Go Back   HeliFreak > R/C Helicopter Support > JR Helicopters > JR Forza 700
JR Forza 700 JR Forza 700 Helicopters Discussion
Old 12-20-2015, 05:14 AM   #1 (permalink)
Default Forza autorotation unit issue
Hi All,
Recently I bought a JR Forza 700 and I am having an issue putting it together.
There is now way this heli is doing an autorotation, the autorotation sleeve is way to tight in the autorotation unit.
It is very hard to insert the sleeve into the bearings and sprang, and once it is in the rotation is far to tight. No way the blades will keep spinning of the motor is shut of.
I have tried some triflow thin oil on it but that does nothing, but make a mess.
Could you please help me out?
Regards,
Menno
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 12-20-2015, 09:19 AM   #2 (permalink)
The bearing is like a spray type bearing. It could be the bearings in the housing has gotten flipped ove someway. You should be able to take your finger and see if you can flip it. If that don't work then it is evidently a bad one and should be sent back
Team Jr Americas
LaDon is offline        Reply With Quote Quick reply to this message
Old 12-20-2015, 04:00 PM   #3 (permalink)
Thank you for getting back to me... I find it hard to tell with way the sprangs should sit...
I have attached some pictures looking at it from above.
Other thing is that is was quite hard getting the sleeve through the first radial bearing aswell. Wasn't binding it up but it is a very tight fit.
Regards,
Menno
ID:	625545   Click image for larger version
ID:	625546   Click image for larger version
JR XG14 PL8 v2
Old 12-20-2015, 05:21 PM   #4 (permalink)
There is one caught under the other one. That cant be that way It looks like the way the pic is that it needs to go clockwise. One is not and has a gap. I don't know if that will fix it or not but I would try to get them all even going the one direction the majority are.
Team Jr Americas
Old 12-20-2015, 11:06 PM   #5 (permalink)
Thanks for all your help and time.
Last night before shut eye I was searching for some pictures of Forza one ways. I've found one and that doesn't really seem like a need arrangement aswell.
I have tried tyding it up with my finger but the sleeve won't budge. It is also realy hard getting it through the first radial bearing.
To me it seems like the sleeve is just a tad to big...
Did email the online vendor yesterday, lets see what they come up with...
Name:	Forza one way.jpg
JR XG14 PL8 v2
Old 12-21-2015, 07:01 AM   #6 (permalink)
Yep that is what I would do. Unusual as I have yet to see anything on all the forzas we have built and been involved with that something didn't fit right. But there can always be something that slips through
Team Jr Americas
Old 12-21-2015, 07:46 AM   #7 (permalink)
Did you auto sleeves fit easely through the bearings?
JR XG14 PL8 v2
Old 12-21-2015, 02:14 PM   #8 (permalink)
It has been 1 to 2 years when we put ours together. My memory can only last for a couple days. I really don't remember but I am getting a new gear and one is coming apart maybe tonite I will check
Team Jr Americas
Old 12-21-2015, 02:31 PM   #9 (permalink)
That would be awesome... Thanks...
I've got word from the EU distributor, this is a new issue for them and they are telling me to sort it out with the online vendor.
Haven't heard from them yet...
JR XG14 PL8 v2
Old 12-21-2015, 03:52 PM   #10 (permalink)
What kind of a distributor have you got? If I needed mine taken care of JR Americas will handle it no problem. I would think they would.
Or did you buy it from someone on line like RC Japan?
Team Jr Americas
Old 12-21-2015, 06:29 PM   #11 (permalink)
Ok I took our gear off tonite and measured the od of the sleeve. It is 0.588 thousands of an inch or 14.97 mm. It does go into the outer bearings hard. I cant even move ours. Take the sleeve and put it in the freezer for a few hours and then take a heat gun and warm up the hub. It will prolly go right in but Ryan said when he put ours together it went pretty hard. The one way will still work free tho. It will be ok if you have those dimensions.
Team Jr Americas
Old 12-21-2015, 11:51 PM   #12 (permalink)
I live in the Netherlands. I have bought it from a big and know online shop in Europe. There is a distributor voor the EU in England, MacGregor... I have heard from them telling me to contact the online shop... The shop must be busy this time of year...
I will take the sleeve to work today and measure it...
I will also put it in the freezer and heat up the hub... seems like it mught the one way after all...
Thanks for all your effords, apriciated...
I'll keep you posted...
Regards,
Menno
JR XG14 PL8 v2
Old 12-22-2015, 11:57 PM   #13 (permalink)
Got my hands on a analog calliper...
My sleeve came in at 15.00mm... as far as I can tell
Did not have time to put the sleeve in the freezer... Busy days...
JR XG14 PL8 v2
Old 12-23-2015, 07:03 AM   #14 (permalink)
Well that sleeve might be out of tolerance. I am not sure what it is but that is quite a bit bigger than mine
Team Jr Americas
Old 12-23-2015, 08:49 AM   #15 (permalink)
14.97mm to 15.00mm
It was an analog calliper... So not sure how accurate the reading is...
I sure hope its just the sleeve, that cheap to replace.
Thanks again for all your effords!
JR XG14 PL8 v2
Old 12-23-2015, 02:54 PM   #16 (permalink)
Oh I used a digital one. I would just cool it and shove it in. I think you will find it is ok. Ours went in so hard I almost couldn't push it. Even tapped it with a plastic hammer. But it will work nice. I don't see where you are far off
Team Jr Americas
Old 12-23-2015, 06:02 PM   #17 (permalink)
I will put it in over night and try tommorow...
It all seems odd to.me to...
JR XG14 PL8 v2
Old 12-23-2015, 08:00 PM   #18 (permalink)
A good tight fit makes things work better. It just isnt going in the outer races easy. Ryan said he had a heck of a time putting ours together too but it works perfect. They way I told you should make it easier. Just make sure you put it in the right side
Team Jr Americas
Old 12-24-2015, 01:14 AM   #19 (permalink)
I know, that's not what I mean. I find it odd mine binds when I can seem to find anything wrong...
The radial bearing tightness I can fix, but if it still doesn't spin free there is something wrong.
My main problem is that the one way doesn't spin free when holding the main gear and spinning the sleeve clockwise...
JR XG14 PL8 v2
Old 12-24-2015, 01:29 AM   #20 (permalink)
There is usually a bit more drag with a new Sprag than with a ramp-roller clutch (the Sprag is stronger, though). This goes away with use.
Did you lube it with ATF?
Is it so tight that it is hard to turn, or does it seem like it will break in with a small amount of use?
