Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 06-19-2017, 10:08 PM   #1 (permalink)
Default How do you fuel your gasser
I'm curious how folks fuel their gassers. Do you use a T in the fuel line from the tank to the carb and fuel from the T capping it after fueling or is there some other method. Also do you run a fuel line from the tank vent or leave the vent with no line attached to it.
luckyflyer is offline        Reply With Quote Quick reply to this message
Old 06-19-2017, 10:57 PM   #2 (permalink)
Through the gas cap, just like a weed whacker
2x JR GSR260Z Flybarless
Classic X-Cell 60
HAL9KPCM is offline        Reply With Quote Quick reply to this message
Old 06-19-2017, 11:01 PM   #3 (permalink)
Ha, that's great except the Whiplash does not have a gas cap. maybe it should.
Old 06-20-2017, 12:23 AM   #4 (permalink)
Hi, have a look in the "Gas Powered Thoughts" forum thru some of the build threads. It should give you an idea of what is commonly done.
You definitely need a hose connected to the vent. See some of the build threads for the coils etc.
Dawiev is offline        Reply With Quote Quick reply to this message
Old 06-20-2017, 06:01 AM   #5 (permalink)
Tees and inline filters, etc are just opportunities for leaks.
I pull the return line from the carb to fuel. Lots of guys do.
MA Whiplash Gas v2 | HelixHeli T700 Gas conversion | G500 Raw | Trex 450 Sport FBL | OMP M1
Futaba, Bavarian Demon, Hanson Engines| DIY Lithium field battery
jharkin is offline        Reply With Quote Quick reply to this message
Old 06-20-2017, 08:06 AM   #6 (permalink)
Default 1 way in 1 way out
Pull the return line to fuel it all day long.
At the end of the day pull the carb line, push the primer bulb until the carb is empty, and drain the tank from the inlet line to the carb.
No T's or extra fuel/defuel line.
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote Quick reply to this message
Old 06-20-2017, 08:37 AM   #7 (permalink)
So then the return line will require a hole be cut on the tank and a fuel line fitting installed, Raja I went back and looked at your v2 build photos but I could not see clearly where you cut the hole for the return line fitting, on the tank top would be my guess. Also what fuel line barb do you use, I know leaks are a possibility. Also would like to know how you route your vent line. Sorry for so many Q's but would like to get it right the first time.
Old 06-20-2017, 09:00 AM   #8 (permalink)
The whiplash fuel tank comes from the factory with the proper fittings for a 3 line setup (carb, return, vent). The MA build manual shows a typical layout:
Old 06-20-2017, 09:06 AM   #9 (permalink)
Ok, thanks I did not remember the molded vent tube. I'm at work and not where the tank is.
Old 06-20-2017, 09:19 AM   #10 (permalink)
Default Here is mine
You can see here how I routed the lines. Make sure you use the top built in nipple as the RETURN line not the vent line. The vent line is the one that gets drilled into the tank and goes straight down.
-=>Raja.
ID:	712281   Click image for larger version
ID:	712282   Click image for larger version
Old 06-20-2017, 09:24 AM   #11 (permalink)
Thanks, The pictures answer all questions.
Old 06-20-2017, 10:02 PM   #12 (permalink)
Default Mines a bit different but OLD
Have absolutely Zero Issue's with Drip's - Run's - Leaks or Air Bubbles -none
Nor do I remove and replace any line to fill and unfill - or drain the system. It is hermetically sealed -
I can easily get a Full Fill - and a Complete Drain. without drip's leaks or run's
Can even do it with out a Fuel Pump using the Gravity method.
Bottom line is my fill and drain. Yes they did make Blue Tygon
Name:	3way mount.jpg
GREYEAGLE is offline        Reply With Quote Quick reply to this message
Old 06-22-2017, 08:11 PM   #13 (permalink)
same here.
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
