SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters |
11-05-2016, 12:30 AM | #1 (permalink) |
500 sport transmission belt alignment
So my kit came with a scorpion motor the pinion is pressed as far up the shaft as it can go and the motor mount is tightened all the way up and the belt is just level with the trans drive pulley according to the instructions they want the belt ridding 1mm higher than the pulley
Any ideas or is it fine the way it is?
Nano qx, nano cpx, 300x and 550x |
11-05-2016, 02:34 AM | #2 (permalink) |
Is there a step in the the motor shaft or circlip or something preventing the pulley from going up any further? I've sometimes run the belt only level with the top or bottom of the owb pulley with no ill effects. Not ideal but as long as it doesn't ride any lower than the bottom of the pulley it'll probably be fine.
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700 |
11-05-2016, 02:59 AM | #3 (permalink) |
Shaft starts to tapper up to a larger diameter
11-05-2016, 03:46 AM | #4 (permalink) |
If you have access to a lathe or drill press you could drill out the top of the motor pulley just a couple of mm but be careful if you try to do it by hand as the drill can get away from you real easy and suddenly you've gone too deep. A tapered reamer might also do the trick. I think a flood of people are going to find this problem as more kits are sold with the Scorpion.
11-05-2016, 11:43 AM | #5 (permalink) |
belt alignment.
You might consider small shims between the motor and plate. A thin washer on each bolt should do the trick.
RCHN citizen 533, Protos Max Legerro 700 w/Brain2, Logo 550sx w/Brain2, Protos Max V2 780. w/Brain2, Hobbywing ESCs, Spektrum, Scorpion Motors |
11-06-2016, 12:45 AM | #6 (permalink) |
Did a slight chamfer on the pinion and was a little better but then I noticed the pulley had on the trans pulley had a bit of play so added 2 shims to the its a hair off the bottom of the pulley now I guess that's better than riding the bottom
11-06-2016, 01:23 AM | #7 (permalink) |
Don't take all of the play out of that pulley - should be free to float up & down a mm or so.
11-06-2016, 10:40 AM | #8 (permalink) | |
I will get my own G500 Sport combo kit in a few weeks time, so I guess I'll find out for myself soon enough, but if the motor shaft has a collar on it that prevents proper alignment of the belt, then I won't be using the Scorpion motor, and I'll complain to SAB and my supplier as I'm not prepared to modify new parts in such a manner to achieve correct alignment. MB
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520 "More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein |
07-17-2017, 04:01 PM | #9 (permalink) |
I had the same issue, I've added a shim on each bolt between the motor and the plate and I was able to correctly align the belt. I guess this would be a common problem with this motor and the G500 but there isn't really much posts reporting this.
Goblin 500/380/Mini Comet T-REX 450L/250 Oxy2 |
07-17-2017, 06:01 PM | #10 (permalink) |
This is old news, you must cut a chamfer in the pulley, best use a drill press. Cut till belt alignment is good.
Forget shims under the motor.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4, X5 stretch 220 Flame Emax Bullet Force V2 VTX |
07-17-2017, 06:34 PM | #11 (permalink) |
https://www.helifreak.com/attachment...1&d=1490489116
An example of what you need to do to pulley! I used a drill press. Alignment is perfect! |
07-18-2017, 08:56 PM | #12 (permalink) |
My quantum motor that came with kit was the same exact way also had to shim mine also
07-19-2017, 05:37 AM | #13 (permalink) |
When I ran the Scorp motor my belt was about 1mm lower than the pulley. Never had a problem. Changed to Xnova and it is now even with the edge of the pulley. Still no problem.
-Ben Oxy 2/3/4/5; XL 550/700; Protos 380/700 EVO; RAW; Jeti DS12 Carbon EGODRIFT Team, Lynx/Oxy Field Rep |
07-19-2017, 03:21 PM | #14 (permalink) |
The belt is supposed to be midway on the pulley, but as long as ALL the belt is somewhere on the pulley, probably won't matter, except they do track up and down a little as it runs, so best to start off centre pulley as per instructions. Recessing the motor pulley boss seems the simplest and tidiest solution.
crash'n'learn Chris If you ain't crashing you isn't learnin. |
07-28-2017, 10:20 AM | #15 (permalink) |
meet similar issue with 4025, and the main pulley on the secondry shaft has some up and down play, do I need to eliminate it with washers?
07-30-2017, 10:41 AM | #16 (permalink) |
Washers? Read post 10, 11 and 14.
