Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Like Tree2Likes
Old 06-08-2017, 11:40 AM   #41 (permalink)
I can do a Graupner MZ-24 Pro telemetry setup video.
HeliFreak Support
Graupner MZ-32
Old 06-08-2017, 02:46 PM   #42 (permalink)
Originally Posted by vultage View Post
anyone know where one would find the said, 1/4w - 10k ohm resistor, needed to hook up CC esc?
I found that on ebay I had to buy a packet of 200, but they are dirt cheap to be fair. I went to our local electronics store, had to buy a pack of 8 and cost me $4.
Bob1 6s with Spirit Pro.
Bob 2 with Spirit Pro.
Bob 3 waiting on Spirit Pro.
Jeti DS-16. Whovian.
Necroscope is offline        Reply With Quote Quick reply to this message
Old 10-13-2017, 09:45 PM   #43 (permalink)
I’m close to finalizing my first telemetry setup, super excited! My question is whether or not I can use a Castle link quick connect device after the ESC and before it goes into the pull up resistor cable assembly per the manual. So for my setup, it would look like ESC -> Castle link quick connect -> pull up resistor cable assembly -> CH1 of the Brain2.
Thanks,
Jay
syn90 is offline        Reply With Quote Quick reply to this message
Old 10-13-2017, 10:34 PM   #44 (permalink)
Thanks,
Jay
If Iam reading this correctly, you want a connector spliced into the speed controller cable so you can connect the speed controller and make changes without having to disconnect anything, correct?
If so , then I have done similar with my Hobbywing ESC so I can update firmware or make changes without unplugging the ESC and it works fine. I haven't done it on my Castle ESc but I can't see why it would be any different.
Old 10-14-2017, 12:27 AM   #45 (permalink)
Thanks,
Jay
https://www.helifreak.com/showthread...=2#post7468040
Dawiev is offline        Reply With Quote Quick reply to this message
Old 10-14-2017, 06:42 AM   #46 (permalink)
Great, thanks for the responses guys, looks like its been done this way by others with succes.
Old 01-25-2018, 03:02 PM   #47 (permalink)
Need some help....got this setup with my Icon2 BT and RCE BL80A. Running single wire from signal at esc to middle of 456. Dx9 is auto configured. How can I verify esc is sending info..... inside my house as its raining out.
Onespeedonly is offline        Reply With Quote Quick reply to this message
Old 01-22-2019, 03:15 AM   #48 (permalink)
Hobbywing instructions and drawings for their opto esc's aren't the best.
I'm pretty sure this would end badly.... or at least simply wouldn't work.
I got it all working by 1x telemetry signal wire from scm to 5 of 456 port and all 3 wires from esc to governor port... although I think the red wouldn't do anything.
James Recard is offline        Reply With Quote Quick reply to this message
Old 10-10-2019, 09:50 AM   #49 (permalink)
Yeah whatever you, never ever apply power to port 456!
Thickfog is offline        Reply With Quote Quick reply to this message
Old 04-08-2020, 12:30 PM   #50 (permalink)
Default 0 value for mah consumed
I have telemetry reading for VFAS working but even after a flight the mah consumed is still 0. I am not using the Brain 2 governor. Is the rpm sensor from the HobbyWing esc required to be connected to the Brain 2 in order to determine mah used? Any other ideas?
jctpro is offline        Reply With Quote Quick reply to this message
Old 04-08-2020, 05:20 PM   #51 (permalink)
I don't know if it's necessary but I joined the second Rx power with the yellow for gov and plug into the gov port. For the signal from the esc I juste take a servo wire with only one wire from signal of the esc to port 5 in the ikon. I juste move my wire to center for port 5. I also use the the spm4649t Receiver telemetry into port 3. In the ikon you need to select the proper esc telemetry you use and in the diagnosic select what you want. The only thing you need in the transmitter is put 10. In the ratio for rpm and esc. Hope this help
Lynx Heli Innovations Field Rep
OXY 4 Neo
Logo 200 Logo 550 Neo-VControl Touch
Pilot rc Laser 88, mikado V-plane, DA-70-MKS hv777
jean-michael is offline        Reply With Quote Quick reply to this message
Old 09-27-2020, 09:59 PM   #52 (permalink)
What happened to the Jeti Telemetry Video?
Link is broke, and can’t find it on YouTube.
dkpodder likes this.
SAB / Jeti / Spirit / Xnova / YGE / Pulse LiPo
wkderf is offline        Reply With Quote Quick reply to this message
Old 01-11-2022, 11:57 PM   #53 (permalink)
Does anyone have the brain2 with jeti video working link?
brianr058 is offline        Reply With Quote Quick reply to this message
