03-07-2017, 12:51 PM | #61 (permalink) | ||
Smoooooooth 3D - 1800RPM Fun
This machine is soo versatile! I've been able to log 5-6 minutes of flight at 1800rpm on 12s 5000 Optipower packs. Hope you enjoy!
Representing: AMain Hobbies, XNova Motors |
03-07-2017, 04:10 PM | #62 (permalink) |
@Jason Bell nice flight...
Just order my first logo was beetwin another Diabolo 700 BE or the logo 700, decided the logo for a change.. what is you pitch and aileron º? and HS..
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP Jeti DS-14 Edition Last edited by Grittner; 03-15-2017 at 07:36 PM.. |
03-08-2017, 11:22 AM | #63 (permalink) | |
Headspeeds: 1800, 2060, 2140. I mostly fly in 2060 however.
03-08-2017, 11:46 AM | #64 (permalink) |
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP Jeti DS-14 Edition |
05-09-2017, 08:04 PM | #65 (permalink) | |
TREX 700XN 👍🏼 / TREX600n FL HEAD\ Logo 550sx 2017\XL POWER SPECTER 700\TREX 470\Vbar NEO/VBAR CONTROL👌🏼😎Citizen 789😎 DX6I RF 7.5 ( BLADE 130s oh yeah!!) () |
06-11-2017, 06:51 PM | #66 (permalink) |
just join the club recently, great machine !
Here's my setup Motor: Xnova 4525-530 ESC: Hobbywing 160A HV BEC: Hw internal bec Servos: Bk7001/7006 FBL System: Mini vbar Pro Receiver: Futaba Rotor Blades: VTX 717 Batteries: Revo 5200 Backup Guard: Optiguard Pinion: 13 Headspeed looking at:1700/1800/1950 Weight: w/o batteries and battery tray - 3.84kg |
06-13-2017, 04:28 PM | #67 (permalink) | |
Did you ever change over to the Tribunus? Just curious. If so, did you do the mod to glue the capacitors, or have you found that to be a real issue?
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550 Amain Hobbies Team Rep |
06-16-2017, 12:56 PM | #68 (permalink) | |
My caps are loose, and I plan to hot glue them. I'm not sure if it's really an issue with the ESC, but I like playing things safe.
06-18-2017, 08:59 AM | #69 (permalink) |
Motor: Scorpion 4525-520
ESC: Castle HV 120 Bec: Castle v2 Servos: BK DS-7002HV and BK bls-8005HV FBL System: New Brain 2 Reciever: Spectrum Rotor Blades: VTX 717 Batteries: Pulse 5000 Pinion: 13T Head Speed: 1800,1900 and 2000 6 to 6 1/2 min. Flights Weight with batteries 12lbs
It's not the destination, Its the journey Align 550e |
08-29-2017, 04:43 AM | #70 (permalink) |
Mine came out at 11.4 (5.1kg) with the following setup:
Koni Pyro 700/52 (custom shaft) Koni HeliJive 120HV v13 R2 Buffer 3x 50F NEO NEO UI sensor NEO battery ID reader JR MPH83's all round VTX697s Funkey 105s Revo 12s 4400s NEO gov @ 1900 and 12degrees Flys nicely on the 697s with that setup. M
Regards, Mark R (#248) TRex 700E V-Bar NEO, BLS251, DS8915's, HJive120, JLog, VControl Carbon TDR 710 CYs, V-Bar NEO, MPH83s, Jive 120, JLog, R2 Buffer, VControl Carbon Logo600SX 600 CYs, V-Bar NEO, 8715s, Jive120, JLog, R2 Buffer, VControl Carbon |
11-19-2017, 09:54 PM | #71 (permalink) |
Waiting on Logo backorder delivery but here is my setup;
Motor: Pyro 750-50L2 ESC: Kosmik 160 w/ TelMe Mikado BEC/RX Pack: Internal BEC Servos: Xpert R2 FBL System: Vbar Neo w/ Rescue Rotor Blades: VTX 717 + Rotortech 105 Batteries: 12s 5000maH Back Up Batteries: R2 Buffer Pinion: 13T Headspeed: low headspeed (I will figure it out during first few flights)
Henseleit’s / Diabolo’s / Kontronik / VBCE |
05-24-2018, 03:00 AM | #72 (permalink) |
I see a few examples here and there, but just to be sure. Would a castle 120 (phoenix) be enough for the 717 blades?
Right now I'm running the castle and scorpion 4525-520 on my goblin 700 swinging rails 696 blades at 1900rpm. I would like to use this setup in the logo. Will the vtx blades increase the amps a lot? I don't do smack, so usually I have 120amp peaks on my goblin |
05-24-2018, 11:09 PM | #73 (permalink) | |
06-16-2018, 04:48 PM | #74 (permalink) |
I've just flown ~7 flights with the castle 120A. I do see peaks of 160A, and that is with my slow 3d: tic tocs, funnels, piroflips, no smack. These blades do draw a lot of amps
717 vtx blades, 1900 rpm I don't dare to push it really hard with this esc so i'm looking for an upgrade (thinking of the tribunus 200A, just to be safe) ah well, it was worth the try |
01-26-2022, 11:13 AM | #75 (permalink) |
My 700 had its first flight today
Motor - Scorpion 520kv ESC. Kontronik kolibri 140hv (internal bec) Cyclic servos - Align BL800 hv Tail servo - Futaba BLS 254 Edge 690 main blades (I didn’t want to use the 717s on first flight) Battery 2x Overlander 6s 4250mah 35c AUW - 5kg or 11.02 lbs Head Speed 1475 gave a nine minute flight 1750 much more fun but 7 minutes. I’m no great 3d flyer but this is a great flying heli, only disadvantage is the gear train is noisy compared to my 600SE also forward speed was not as high. Next flight will be fine tuning and will try the 717s. |
01-30-2022, 06:20 PM | #76 (permalink) |
The gears will get quieter takes 80 flights honestly. Put a little light grease on the gears too
08-14-2022, 05:29 PM | #77 (permalink) |
Motor: Scorpion 4526-520KV
ESC: Tribunus II 200A Servos: Xpert KD1 & KD1T FBL System: Vbar NEO Rotor Blades: RotorTech Ultimate 700 / 106U Batteries: ManiaX 6S 5000mAh (x2) Back Up : 1st 3X50F Buffer Gearing: 136 / 14 Headspeed: 1600/1800/2000
Alexander M1 & M2 EVO | M4-MULTISTAR | M4 MAX | M7 OMPHOBBY | SUNNYSKY | Xpert |
