KDS Agile 7.2 KDS Agile 7.2 Discussion |
10-25-2016, 06:55 AM | #1 (permalink) |
Hobbywing Platinum Pro 120A HV-Opto for 7.2?
Hi,
I already have the above ESC and wonder if I can use it with the Agile 7.2 which I plan to order (there is a good sale going on). I only sport fly and no 3D at all, not even invert. Would this be ok or should I get a 160 A ESC instead ? Thank you. |
10-25-2016, 06:25 PM | #2 (permalink) |
For just sport flying the 120 should be fine. When you start to push things a little you need the 160. A good POWER loop may challenge the 120.
Paul Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD |
10-26-2016, 02:04 AM | #3 (permalink) |
Thanks Paul. Just a little curious, when you say 'A good Power loop my challenge the 120' could you pls. elaborate? I just want to make sure I understand the drawback of using this ESC with Agile 7.2 thoroughly. Hate to buy anothe ESC if this one will do for my style of flying. Thank you.
10-26-2016, 06:36 AM | #4 (permalink) |
I used to fly my agile 7.2 with a 120A YEP and it coped fine. This included sports aerobatics like big loops etc. and some sloppy rainbows etc. but no true 3D
Gob 700 BT 'T' | SoXos Strike 7.1 | Henseleit TDR, TDF, TDSF & TDR2 | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk |
10-26-2016, 09:35 AM | #5 (permalink) |
Except for poor internal gov, the esc is robust. I have no doubts to use it on a 700 size and do some light 3d.
Nothing smaller than 700 ..... |
10-26-2016, 06:23 PM | #6 (permalink) |
Coming out of a big loop with a lot of speed can be some of the highest and most sustained amp draw an ESC can experience.
10-27-2016, 12:02 AM | #7 (permalink) |
Thanks guys, that was sufficient for me to make up my mind to use this ESC instead of getting a higher spec one as I fly fairly tamely. In fact, I fly with Naza H FBL controller so it's pretty much slow circuit flying.
