Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-17-2017, 10:54 AM   #21 (permalink)
If you are going to use a wiring adapter to connect your gov sensor to the Ikon this is what to look for. It already has the + and - wires swapped. I'm going to use this to get my setup done then crimp on a servo plug. Probably other sources for an adapter but this is the one I found.
http://www.horizonhobby.com/jst-zhr-...82%29-eflra100
jiminator is offline        Reply With Quote Quick reply to this message
Old 03-17-2017, 12:22 PM   #22 (permalink)
Thank you so much for this, saves me the trouble finding one.
AdrianXD is offline        Reply With Quote Quick reply to this message
Old 05-27-2017, 09:18 AM   #23 (permalink)
Originally Posted by smwht View Post
The BK servos are HV capable, so you can run a straight 2S lipo, no need for the regulator. You'll need to come up with a harness that goes from the battery connector to at least 2 servo plugs, a single servo plug can't handle the current draw required for the BK servos - the plug tops out at 5A continuous.
All my nitros just run a straight receiver pack.
can you please share pictures of your set up? I want to see a nitro running a straight receiver pack also what are igniter are you using for your nitro?
Old 05-27-2017, 10:40 AM   #24 (permalink)
Sure, I think you can see just about everything in this pic. Vbar is on top of the ignitor - protek truglow. Not sure they make that currently, I heard they had some supplier issues. The black box you can see in the round cutout is the spartan power bus - it has 2 servo leads coming out of it and into the vbar. Other side of the box has 2 servo ports and the wires I plug the 2s lipo into. Wiring is kinda messy but it gets the job done.
When I have a battery on it I use the velcro hanging off the front to hold the plugs in place and keep the wires from flopping everywhere.
My N7s have a similar setup, just with a vbar neo instead.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 08-06-2017, 09:57 PM   #25 (permalink)
This is my 700n that's been slowly updated after each crash. I now run an fl head the same as the 700x. I run direct 2s into my vbar and switch glo pro.
You may notice I currently have 3 lines coming from my battery, 2 directly into the vbar and the third one directly powering the switch glo, this was just an old harness from a previous wiring job when I had a seperate receiver onboard. This set up is about to change though because of my last incident, evidence can been seen in the pics! I am now going to install a pin flag switch (http://www.boomarc.com/en/hidden-bal...-with-pin-flag) so the main battery terminal is secured for the day and not being plugged and unplugged after each flight. With this switch I will be running both feed lines to vbar and plugging the switch glo power back into the vbar as well, much neater setup.
Hope this helps.
ID:	718290   Click image for larger version
ID:	718291   Click image for larger version
ID:	718292   Click image for larger version
Blade Mcpx
Align Trex450 se/sport
Align Trex700n FBL
nightrider is offline        Reply With Quote Quick reply to this message
