Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Like Tree3Likes
Old 09-05-2014, 11:32 AM   #41 (permalink)
Does anybody have dimensions of the GSR260 fuel tank? I recently acquired an Ergo Z230 and looking for a better fuel tank. From pictures, it looks like the dimensions could be very similar where it mounts into the frames. I know JR has a reputation for making parts cross-compatible with their other heli models, at least back in the day...
Thanks!
Khosravi is offline        Reply With Quote Quick reply to this message
Old 09-09-2014, 07:30 PM   #42 (permalink)
this should answer your questions
Name:	jr tank top.jpg
ID:	535086   Click image for larger version
Name:	jr tank side.jpg
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 12:33 PM   #43 (permalink)
I noticed in the construction that you did NOT bond the pinion gear to the bearing block as advised in the instructions. I did, but after two seasons the bond didn't hold and it wore out the top of the pinion gear so badly that the pinion was skipping on the main gear and the lower bearing in the bearing block was trashed. It's quite the job to get the assembly out. You're either dropping the engine which is a chore or splitting the frames in half which I did. I bought some industrial Loctite that I was advised I would probably never get the pieces apart without damaging them, but they don't cost that much, so if that is ever required, I'll just buy a new pinion and bearing block. Hope you don't run into this issue.
HAL9KPCM is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 06:51 PM   #44 (permalink)
I'm going to swap out the engine fairly soon, I'll take a look at it
I'm also have a K&S ZGSR26 conversion for it that I'll install a bit later. That totally changes the model
Carey Shurley
Old 09-20-2014, 10:32 PM   #45 (permalink)
Is that the complete new frame set? I'm actually pretty curious about that one myself. Post plenty of pics!
Old 09-21-2014, 08:09 AM   #46 (permalink)
yeah it replaces pretty much the entire chassis, all graphite, lighter
Carey Shurley
Old 09-23-2014, 12:05 PM   #47 (permalink)
Thank you so much! Looks like it'll be a direct drop-in for my Ergo Z230! Can't wait to get my tank in!
Edit - Got the GSR tank in, it's a direct fit for the old JR Ergo Z230. Thanks again for the dimensions.
Old 04-11-2015, 03:55 PM   #48 (permalink)
I attempted to buy the GSR260Z FBL Sport from RC Japan this morning and could not find it on the JR Glow/Gas helicopter section. After some searching I found it on the discontinued section. Can anybody confirm that the FBL Sports version has been discontinued? That is what I get for waiting for the yen to fall a little more before making the purchase
Jason
KELHAR Designs
CAD Design, Laser Cutting, CNC Router, & 3D Printing
KELHAR Designs
spookyeng is offline        Reply With Quote Quick reply to this message
Old 04-12-2015, 04:43 PM   #49 (permalink)
Default GSR260z Sports FBL - Availability
Jason,
The kit that is discontinued on RCJP is the 88315 which was the kit w/ servos and FBL controller.,
The 88314 is still available but I think you will find it more expensive than at JRAmericas.
JRAmericas never carried the 88315
Mike S.
Whiplash II Gas, Synergy 766 Gasser, OMP M2
encore27 is offline        Reply With Quote Quick reply to this message
Old 04-26-2015, 08:29 AM   #50 (permalink)
Smile Many thanks Carey GSR260z
Many thanks Carey. I am now 50% through my GSR260Z build.
Your post has been a great help and has made the build easier.
Must say I have always built Hirobo kits as I have always liked the quality of their kits and the build manual is very clear to understand.
I decided to build the Futaba kit as I wanted a large petrol Heli and
although the parts are of a very high standard and I absolutely love the Heli, the same cant be said for the build instructions. ( mine was all in Japanese...)
Thank again very much appreciated.
Nick
wildhog is offline        Reply With Quote Quick reply to this message
Old 09-13-2016, 06:55 AM   #51 (permalink)
Is there an Rc style engine conversion for this model?
Stonetronix is offline        Reply With Quote Quick reply to this message
Old 09-13-2016, 11:22 AM   #52 (permalink)
never seen one, the only conversion kit I've ever seen for it is this one
http://www.rcjapan.net/index.php?mai...shuagn26f90qp5
which appears to have been discontinued
Carey Shurley
Old 01-29-2020, 03:43 PM   #53 (permalink)
I know this is an old thread, but are these parts still available from K&S?
JesusFreak is offline        Reply With Quote Quick reply to this message
Old 04-24-2020, 10:48 AM   #54 (permalink)
Anyone still flying these? Are parts available anywhere?
Old 05-02-2020, 07:03 AM   #55 (permalink)
yes still flying however parts are hard to come by at this point. Best bet is to buy an air frame and use for parts, there were some differences between drivetrain parts between the older and newer versions but a lot of the chassis parts are the same.
Old 07-04-2023, 02:47 PM   #56 (permalink)
Hi Folks,
THis is an old thread I know, but does this engine use a magneto (i.e. no ignition battery)? Also, what is the recommended oil and mix for this motor?
MarkusG likes this.
"Keep it pithy."
eAurora, TREX600E, TREX 600 HFEX, TREX500, Vibe 50
(Professional grade pretzel maker).
Old 07-04-2023, 03:19 PM   #57 (permalink)
magneto ignition
normal mix ratio, 36-40:1
MarkusG likes this.
Carey Shurley
Old 01-18-2024, 07:35 PM   #58 (permalink)
Oh my! That is an awesome looking model!
Jarrett W.
Mustang, OK
JWatson is offline        Reply With Quote Quick reply to this message
