Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 05-06-2013, 04:13 PM   #41 (permalink)
Originally Posted by NCcraig View Post
Among others.
Oh, I didn't know you did repairs! I though you just did BL installs.
- Benton Jackson, Maple Grove MN
Roswell Flyer (retired), Concept EP (retired), Eco 8 (retired), WLToys V929 & V202, Nano CPx, Nano CPx mild BL, Nano QX, mCX2, 130x
GoatRider is offline        Reply With Quote Quick reply to this message
Old 05-06-2013, 04:28 PM   #42 (permalink)
Some but the topic was soldering skills.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 05-06-2013, 10:13 PM   #43 (permalink)
Switched to gov arm mode today (using tx program, not a toolstick) and played with some v-shaped throttle curves. I cant believe how well the tail holds now! Almost seems like the climb rate is faster or more efficient maybe. You can really hear that tail working hard too. Couldnt be happier with my mild nano now!
drewracer32 is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 12:34 AM   #44 (permalink)
Default Re: What did you do to your BL NANO Today?
Put my wild nano back in the box because it seems incredibly weak and lame compared to my hp10s 130x
sent from my RAZR Maxx w/Rage Rom
Greek6486 is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 05:28 PM   #45 (permalink)
Default What did you do to your BL NANO Today?
Don't worry, you'll take the nano back out once it is snowing every day again!
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 08:18 PM   #46 (permalink)
Built myself a wild nano
So far I have just done a few easy ciruits. Seems not as 'tight' as the mild nano...maybe its the extra weight? Or maybe its my new Glacier 250's that are not fully broken in yet.
Either way, very happy that the install and flashing went well...even got the motor leads right the first time
mixfisto is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 08:42 PM   #47 (permalink)
Should be the same weight as the "mild" bl Nano, the motors weigh almost exactly the same. Probably the higher headspeed making it a little more twitchy in it's response.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 09:53 PM   #48 (permalink)
Just ordered a Lynx DFC head and swash. Also ordered a titanium shaft, I'm tired of cracking the carbon ones. It seems with the higher head speed I'm breaking them a lot more often.
Old 05-11-2013, 01:18 AM   #49 (permalink)
Think I may finally have found the perfect mild Nano set-up for me. Been dicking around with it for a week now. Seems my tail motor was going. Switched it for a new one and used a MH aluminum tail mount I got in another buy. I hope it will help cool the motor as I put back to back packs through it. Love flying this heli between periods of the hockey games in the small feild in front of my place.
GO LEAFS GO!!!!!!!!!!!!!!!!!
litehawkdown is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 02:45 PM   #50 (permalink)
Well after re-soldering every wire in the setup about 6 times trying to find the weak point with no change... I smoked a FET... after replacing the FET and the tail motor wires... all is good... no power losses anymore =)
T-Rex 700E DFC Pro HV, Blade 500X, HK450 ProV2 FBL (Tarot DFC Head, Tarot DFC Swash, BeastX, Align Blades), mCPX BL (Every RKH Upgrade, KDE Blades, Lion Heli Canopy, Gear and Fin), 130X (Custom build... nothing stock), 300X (Edge Blades)
Meekrakkin is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 04:26 PM   #51 (permalink)
Scratch that... FET came loose =(
Old 05-12-2013, 10:31 PM   #52 (permalink)
Think I got it this time... it's flying again anyways.. lol
I'm going to learn to solder if it kills me!
Old 05-13-2013, 05:57 AM   #53 (permalink)
got my frame braces from astroid. my wild brushless nano is now back together. i will finally get to try the microheli power pack upgraded head set that i installed when i found out my frame was cracked. if only microheli would release a frame for the nano like the mcpx frames.
boofy is offline        Reply With Quote Quick reply to this message
Old 05-13-2013, 06:54 AM   #54 (permalink)
+1
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 05-14-2013, 03:36 PM   #55 (permalink)
The frame mod for the Nano is a PITA. I made my own pieces out of plastic on my hell which made it even worse. I would buy a MH frame if it was 30-35 bucks. The RKH frame is ludicrously priced. I have another frame and I think I will mod it to have a clamp as the glued it motor bugs me to no end.
I am finding this heli to need a bit more maintenance then my MCPX's though. Might be the used bird factor. But I do love the power to weight ratio of this little guy.
Old 05-15-2013, 09:42 AM   #56 (permalink)
I think you're going to love the uH head set! Mine's been rock-solid. Just don't forget to Loctite the blade screws!
Goosky Legend S2
Goosky Legend S1
Smok1n is offline        Reply With Quote Quick reply to this message
Old 05-15-2013, 09:24 PM   #57 (permalink)
Been a couple of weeks since I've been able to fly. Tonite I flew a handful of lipos through my "stretched" DFC Nano tonite. It flies nice and tight, I concentrated on flying "low and slow" with a series of flips, rolls, and loops combined with some inverted hovering 2-4 feet off the ground with the goal of tightening up my maneuvers into as small a space as possible. Pretty happy with the results. Ended the session with a slightly cracked trailing edge on one main blade. Ca'd it back together and ready to go for the next session.
Flew a few rounds with my stock 130X too, but that's another story. All went well, though.
MARTY
Team Newb pilot
Old 05-21-2013, 01:18 AM   #58 (permalink)
Replaced a XP-3A esc on one of my mild nanos. This nano would not build high headspeed with load (i.e. 68% throttle idle up 1 and 75% throttle idle up 2 gave the same headspeed under load). This nano would also seriously bog when applying collective. Thought maybe at some time I had entered TX Programming mode and messed something up but reflashed BLHeli setup with same results.
Without load, IU1 and IU2 headspeeds were as expected.
Looked at ESC and none of the FETs looked burned out so not sure what the issue was.
Many question the logic of having two of every heli.....sure does help to debug problems
MCPX BL, 130X, 180cfx, 300x,300cfx, Compass Warp 360, ZMR250 FPV, EMax 250FPV, Morphite FPV,Taranis
linklemming is offline        Reply With Quote Quick reply to this message
Old 07-27-2013, 05:43 PM   #59 (permalink)
Wow, it's been a couple of months since anyone has posted on this thread, so I figured I better resurrect it. I swapped my mild motor for a 'wild' motor this morning, and, what a difference!! The mild motor performed almost exactly like my well worn brushed motor in my stock nano, it would bog badly with any meaningful combination of collective and cyclic and basically just fold up and fall to the ground as often as not. With the wild motor, it basically does what I ask it to, with very little bogging and no fuss. It does exhibit a bit of TBO, so I think I'll set it for governor arm and run a little V in the throttle curve and that should take care of it. This little heli is now what it should've been all along. Seems to be a bit hard on my Oversky lipos, though....
MARTY
Team Newb pilot
Old 07-27-2013, 07:25 PM   #60 (permalink)
Great, I'm thinking of doing the same thing. I'll be really curious how you end up with lipos. I think I'll go out and fly all my batteries now just to get some stick time in.
George
gstoneberg is offline        Reply With Quote Quick reply to this message
