Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Raptor G4/E720
Raptor G4/E720 Thunder Tiger Raptor G4/E720 Helicopters
Old 04-27-2014, 07:42 PM   #1 (permalink)
Default Elevator servo failure
I have had two elevator servos fail in the past week. First one was a torq 9180 that was 4 flights old on my g4. Stripped a pressed in gear. Second was a rjx HV on my e700 and the servo motor locked up. I have read about the elevator servo mount breaking. Is there a design problem or is it just coincidence?
squeely531 is offline        Reply With Quote Quick reply to this message
Old 04-27-2014, 09:09 PM   #2 (permalink)
I am running RJX servos on my e700 with no problems. Is it possible that you are accidentally inputting the wrong frequencies for those particular servos?
TT e700, Titan x50f, Trex 450 Pro ,MCPX BL,MQX
pbpro954 is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 06:54 PM   #3 (permalink)
I already had about 100 flights so I don't think the setup was wrong but I will double check when I rebuild. I was also going to make sure I don't tighten the servo until after I mount the servo horns. Not sure if I put them into a bind causing premature failure? Servos were quiet when on the bench but who knows when under load.
Old 05-26-2014, 04:22 PM   #4 (permalink)
It happened again. anybody else have elevator servo problems? My torq 9180 failed in flight. This time it cost me a couple hundy. These servos are only 15 flights old.
Old 05-26-2014, 09:25 PM   #5 (permalink)
Just a long shot but maybe check the wiring. Being the elevator servo, you will have an extension wire. Check for any cuts or shorts in the wiring. Maybe it is sending the servo into a spasm and locking it up or over driving it.
Never had this problem with hundred of flights on both G4 and E700.
sent from..............
borntofly is offline        Reply With Quote Quick reply to this message
Old 05-26-2014, 09:26 PM   #6 (permalink)
What FBL system?
Old 05-26-2014, 10:27 PM   #7 (permalink)
There's advice going around that you should mount the servos loosely, until you get the push-pull put together, so they're not under stress. It could be that the "natural" mounting for the elevator servo requires you to force the system together and put on strain.
Tighten before locking the servo collar to square, of course.
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 05-26-2014, 11:05 PM   #8 (permalink)
Using bx. I made sure I left everything loose until setup menu G. The servo failed in the same way. One of the smaller pressed gears slipped inside the larger gear. This servo is new. I don't have an extension and the wire is covered with braid. I will double check everything tomorrow.
Old 05-26-2014, 11:07 PM   #9 (permalink)
Anybody using the torq 9180?
Old 05-26-2014, 11:08 PM   #10 (permalink)
I am also using FB blades. Could that be the cause? Thanks again for any input.
Old 05-26-2014, 11:38 PM   #11 (permalink)
I'm using torq 9180 in my raptor g4 hundreds of flights no issues and a Futaba 255 on my e700 no issues
Tried alot blades with the g4 fb fbl fai 690-720
VControl, Vbar Neo, Scorpion power systems, Optiguard, BK servos, Mikado Logo 700
Phil777 is offline        Reply With Quote Quick reply to this message
Old 05-26-2014, 11:40 PM   #12 (permalink)
Suggest u take a picture of how u had it installed
Old 05-27-2014, 12:00 AM   #13 (permalink)
The push pull design has very minimal stress on the servo. No where near the amount of a direct to swash design. The design has nothing to do with it.
There is sometging else not right.
Old 05-27-2014, 07:00 AM   #14 (permalink)
I have the servo torn down for repairs but when I put it back together I will post pics. Nick Maxwell will be in town this weekend so I will see if he can give me any insight. Thanks again.
Old 06-27-2015, 09:01 PM   #15 (permalink)
I know this thread is old but wondering if OP found out why his servo stripped the gear. I noticed mine had a touch of play on my G700. Didn't think much of it but its costing me a few hundred in repairs right now. If the rest are prone to failure I'll just get rid of them. thanks for any help.
SAB Kraken 580 N, Tiporare, Carbon Z foamy Plank, Sig Kobra, GP Stearman, JR 11X, Vcontrol classic
faceman425 is offline        Reply With Quote Quick reply to this message
Old 07-12-2015, 11:08 AM   #16 (permalink)
I never found the cause but I think it may be related to the way I had the BX set up. There are two 140* settings and I was using the wrong one. User error on my part.
