Like Tree1Likes
Old 05-27-2017, 09:51 AM   #21 (permalink)
Hello,
I`m redoing the setup and whiule checking my transmitter I noticed somethinmg. I forgot which swash setting I had to use? Both my 450 and 500 heli are set to 90. Shouldn`t this be 120?
Shomey is offline        Reply With Quote Quick reply to this message
Old 05-27-2017, 09:05 PM   #22 (permalink)
Since you are using FBL, the transmitter should be set to 90. The mixing is done in the FBL.
You will have to choose 120 in the FBL software, though.
Oxy 2, Gaui X3 #1, Protos 380, Gaui X5, Synergy 766, Specter 700
Oxy 2/X3/Protos 380/X5/766/Specter 700 Consecutive Successful Flights (Current) = 32/16/12/145/7/50
Consecutive Successful Flights (Max) = 145
macdad is offline        Reply With Quote Quick reply to this message
Old 05-31-2017, 05:18 AM   #23 (permalink)
Originally Posted by macdad View Post
Ultimately, leading or trailing edge shouldn't matter on you heli, as long as your fbl is setup properly. My suggestion is to go through the entire setup every time you rebuild. Just in case. Doesn't take too long.
+1
Sensor direction would be most likely (how it is mounted) since it turns the other way if you apply rudder to counter the spin...
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV)
Lynx Team Pilot / Oxy Field Rep
Livan75 is offline        Reply With Quote Quick reply to this message
Old 06-02-2017, 10:47 AM   #24 (permalink)
Originally Posted by Livan75 View Post
+1
Yes, but given the order of operations if you flip your grips after you setup ( crash rebuild ) withoiut complete setup you will have a spin, after you try to mess with all the reversals or ect. ect. to make the tail "look" like it is going the right waty.
....... Arf! ARf! ARFFFArFARFF! Arf. ......
Align 550e & (Got me some more canopy nutz, Jack.) Gaui X7 filled to the brim (still uncrashed)... (broke 17,830w w/90$, homemade recycled battery from the junkyard... )
Dogdipstick is offline        Reply With Quote Quick reply to this message
Old 03-06-2020, 09:44 AM   #25 (permalink)
Yes you said that the tail grip control arm should be on the leading edge of rubber and not the trailing edge. Then how has my heli with the kbar be flying great until I crashed again now it won't hold heading
Ronald Headrick is offline        Reply With Quote Quick reply to this message
Old 05-26-2020, 08:01 AM   #26 (permalink)
If you have a belt driven tail.
Check that you not have reversed the tail rotor by putting on the belt wrong.
I did this once and it causes a very heavy tail drift and when you are not quick enough or surface it not equal a crash.
First is looks ok, but when it ramps up a heavy spin to the left (boom to right)..
ppheijnen is offline        Reply With Quote Quick reply to this message
