Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 08-22-2010, 09:57 PM   #1 (permalink)
Default Compatible parts between 550 and X5
So what parts are compatible between the X5 and the 550?
Compatible
X5 Tail drive 61 tooth= Hurricane main gear 61
Landing gear, skids = same but X5 pipe work is chrome
X5 boom supports are 90mm longer but will work and be shiny
X5 tail hub/grips = straight fit
X5 tail box,levers,slider etc = hurricane
X5 front TT drive = hurricane TT
X5 400mm flybar = fit hurricane should you desire and the cutouts for the grub screws are spot on
Not compatible
Mast
Zeta30 is offline        Reply With Quote Quick reply to this message
Old 08-22-2010, 10:32 PM   #2 (permalink)
Zeta, I've started taking a few pics and am planning on doing a thread on this during the week. Just need to get a few moments.
Vas
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote Quick reply to this message
Old 08-23-2010, 02:40 AM   #3 (permalink)
Blades I reckon, plus I would guess ...
paddles, tail stuff, plus I'm fairly certain the the under-carraige is the same
Old 08-24-2010, 01:53 AM   #4 (permalink)
That would be great Vas, thanks! The X5 looks amazing. Would you mind taking a pic of the X5 canopy on the 550? I know it would not be a direct fit but I think with some work it could make the 550 very easy to see. Thanks!
styndall is offline        Reply With Quote Quick reply to this message
Old 10-10-2010, 08:47 PM   #5 (permalink)
I went ahead and bought a mast for the X-5 because a site had them on sale. I can say with 100% certainty that the main mast between the X5 and 550 are not compatible. The X5 mast is about 1/2" longer and the holes are spaced differently as well.
Old 10-10-2010, 10:09 PM   #6 (permalink)
very true Zeta. The collar up is the same length,but collar down is about 12mm as you mention longer. Different drive setup. A few of the differences are mentioned
here
I've taken a few pics and hopefully some more and won't be too far away from a list.
for now
X5 Tail drive 61 tooth208903 61T Gear (Set of 2) = Hurricane main gear 61
Landing gear, skids = same but X5 pipe work is chrome208970 X5 Brace Set, 208370 X5 Skid Set (Silver anodized)
X5 head assembly looks to be drop in, just flybar cage will have to be swapped for Hurricane as is narrower swash
X5 boom supports are 90mm longer but will work and be shiny 208362 X5 Tail Supporter Pipes(Silver anodized)
X5 tail hub/grips = straight fit hurricane and best tail ever imho 208950 X5 Tail Hub and Grip Assembly
X5 Tail Pitch Assembly(for 5mm)208924 208914 X5 Tail Gear Case Set(plastic for belt)
208907 Tail Pitch Control Lever Set 208922 Rudder Control Guide208923 X5 Tail Pulley Set(for belt)
208908 Tail Rotor Blade Set (82mm) 208705 X5 Fin and Tail Set 208710 X5 Fiber Fin and Tail(1.6mm) 208365 X5 CNC Torque Tube Tail Gear Case 208364 X5 CNC Tail Fram Set (Black anodized) 208379 X5 Tail Output Shaft with Pulley(for belt)
208380 Tail Output Shaft and bevel gear set 208381
Front drive gear set and Pulley Shaft with Steel Gear (15T)X5 front TT drive = hurricane TT
X5 400mm flybar= fit hurricane should you desire and the cutouts for the grub screws are spot on
208349 X5 Flybar(400mm)
more coming
Vas
GAUI
Old 10-10-2010, 10:45 PM   #7 (permalink)
I've been using the X5 flybar cage for some time now with no troubles.
spootman is offline        Reply With Quote Quick reply to this message
Old 10-11-2010, 08:00 AM   #8 (permalink)
Thanks guys, I've copied your findings up to the first post to make it easier to keep track.
Old 10-25-2010, 07:03 AM   #9 (permalink)
ok lets start adding some pics and part numbers
hurricane silver 550 boom 204191
X5 TT boom 208321 (comes in 2 pack)
hurricane tail supporter pipes 204557
X5 tail supporter pipes( 90mm longer and anodised silver) 208362
Hurricane Landing brace and skid set 204180(complete) 204188(just braces)
X5 skid set(silver anodized) 208370
X5 landing brace set 208970
more to come
Vas
GAUI
Old 07-08-2012, 08:32 AM   #10 (permalink)
Nice post. did anyone try X5 tail fin & stabilizer on the hurricane?
Gaui part 208710
http://www.allerc.com/gaui-x5-1-6mm-...il-p-6215.html
stark is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 04:26 PM   #11 (permalink)
Gaui part 208710
Yes, I have those on my 550, no modding needed
catzjes is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 04:57 AM   #12 (permalink)
cool, thanks catzjes.
Old 06-06-2016, 03:01 PM   #13 (permalink)
Hey Guys
Just so you know, the X4 front and main gear hub is the same as for the hurricane. Some sites have hurricane parts out of stock, actually have the identical part for the X4 listed.
Cheers
PhillyD is offline        Reply With Quote Quick reply to this message
