Old 03-10-2017, 03:36 PM   #1 (permalink)
Default Kontronik News March
Ck out Kontroniks New Lv Esc line up, http://www.kontronik.com/en/news.html
Magneto is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 05:26 PM   #2 (permalink)
That's really cool that the TelMe is integrated.
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
jhamel is online now        Reply With Quote Quick reply to this message
Old 03-11-2017, 08:42 PM   #3 (permalink)
actually - integrated TelMe, up to 9V BEC and Kosmik governor.
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 01:56 PM   #4 (permalink)
So not all the parameters one would expect to get from the TelMe, especially the mah consumption?
Amain Team Pilot
Old 03-15-2017, 08:26 AM   #5 (permalink)
??? Why not mAh usage? I have a few TelMe running on my Kosmik ESC's and they deliver mAh. I simply fly based on that info. Compared to charging the batteries the numbers are very close. So I am not sure why the TelMe on the new units should not have the info.
Old 03-15-2017, 08:51 AM   #6 (permalink)
Not sure where that came from. On K's site it just says that Tellme functionality is integrated.
A\ziz - Citizen 672
Minicopter Diabolo 700 Black, SAB Kraken 700, Kraken 580, Minicopter Diabolo 600, Minicopter Diabolo 550, Henseleit TDR Mark II, Henseleit TDR
Jeti DS24 / VControl Touch
aziz76 is offline        Reply With Quote Quick reply to this message
Old 03-15-2017, 10:10 AM   #7 (permalink)
I just misunderstood the "...up to 9V BEC and Kosmik governor..." comment as meaning that the integrated TelMe function in the new Kontronik ESCs would be limited to BEC voltage and RPM. So if I understand you correctly, the integrated TelMe would give all the parameters expected from a stand alone TelMe. If that's the case, that would be great. No need to purchase a separate $85.00 TelMe. I assume the integrated TelMe would be compatible with all radio systems by just selecting the appropriate "box" in the K-Konfig?
Amain Team Pilot
Old 03-15-2017, 12:43 PM   #8 (permalink)
Yes - thats what it says.
Old 03-15-2017, 07:19 PM   #9 (permalink)
With the existing TelMe units there's a different one for each receiver/FBL brand. Just wondering how one ESC with integrated TelMe is going to work with all the different receiver/FBL brands. To be honest I never understood why they needed so many different TelMe units when the difference was probably only firmware and connectors.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 03-15-2017, 11:22 PM   #10 (permalink)
good question - I am not overly concerned. On SW you normally should be able to choose the option what output protocol you want. It maybe interesting to see how its done
Old 03-16-2017, 08:57 AM   #11 (permalink)
On the Telme I suspect the microcontroller used doesn't enough memory to support all possible protocols at once. Sure, you could add add USB in order to flash a new firmware, but that would increase size, complexity, and cost. There might also be some hardware differences due to different voltage signaling levels across the different hardware interfaces.
Ace Dude is online now        Reply With Quote Quick reply to this message
Old 03-16-2017, 09:24 AM   #12 (permalink)
Surely you'd just connect to USB via a ProgDisc or ProgUnit like you would any of their other products. I'd say producing, packaging and distributing multiple different units is more costly.
Old 03-16-2017, 09:49 AM   #13 (permalink)
Requiring ProgUnit/ProgDisc is another external dependency. Additional cost for multiple units exists, but seems limited to packaging.
One issue nearly always overlooked is support costs. Having dedicated devices with zero options significantly reduces support costs.
I'm not saying it's the right or wrong approach. These are architectural decisions every development team faces. Just stating whey they may have done what they did.
Old 03-16-2017, 09:58 AM   #14 (permalink)
Yeah good point. I took it for granted because I have a ProgDisc but others might not.
Old 03-16-2017, 11:31 AM   #15 (permalink)
I guess I'm torn, I like the idea of having a universal device that would work with multiple systems and I also like the simplicity of a true plug and play device.
Old 03-22-2017, 08:46 AM   #16 (permalink)
Any news on price and ETA? I would like to give the 120LV a try
Old 03-06-2018, 03:27 PM   #17 (permalink)
... and then, 1 year later... still no signs of Kolibri in the air?!
Logo600SX-Logo600SE-Logo700-VBarControl-Neo
STAZZ is offline        Reply With Quote Quick reply to this message
Old 03-08-2018, 07:46 PM   #18 (permalink)
Latest news on it is from January 26th 2018:
In 2017 we announced the KOLIBRI series for summer / autumn 2017. But during our tests and validations we found some details, that we wanted to optimize before going to market. Despite the announcement, it is most important for us to provide a carefully tested product that meets our own expectations – even if it takes longer than planned. We are now again testing and validating the ESCs and therefore we do not yet want to make any new announcement. But please be sure, that we are working on it with high pressure!
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Drake & Raw, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro
