Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Chase 360
KDS Chase 360 KDS Chase 360 Discussion
Old 04-01-2017, 12:04 AM   #1 (permalink)
Default Liking the chase stretched
Just bought this off a fellow helifreak. Threw in an xnova 1860 with a 20 tooth pinion, some zeal 380's and switch tails.....rebuilt the heli as it was shipped half apart. Flies excellent has a crisp feel with cyclic and tail is phenomenal.....how long does the second bigger belt last? How many flights u guys getting?
ID:	701141   Click image for larger version
ID:	701142   Click image for larger version
out flying..
$Gambino$ is offline        Reply With Quote Quick reply to this message
Old 04-01-2017, 02:04 AM   #2 (permalink)
I just passed 100 flights on a new build. I started out stretched with a trex 500 tail belt and all belts are still fine. Spray them with some silicone from time to time.
I use a PTFE Dry lube spray and i still need to get some spares in stock
Sirolf is offline        Reply With Quote Quick reply to this message
Old 04-01-2017, 07:01 AM   #3 (permalink)
Nice well ill grab some silicone then! Thanks!
out flying..
Old 04-02-2017, 02:51 PM   #4 (permalink)
[ame="https://youtu.be/AGmB0IP9wjk"]Stretched chase 380/ mks/xnova higher headspeeds - YouTube[/ame]
Second flight running higher headspeed not sure what it is but know its high. 1800 mah 65c ...she moves
out flying..
Old 04-09-2017, 02:17 PM   #5 (permalink)
Bag the silicone guys. Use a product called white lightning clean ride wax lube instead. Most us belt driven guys are using it on all our stuff.
Old 04-09-2017, 04:24 PM   #6 (permalink)
Used the white lightning also during the build but a pain to apply when it is up and flying so i switched to spray drylube.
Belts are still good as new
Old 04-15-2017, 02:31 PM   #7 (permalink)
We just had a 766 stripping tail gears using the dry lube. Applied the white lightning. Zero issues now.
Yeah, it is a total pain to apply. I just don't do it directly out of the bottle. Been using a toothbrush, but am gonna try it out of a spray bottle this week. Will let everyone know how that works....
Btw, still on the same belts I had when doing the build thread sticky. The last a loooong time when properly taken care of.
Just installed a rare Kde 450XF 1750 bought in pristine shape for less than $40. Tore it down and lubed it up with diamond lube just to make sure all was well. What a motor! Does the same thing to my Chase that Patrick at Kde's larger gen 3 455kv does to my Gob 800. Flew it yesterday. Just rips. Was looking at the Xnova and wondered how they compared. I think the mags and stator on the Kde are still much higher quality. Hence, the high price guys didn't want to pay and why they no longer produce them?
Old 04-15-2017, 04:35 PM   #8 (permalink)
Some pics of mine. I really enjoy this heli! It rips so hard with the xnova 1860 , pulse 1800 65c running high hs. Flies precise, fast and nimble and have had no problems about 50 flights so far. Thinking of changing the swash to blade grip linkages to real turnbuckles mine are a little loosey goosey. Even tho they move easily on ball the take quite a bit of pressure to actually pop off...anyone have any recommendations?
ID:	703353   Click image for larger version
ID:	703354   Click image for larger version
ID:	703355   Click image for larger version
out flying..
Old 04-19-2017, 01:06 PM   #9 (permalink)
I am using aftermarket turnbuckles made for the trex 450 pro. All my links have expired though so not sure where they are stocked now. I scrapped the nasty Chase links that should easily have been machined as true turnbuckles right off the bat. Which is what Glen penned out when he designed this heli.
Old 04-19-2017, 03:47 PM   #10 (permalink)
These are the ones from the build thread:
http://www.helioption.com/store/inde...roducts_id=138
Couldn't get them to work on mine, too short...
JetiDC-16, GAUI X2, MS-Hornet's, Trex450's,LAheli(Maxir, Ricco's,LA400,SniperV2), Logo600SE, Chase380, D360KSE, Warp360, BEAM E5, Multi (Quad, Vtail, Hex), Spirit, SpiritPro
IamCxZ is offline        Reply With Quote Quick reply to this message
Old 04-19-2017, 10:30 PM   #11 (permalink)
Sooo they do work or dont? Lol. Anyways the thing that bothers me with stock links is how loose they are on balls i got the red part to actually not unscrew links. Hopefully the helioptions are tighter on balls
out flying..
Old 04-20-2017, 09:53 AM   #12 (permalink)
As I recall....
Since they are shorter, they raise the swash - which is a good thing, since servo to swash links need to be longer anyway.
In your case, no, they are not drop in replacement.
I seem to remember that the HeliOption plastic links were horribly sloppy on the balls.
You can use Align links if you have a good batch, or SAB - although they need to be shortened.
It's in the first couple of pages of the build thread...
Old 04-21-2017, 09:51 PM   #13 (permalink)
Ok cool thanks
out flying..
Old 04-22-2017, 12:49 AM   #14 (permalink)
I changed out all my links to Align 450 links servo to awash & Align DFC links for the grips & follower arms to swash.
The loose & crappy plastic links that come stock made me nervous. Never had a failure, but I didn't chance it either.
I had to do some trimming of the links to get them to fit & still have enough room to make adjustments for geometry.
Damn_encode is offline        Reply With Quote Quick reply to this message
Old 04-23-2017, 12:05 AM   #15 (permalink)
U have a link or better yet a part # buddy? And i know there is various align 450's im guessing newer links? Anyways if anyone is interested thinking of selling mine. Pm me. Flies great top of the line electronics
out flying..
Old 04-23-2017, 06:50 AM   #16 (permalink)
What are you guys using for a stretched boom? Is the Protos 500 one the only way to go?
I started running the new Align plastic tailblades but i am running into vibe problems again using a 1mm thick cf boom. With Edge cf tailblades there's no problem but the hold is not great.. need longer ones.
Old 04-23-2017, 07:12 AM   #17 (permalink)
I buy the Protos 500 part # MSH51322.
From what IamCxZ. posted the Beam E5 boom would work also but I have not tried it yet.
ifheli is online now        Reply With Quote Quick reply to this message
Old 04-23-2017, 07:46 AM   #18 (permalink)
Ok.. and anyway to get the printing off?
Old 04-23-2017, 08:46 AM   #19 (permalink)
Monokote trim sheet----wide range of colors to chose from.
Dan
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is offline        Reply With Quote Quick reply to this message
Old 04-23-2017, 10:45 AM   #20 (permalink)
I always install with MSH facing down but trim sheets will add color to tail.
