Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Old 06-09-2017, 03:49 PM   #1 (permalink)
Default Blade 230S Won't lift off
When I am at center sick on my Spektrum DX8 all servos are at 90 degrees.When I give it throttle and push stick forward the head speed increases but won't lift off,can someone help me out
Keep on Flying
Pipes is offline        Reply With Quote Quick reply to this message
Old 06-09-2017, 05:39 PM   #2 (permalink)
Is your swash plate going in the right direction? Are you getting any positive pitch on the blades?
Blade CX2 (x2) 120SR, CP Pro2,230S Huey, 400 3D (X2), 450 3D (x2), T-Rex 450 sport, T-Rex 450Pro DFC, T-Rex Scale 450 size x4 , T-Rex 470LM ,T-Rex 500 ESP, T-Rex 600N, Fireball.
icehunter is offline        Reply With Quote Quick reply to this message
Old 06-09-2017, 08:16 PM   #3 (permalink)
First thing double check pitch curves and make sure both blades are attached the right way round.
Goblin 420 | Goblin 280 Fireball | Gaui X3 | KDS Chase 360 | 360CFX - 6S | 230S | 180CFX x3 |
130S | Nano CPS | V977 | XK K110 | Skookum Spartan V-Bar uBrain BeastX | DX6 Gen3
Lotus 7 is offline        Reply With Quote Quick reply to this message
Old 06-09-2017, 08:26 PM   #4 (permalink)
He meant to say...big blades go on top and little blades go at the back..
Old 06-10-2017, 06:48 AM   #5 (permalink)
When I look at the Heli nose to the right and tail to the left and I move the stick on both of my Blades230S one of the helis servos works in the correct direction this is the one that flys great but the other one that I repaired the servo
the servo on the top back right hand side does the reverse of what the servos does on the heli that flys great.
I have both heli binded to a Spektrum DX8 and run them on the same radio position, is it possable that this servos is reveresed and it so how do I correct it.
How do I fix this
Keep on Flying
Old 06-10-2017, 07:41 AM   #6 (permalink)
Ok I set everything the same for both Helis but for some reason One main blade has a poss pitch and the other is at 0 pitch can someone tell me how to fix this
Keep on Flying
Old 06-10-2017, 07:57 AM   #7 (permalink)
How do I fix this
Pipes, I am a beginner with a 230 S problem of my own.....but after reading your thread, I suggest that if you have set up the heli profile on your DX8, simply go back into the profile and reverse the operation of that servo to match servo operation of the one that does fly well...
garyv440 is offline        Reply With Quote Quick reply to this message
Old 06-10-2017, 08:33 AM   #8 (permalink)
Is this heli used? New BNF? One you fixed after crashing? Measure the length of the linkage rods on the good one and compare to the one you are having trouble with. When you get +pitch on the one blade,is the other one also getting positive pitch? Just not as much perhaps?
Old 06-10-2017, 08:48 PM   #9 (permalink)
I have two Blades 230S I have looked at the servos powered up and they have the servos at the same position,for both helis. When I power up the heli tthis one won't lift off the ground,
Can't figure this out.
Keep on Flying
Old 06-11-2017, 07:17 AM   #10 (permalink)
Is the LED on the ESC blinking on the one that won't lift off?
Bill_Van is offline        Reply With Quote Quick reply to this message
Old 06-11-2017, 05:22 PM   #11 (permalink)
I just tried again and everything looks ok , I get good head speed and I have positive pitch but heli won't lift off the ground.
Can't figure this out,don't know what to do now.
Can someone send me pictures of where the servos should be at 0 stick.
Keep on Flying
Old 06-11-2017, 05:37 PM   #12 (permalink)
How do you know you have positive pitch? Keep the motor in throttle-hold mode and move the throttle/collective stick all the way up - does the swash plate go up or down? When it goes down, does the front or the back of the blade go down too? Are you blades spinning clockwise when looking from above? Very difficult to help by showing pictures of our servos but (if you are not in stability mode, and you initiate the heli on a level surface) your servo arms should be pretty horizontal and the swash plate should be pretty level and your blades should be close to zero pitch, when both sticks are centred,
Does that help?
AndyO is offline        Reply With Quote Quick reply to this message
Old 06-12-2017, 07:19 AM   #13 (permalink)
Yes when I move the throttle/collective stick all the way up - does the swash plate go up or down?
Yes the swash goes down
Yes the do.
I just placed both sticks at cente rand re align the servos arms 90 %
will see what happens and back get back to you
i will g
Keep on Flying
Old 06-12-2017, 07:58 AM   #14 (permalink)
Just tried again still doesn't lift off and heli keeps trying to slide backwards along the ground
Keep on Flying
Old 06-12-2017, 08:22 AM   #15 (permalink)
Ok I powered up both my Blade 230S When i put the both sticks on the Spektrum DX 8 centered both helis have all three servos arms at 90 degrees
on the both of them, when I push the left stick forward or down two servos the ones in the back are in the same position.
I have them working on the radio under the same model
Looks like some how I need to make changes to these two servos. Do I do this on the radio but I don't want to loose my original setting because one heli works fine. Should I program another spot in the radio if so how do I correct the other two servos
Keep on Flying
Old 06-12-2017, 11:12 AM   #16 (permalink)
Are you sure that the servos are plugged into the correct ports on the receiver/FBL unit?
You didn't clarify whether the leading edge or the trailing edge of the blades goes down when the swash moves down? Trying to ascertain whether you have the blades on backwards....
When you move the collective stick up, all 3 servos should pull the swash down equally - if your blades are on correctly, the grips should be pulling the trailing edge of the blades down, creating positive pitch...
Old 06-12-2017, 02:00 PM   #17 (permalink)
This was the first thing I suggested checking. It's an easy thing to overlook, I know I've done it.
@ pipes, I'm sorry but it's hard to get a grasp of exactly what's going on. One thing I can tell you is any adjustments made to the servo arms need to be made while in "servo adjustment mode" - this disables the flight controller and centres the servo's (not the arm). With the servo centred the arm can then be set perpendicular to the servo. If it's way out then it needs to be manually replaced, if it's just a little out it can be adjusted remotely using the tx. The whole process is described in the manual.
Old 06-12-2017, 02:56 PM   #18 (permalink)
Ok I had a wire in the wrong area, but now the front servo doesn't work and when I try to bind I don't get all the 6 beeps
Now what do I do
Thanks for your help
Keep on Flying
Old 06-12-2017, 03:18 PM   #19 (permalink)
Well done for finding the servo plug error. Had you already performed a bind with this heli and your Tx? Have you left the bind plug in?
I would start from scratch if I were you - servo arm setup as per adjustment procedure Lotus7 mentioned, then check swash for level and blades for zero pitch at mid stick etc etc
Probably not necessary but maybe consider creating a new model in the Tx and import the Blade 230S file into it clean, do you have an SD card?
Old 06-12-2017, 04:18 PM   #20 (permalink)
Ok I made another set up in th radio and I will put back the bind plug and see if I get the 6 beeps
o
Keep on Flying
