Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters
Compass Helicopters Rage RC Hellicopter Discussion
Old 03-02-2017, 11:43 AM   #1 (permalink)
Default First Compass Heli!
Hey all! I'm stoked here as I just bought my first Compass heli.
Bought a used Warp 360 V1. I've always been impressed with the Compass line of helis (never seen one in real life yet, lol).
I'll be skimming through the Warp forum, but any advice with this bird would be awesome.
It will be coming with a Hawk-RC tail case, but it's not installed yet, so not sure if I'll just leave in the stock one or not.
This is going to replace my tired old Blade 450 3D.
Cheers!
Chris
Diabolo 700, Xnova, Castle, Spirit
Diabolo BE, Pyro, Castle, Spirit
Logo 550SE, Castle, Xnova, Spartan
Oxy4 Max, Spartan VX1e
, iCharger w/LiFePO4, DX8 G2, AccuRC
CFerry is offline        Reply With Quote Quick reply to this message
Old 03-02-2017, 11:49 AM   #2 (permalink)
Cheers!
Chris
Enjoy, Chris!
Scott
KBDD Team Pilot ):>
Old 03-02-2017, 12:05 PM   #3 (permalink)
CFerry,
Welcome!
There are quite a few of us here who will be happy to answer any questions for you.
I have upgraded a Warp V-1 to a Warp V-2, so I am familiar with the process. Compass is constantly working to improve their models so there were quite a few changes.
The boom has been changed several times: first to increase the wall thickness and then to reduce the length very slightly to accommodate the optional, 19 tooth (larger) tail pulley. The thicker boom is a good idea as it is quite a bit sturdier.
The tail bellcrank mount has been changed twice. The first version was plastic, the second aluminum, the third was machined delrin. The second or third versions are much stronger than the first version and either should be used.
I think the consensus was that the stock tail was more robust than the Hawk version (I am sure others will post their thoughts on this). The V-1 tail case sides are CF. The V-2 case sides are aluminum-you definitely want the aluminum ones. I epoxy the bearings into the tail case sides.
When the V-2 came out, a brace was added between the two idler pulleys for the tail belt. This is not necessary if the tail belt tension is set correctly (i.e. as loose as possible on the bench without the tail belt skipping when the tail rotor is held with one hand while you attempt to turn the head GENTLY with the other). If you pull the belt tight like a guitar string (not a good idea) you will need the brace.
The tail grips on the V-2 are slightly heavier/thicker. I used the first and second versions with no problems.
The motor on the V-1 was noisy on spool up-this was corrected by changes to the motor can.
There is a replacement canopy mounting tongue that is a bit longer than the stock version. This allows you to mount the canopy a bit further forward which helps with getting a good CG.
One of the nice things about the Warp is that it resists wear. With periodic lubrication it will go for a very long time without having to replace parts due to wear an tear.
That is all I can think of for the time being. I am sure that more of will chime in.
Old 03-02-2017, 01:36 PM   #4 (permalink)
Ah Clem,
Thank you for those tips on v2 vs v1. That gives me a great start on what to look at. It feels great to know there is help, especially if I run into problems.
This is one thing I love about this hobby.....the great community.
I think I have a problem though as I'm constantly checking Canada Post tracking........even though expected delivery isn't till Monday
Chris
Old 03-02-2017, 02:11 PM   #5 (permalink)
Ah Clem,
Chris
I do the same thing. Once in a while you get lucky,at least here in the U.S.. My last two packages scheduled for Monday delivery arrived on Friday
You should be happy with the Warp. My friend went from a Blade 450x to a Warp 360 and it was love at first flight!! Compass has a pretty strong following here in Michigan and everyone I've met that owns one loves theirs and ends up buying another one.
Had the pleasure of watching a Chronos fly at the field and was thoroughly impressed with how smooth it sounded and how well it flew. Someone flew a Trex 700 right afterwards and it made some scary sounding noises in comparison.
Both were smacked around equally hard but the Trex squealed for mercy a few times while the Chronos said "Is that all you got punk?"
Congrats on your new machine
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 03-02-2017, 05:34 PM   #6 (permalink)
Yeh , your going to love the Warp !
They really do fly 'big' compared to other Helis in the same class. After buying a used one , I'd placed an order for a second new kit before my Packs had time to cool.
No need to be looking for third party upgrades , Compass do that for us if anything needs improving on which earlier posts do outline.
I'm about to build an eXo which I can see is going to take everything I love about the Warp to the next level.
Enjoy !!
team eDUCATIon !
eXo BD3SX Torq/BK HW ,Warp-Spirit/GeoLink MKS , #2 Warp-Spirit KST. iX12
Van Scott is offline        Reply With Quote Quick reply to this message
Old 03-02-2017, 07:37 PM   #7 (permalink)
Too funny. I love my Trex 550, but if I`d love the opportunity to see a Chronos irl.
