Go Back   HeliFreak > R/C Helicopter Support > OXY HELI
OXY HELI OXY HELI Factory Support Forum
Old 04-24-2017, 06:48 AM   #61 (permalink)
Manual says: "if you are a beginner use 3s and 11t pinion!"???
Tgilf is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 06:55 AM   #62 (permalink)
Lol, that's a good one. I'll have to go back and check the manual. If you want lower headspeed on 3s, I would go with 13t.
Compass Atom 5.5; Oxy 2/3/4
XK K110 K120
Wargamer is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 07:02 AM   #63 (permalink)
Default Manual
Will it be to slow with 11t?Click image for larger version
Old 04-24-2017, 07:34 AM   #64 (permalink)
Originally Posted by Tgilf View Post
Will it be to slow with 11t?Attachment 704563
Very
Old 04-24-2017, 07:44 AM   #65 (permalink)
So should I go with the included 14t or is the 13t worth buying it?
Old 04-24-2017, 07:52 AM   #66 (permalink)
Pretty sure that even going with the 14t you can make the flying pretty sedate.
-Ben
Old 04-24-2017, 08:54 AM   #67 (permalink)
Default Us Ultra Tame Guys
Just for the record you can go with whatever combination of pinion and battery that meets your personal wants/desire/needs. Some folks like myself really enjoy flying a really tame Oxy. I use 3S batteries and a 10T pinion. I run a headspeed somewhere around 26-2700 and am very happy with my wimpy Oxy3. It flies fine for hovering, orientation work, patterns and other tame stuff. And if I ever feel the urge for more I can always change the pinion and/or use a bigger battery.
Helicopters do not fly. They beat the surrounding air into submission.
SCflyer is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 09:02 AM   #68 (permalink)
Thanks a lot. So maybe as a beginner like I am it's not worse with 11t for the first few flights
Old 04-24-2017, 11:08 AM   #69 (permalink)
I'd suggest aiming for 3600-3700 to start with. This is not manically fast nor slow enough to make the heli sluggish. With smaller heli's, HS provides stability. Its about hitting the 'Goldilocks Zone' somewhere in the middle.
Now: OXY3 || Buddy
Then: So Many
MinskUK is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 11:54 AM   #70 (permalink)
For the standard 255 kit on 3s, the optimal range with 14t is 3000 to 4000. With 13t you can drop that by a few hundred RPMs. 11t will mean you are flying 3000 and under.
With both 13t and 14t you can run lower HS than the ideal range above; it will just mean dropping your throttle setting. With 11t, you are up against stability, and really won't be able to fly much below 2500.
As a relatively new pilot, I would not suggest starting any lower than 3000 for your first flights, and certainly no reason to start higher than the 3600 suggested by Minsk. You should be fine anywhere in there, and can adjust to suit your tastes.
XK K110 K120
Old 04-24-2017, 12:24 PM   #71 (permalink)
Thanks so much for all your help! So good to have you on my side while building this thing..
unfortunately it takes so long for me because I only find a few minutes in the evening to progress
Old 04-24-2017, 12:49 PM   #72 (permalink)
If there is one thing that helps in this hobby, it's patience. There is no right speed for building or learning. Whatever works for you is good.
Keep coming back with questions as you have them. Someone will always be here to help.
XK K110 K120
Old 04-24-2017, 10:26 PM   #73 (permalink)
+1 for patience. If there is any one best piece of advice, it would be to be slow and methodical...basically patient. Read EVERY word of the manual, there are many important things that are easily missed when skipping a few words in the manual.
I'm sorry for the obvious advice, but I'm sure we're all guilty of this.
Helyfreak is offline        Reply With Quote Quick reply to this message
Old 04-25-2017, 01:59 AM   #74 (permalink)
That's true. As patience is not my strength maybe this hobby gets me trained a being more patient :-)
So right now a have everything ordered except FBL - looking for the brain 2 but at 160€ it's quite pricey. Do I need the brain 2 or would the mini brain be equally good?
Old 04-25-2017, 03:32 AM   #75 (permalink)
Mini will work as well. Just don't get the micro.
Sent from my SM-N910T3 using Tapatalk
Old 04-25-2017, 03:52 AM   #76 (permalink)
Could get a v1 brain with Bluetooth module used condition for 95€ good deal?
Old 04-25-2017, 04:20 AM   #77 (permalink)
Sure, but personally I would want all the features offered in the Brain 2/ Ikon 2.
Old 04-25-2017, 04:30 AM   #78 (permalink)
Is it worth the price? As far as I read - it is only processing power nothing special or am I wrong?
Old 04-25-2017, 04:43 AM   #79 (permalink)
First off, buying a FBL used is always risky. Assuming it was okay, the Brain 2/Ikon 2 will give you vibration analysis and diagnostic logging. May be tools you aren't familiar with now, but as your knowledge of things increases these will be things good to have. I use them on a regular basis.
-Ben
Old 04-25-2017, 04:55 AM   #80 (permalink)
Risky because it could have been crashed?
So you would recommend buying a new mini brain 2?
