Go Back   HeliFreak > Multi Rotor Support > AerialFreaks Hyper 3D Quad Forum
AerialFreaks Hyper 3D Quad Forum Hyper 3D 400, Hyper 3D 280 Support
Old 03-09-2016, 04:25 PM   #1 (permalink)
Default Total newb needs help getting hyper 400 in the air please
got this used from a friend, had to replace all the tubes and props, now ready to try and figure out how to program radio..
I can put it on my old DX8 or on my new Gen2 DX7..what should I use?
The hyper has a dsmx satellite already soldered on, and I know to take it off and bind to one of my radios, I just do not know anything past that point..
What do you guys suggest?
I Am all ears!
Thank you for any help!
Birdie
Just hangin' in there tryin' to get past the n00b in newbie"..!
birdie_in_texas is offline        Reply With Quote Quick reply to this message
Old 03-09-2016, 10:05 PM   #2 (permalink)
HF MR Support
You'll be fine using your DX8. Set it up in 'Acro' mode.
3 years cancer free! Woot!! ~ Cancer can kiss my grits! Ainokea!
If you never crash, you're not having enough fun!
Pilot, Team Lavaquad
Big Island Guy is offline        Reply With Quote Quick reply to this message
Old 03-11-2016, 08:58 PM   #3 (permalink)
Yes, you will need to bind the satellite to your radio. Then you will need to download the Baseflight software, which is a google chrome app. Also, if you don't have the manual, download it from Aerial freaks website.
A micro USB cable is needed to connect the Naze32 board to your computer. Make sure you remove the props before you power it up and connect it to your computer. The motor can spin up during the setup process.
The Hyper 400 manual has step by step instructions on how to setup things up. Also, as the previous post says only setup the Acro mode in the mode selection tab of the software. This means only there should only be a checked box in the "Arm" row to the corresponding switch position. The angle and horizon modes are known to cause stability issues, which could lead to a crash. Some people have gotten them to work and others have not. The flight mode switch will be used to arm and disarm the quad.
On final note, there is a table listing the recommended end points in your transmitter. I would leave the elevator and aileron at 100/100 instead of the 120/120 until you test fly it. You can always change them later if you want to the quad to flip and roll faster.
guinness221 is offline        Reply With Quote Quick reply to this message
Old 03-29-2016, 12:37 AM   #4 (permalink)
You can bind the satellite via the naze32 via the command line interface. Type in: set spektrum_sat_ bind = 9 (or 5 for dsm2), then type in: save. Unplug board then plug back in, sat should be in bind mode, bind your tx to the sat. Go back to the CLI and type in: set spektrum_sat_bind = 0, then: save. Works in baseflight and cleanflight.
I do suggest setting up a "throttle hold" switch like on a heli via mixing in the TX on the flight mode channel. It is double safety and can help save some of the props in the event of a crash since the motors do not stop spinning when armed.
Brute71 is offline        Reply With Quote Quick reply to this message
Old 05-06-2016, 01:27 PM   #5 (permalink)
Hi,
Do you mind expanding in the mixing? Do i simply mix the FM channel 100% to my throttle hold switch channel?
Nano QX, QX 3D, Nano CPX (HH BL), MCPX BL (Fully MH), 180cfx, Hyper 400 3D, DX8, RF7
ThatVWguy is offline        Reply With Quote Quick reply to this message
Old 05-08-2016, 02:09 AM   #6 (permalink)
Mix your TH switch -100% to the FM channel, you can verify the function of it in baseflight or cleanflight
Old 05-17-2016, 10:44 AM   #7 (permalink)
Thanks!
