TREX 700E powered by Hacker A50-14L & 10S 5800mah? - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Electric Conversions
700 Electric Conversions Align T-REX 700 Electric Conversions
Old 08-14-2010, 09:50 PM   #1 (permalink)
Default TREX 700E powered by Hacker A50-14L & 10S 5800mah?
Hello everyone, really tempted to convert a trex 700 to electric and power it with my existing Hacker A50-14L and unused 10s (2 x 5S) 5800mah blue Turnigy packs, would really help making it affordable, could this combination work as a (first) power system?
Would it be sufficient for graceful intermediate 3D flying?
Could I then move to 12S with the same motor?
Apologies for all the questions
Thanks ever so much everyone, hope to be joining you in the trex 700 forum(s) soon
threedee is offline        Reply With Quote
Old 10-04-2010, 11:19 PM   #2 (permalink)
Where did all my replies go?
Was just wondering if this motor could be used with the 10s 5800mah packs and kontronic 55A 10S Jazz for a super low headspeed 700 (~1000rpm-1200rpm) now I have the 700N for 3D? Would be fun to fly around scale and smooth before getting a scorpion motor and 12S next spring
Like this:
[ame]http://www.youtube.com/watch?v=yntueog1KYU[/ame]
Thanks fellas
Old 10-06-2010, 10:20 PM   #3 (permalink)
i'd fall asleep at the sticks flying that machine
Blade 130x. Gaui X5 Forumla
I'm Back Snitches!!!!
maxxteezy is offline        Reply With Quote
Old 10-07-2010, 02:44 AM   #4 (permalink)
I think it would take more skill to 3D with such a low headspeed, be more of a challenge, looks like fun
Would the setup work? (even if you wouldn't enjoy flying it)
Edit: Did you watch all the way through? Starts off boring but gets good after 1:40
Old 10-07-2010, 12:44 PM   #5 (permalink)
That's a 540KV motor right? If so you should be able to use it. It would be a down on power compared to a Scorpion or Kontronik but it should work fine. I believe you could run that motor on 10S or 12S depending upon the pinion and head speed you want to read. I just put a Kontronik Pyro 700-45 in my 700 E conversion so I have a Scorpion 4035 560 laying around if you don't want to buy a new one let me know. It would provide quite a bit more power (4200w vs 3000w) but the hacker should work OK if you don't need a ton of power. Maybe someone here has actual experience with this motor in a 700?
Mr Nice Guy is offline        Reply With Quote
Old 12-29-2011, 03:56 PM   #6 (permalink)
Smile
i'm currently considering that Hacker motor to convert a gasser. I am mainly concerned with duration and also a lower than typical headspeed. ....720mm at 1650RPM or 800mm at 1450RPM.
Very nice flying! I like the more scale rotor speed and the blade sound at that RPM is great.
Oracle is offline        Reply With Quote
Copyright © VerticalScope Inc. All rights reserved.
