Old 12-28-2012, 06:05 AM   #41 (permalink)
Ralph, just got a 4530 returned from Scorpion and it had the new shape fan and also a different stator to my older 4530LE. Scorpion is really on the ball with development.
VControl
Old hand at Planks
Peter
Old 12-28-2012, 06:21 AM   #42 (permalink)
Very interesting stuff Ralph, hopefully over time these improvements will come through in production motors.
Scorpion indeed makes changes to their motors over time, I like that.
Reading your remark on the fan shape, I compared my own 4530 to the new 4525 rotor and indeed there is a difference: the holes in the 4525 rotor are wider.
I also really love the flexibility of Scorpion, look what they did on the 4525 kit they sent me
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16
_Dekker is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 06:24 AM   #43 (permalink)
so you got a special "signature" edition.
the last (and best) fan variation (only prototype) has 8 holes now.
and the main differennce you only can see from the inner side.
powercroco is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 02:30 AM   #44 (permalink)
Default HK-4525 5+7-YY 1.5mm 495Kv
5+7 turns in 1.5mm.
This is the same number of turns as in post #39, but now with 1.5 in stead of 1.4mm wire.
For comparison:
12 turns 1.4mm: 18.4mm^2 copper surface
12 turns 1.5mm: 21.2mm^2 copper surface. Measures 9.3mOhm for YY.
Servo wire visible at the back is the Futaba telemetry temp sensor cable, the (stripped) sensor is epoxied on the windings.
Both motors are going to the same person setting up two Raptor G4 E720's, we are looking forward to comparing them.
Old 03-13-2013, 09:10 AM   #45 (permalink)
Originally Posted by _Dekker View Post
5+7 turns in 1.5mm.
For comparison:
Hey Bert,
is your guy able to log some data? Would be interesting to see the difference in those two windings.
Can you feed the data into DC?
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 12:40 PM   #46 (permalink)
I am using a IISI-RC telemetry and data logging system, so I'm definatly able to provide data on both motors.
The 1.4mm wind motor is already really powerfull, but still I'm interested to see what differences I will notice. So far I'm not sure if I'll use 2 different ESC's or not though, maybe that will make a big difference too.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 09:06 PM   #47 (permalink)
Thanks Laurens,
would be nice to have the data for the second motor with the same ESC . . .
But I don't want to be pushy.
Old 03-14-2013, 05:37 AM   #48 (permalink)
I can always swap them in a later stage. Should be interesting, but first I need a lot of data from the ESC thats powering them in the first couple of weeks.
Logo 800/Jeti DS16
Old 03-22-2013, 05:19 AM   #49 (permalink)
Finished.
Meanwhile I also started doing back-EMF measurements to see what the differences are between motors, before and after rewind. This is for this rewound 4525:
Old 03-22-2013, 11:42 AM   #50 (permalink)
Dekker
interested in learn more on how and what your using to measure the back EMF.
I take it your using some sort of scope . what model / make is your scope and is it cheap ?
Finished.
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
HeliFX is offline        Reply With Quote Quick reply to this message
Old 03-23-2013, 04:18 AM   #51 (permalink)
Originally Posted by HeliFX View Post
Dekker
I'm also still in the learning process, reading into this subject more.
Yes it's an oscilloscope, in this case a digital storage one from Tektronix. You can also use older analog scopes, these are a lot cheaper to get and measure just fine.
Old 03-24-2013, 09:45 AM   #52 (permalink)
dekker that one expensive piece of equipment you have there unless you bought it used
I've done some general reading on the subject and yes still learning.
Old 04-09-2013, 02:55 AM   #53 (permalink)
Based on the n spec of the rewind: the original motor (5+6yy) must have 545rpm/V in stead of the advertised 520..
I just measured the kv of a brand new out of box 4525 ultimate and found a kv of 555rpm/volt with 22.5V and 18degree timing on yge.
Perhaps scorpion measures their kv on 5 degree timing.
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 04-09-2013, 08:00 AM   #54 (permalink)
Yeah, they quote mostly data for 5 degr. timing.
Old 04-09-2013, 08:30 AM   #55 (permalink)
Default Re: My 4525 rewinding project
The 5deg of scorpion should be much closer to YGE 18deg.
The higher Kv's that we measure is to me an indication of a lower quality motor: something in the magnetic design got worse, magnets, iron, stator, who knows.
Just like the first P800's that also measured too high Kv's and now are just about spot on.
Old 04-09-2013, 09:10 AM   #56 (permalink)
Yeah, could be.
Also not uniformly glued magnets can change the air gap, resulting in Kv variations from the stated ones.
I'd like to see more uniformity of the test equipment in the future.
I don't mind checking Kv of supplied motors with two different ESCs, but it is all time consuming. If the manufacturers would supply us with some more equipment data, we would be better off.
There will always be some minor variations in the 5 or 10 RpM range, but not 30+ like now.
Old 04-09-2013, 10:49 AM   #57 (permalink)
higher timing will produce higher Kv value between 10 to 20 kv. ESC model and type also has an influence.
Powercroco has posted a chart of test he did when scorpion first started producing rewind motors. the three esc used was the YGE, JIVE and Scorpion each produced different Kv with a given timing.
scorpion does not mention which esc they used for there testing. I suspect its a custom test bed for workers to quickly test each new motor.
besides all motors should be tested at its base low value and limit the number of influencing variables that can shift the Kv.
Old 05-24-2013, 05:34 AM   #58 (permalink)
Default Stock 4525 ultimate- 520Kv rewind
Got to rewind a stock 4525-520Kv Ultimate (YY termination).
This one has burnt windings in one phase, it seems this is something that can happen at random with the Scorpion 130A esc. Even though the windings looked like this, the owner had about 15 flights with it before he understood it's probably wise to do a rewind
The reason it still worked: All phases still measured 10mOhm and the motor still passed the 500V isolation test. 1000V isolation test was bad.
The original wind has no room for airflow and is soaked with epoxy.
Rewind was done with the same (1.4mm) wire and number (11) of turns. So it was nice to see how tight I could get it compared to the stock wind. We have airflow now:
Back:
Indeed as I suspected these 520 Ultimate motors have higher Kv than listed: I measured 549rpm/V (YGE 18deg setting)
Old 05-24-2013, 09:21 AM   #59 (permalink)
Dekker, was it hard to remove the carrier? Was there a thin FG plate under the screw holes? Locktite or epoxy on this one? I would love to do mine just for the sake of opening up the slots for cooling. Mine has the same problem with epoxy all over the place and it gets quite very hot
belcom is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 03:31 PM   #60 (permalink)
No not harder than any other Scorpion. Yes there is a thin fg plate. I used epoxy on this one.
Tags
stator repair 4525
