AerialFreaks Hyper 3D Quad Forum Hyper 3D 400, Hyper 3D 280 Support |
04-18-2015, 10:29 PM | #1 (permalink) |
Hyper 400 Mode Selection Question
As the supplied manual is a little weak in explaining the various modes I was looking for some help in defining what they do and what is available on the Hyper 400?
ARM Angle Horizon MAG Headfree HeadADJ Beeper OSD SW From playing around with mine it appears that the ARM must be green to fly in any mode where I assume one then picks the Angle or Horizon however there does not appear to be much info on the different modes and what they do.
Wife, Kids and house payment |
06-04-2015, 07:53 AM | #2 (permalink) |
There are really only 3 modes:
Acro - default and is not listed, so if you are armed and neither of the the other 2 modes are selected, this is. The Hyper is for 3D so this is how it comes setup. Basically it just uses the gyros and allows you to flip and does not auto level when sticks are released. Angle - When selected limits angle to 50 degrees (I think) and will auto level when sticks are centered. Horizon - This is a combination of the 2 other modes and will act as angle mode until you use extreme stick throws then will flip. The other ones you listed are sub modes of these. "Arm" of course must be active to do anything. Hope this helps.
Mark Outrage Fusion50 FBL 12s Logo 10 6s FBL 3DMP-V50 FB nitro Last edited by spence46; 06-08-2015 at 04:22 AM.. |
10-12-2015, 06:47 AM | #3 (permalink) |
i need help bad
Ok i have about had it i own a hyper 280 set up went fine. I own a leap 3d set up was even easier .. Gret flying maching never a problem ... Then i got the hyper 400 i have been through 6 arms and 13 props ... I have 3 modes on ny 280 1st is 3d factory default 2nd is horizon then aux 2 is level as bailought .....when in horizon or level this thing is stable vor about 4 deconds tben does a crazy reverse dash on its own that cant even be detected by my dx18 and crashes why is this hapenig it flies dine in 3d mode..????? My 280 does not do this at all what the heck am i doing wrong... Even adjusted pid setings and also calibrate it on level ground do i need to mess with the trims in the softwear ir what ? Someone please help im lossing all patienys here my vell number even 3047197620 please email hyden.gruntusmc@gmail.com
