External discharge resistor ? - HeliFreak
Like Tree2Likes
Old 01-01-2016, 11:58 AM   #1 (permalink)
Default External discharge resistor ?
There is a main page thread about quick discharging batteries. Someone suggested that some chargers could be used with an external discharge resistor.
Are the PL8's capable of doing that with something like the following?
http://www.ebay.com/itm/1000W-1ohm-a...a5c&rmvSB=true
Mark
OMG, I'm flying again!
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 01-01-2016, 11:53 PM   #2 (permalink)
For the PL8 V2:
PL8 is regenerative discharge to a lead acid battery up to 40A, 1344 watt max.
For the Dual PL 8x2
PL 8x2 regenerative discharge supports up to 40A, 1344 watts per channel max.
In either case the charger needs to be powered by the lead acid battery in order for this to work.
I haven't seen a provision to add an external power resistor into the discharge circuit of the charger.
Old 01-02-2016, 08:46 AM   #3 (permalink)
Fair enough. Just curious.
I'll probably be better off keeping these discharge resistors separate anyway. I'll be in a position to charge and discharge about as fast as I could ever want pretty shortly.
Mark
Old 02-13-2016, 08:57 AM   #4 (permalink)
I was really hoping the PL8 supported this, too.
Regys likes this.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 02-13-2016, 01:10 PM   #5 (permalink)
I think most guys just connect/switch a resistive load on as needed to pull their lead acid battery voltage down low enough to allow the PowerLab to reach the desired discharge rate. It's a fairly simple thing to add and you just connect as needed when you see the PowerLab limiting discharge current due to lead acid battery reaching max volts.
RevoKelly is offline        Reply With Quote Quick reply to this message
Old 02-13-2016, 01:39 PM   #6 (permalink)
I set this up very recently but had never heard of using a large resistor to discharge before I started looking at this.
Mark
Old 02-13-2016, 01:59 PM   #7 (permalink)
i run 2 cooling fan motors (from a mazda) in series for 6s packs, i can do a fully charged 6s 5000mah in about 15min with very minimal noise (BLADES REMOVED !!) from the motors. They pull aprx 10@ when i put a amp meter on it.
Vbar cont/Dx9 , Nano,Nanocps, McpxBL,Goblin 380, Goblin 500 Lynxed out, Goblin 500 Night flyer, Goblin700 carbon edition Oxy2
Lynx Heli/Team pilot
thanasi is offline        Reply With Quote Quick reply to this message
Old 02-13-2016, 08:06 PM   #8 (permalink)
I don't use a lead acid battery to run my charger. For me, having the option to connect to a resistive load and then control the discharge with the PL8 would be really nice. In the scenario you mention, I have to buy the load resistors and a deep cycle lead acid battery instead of just load resistors.
Regys likes this.
Old 02-15-2016, 04:10 AM   #9 (permalink)
This exact scenario is why I keep my iCharger around even though 99.9% of my charging is done with the DPL8.
Eury is offline        Reply With Quote Quick reply to this message
Old 02-15-2016, 11:44 AM   #10 (permalink)
Yep, understood - for guys that wouldn't normally require off-grid charging, it is not a convenient solution and a standalone discharge solution would make more sense. We're kicking some ideas around on how to address this need using the PowerLab - will keep you posted.
Old 02-15-2016, 02:56 PM   #11 (permalink)
Nice! I know it's not always possible to add some things that were never part of the original scope of the project but it's really great to hear that you're looking into if it can be done.
Old 02-24-2016, 09:12 PM   #12 (permalink)
I hope it works out! It's the one thing I want my DPL8 to do that it currently doesn't.
Heli-X, Gaui X3 & Gaui X5 w/ Spirit FBLs, Quad with BetaFlight, FPV Fixed Wing w/ ET Vector FC, FrSky Horus w/ OpenTX 2.2, FMA DPL 8x2
kirby_ is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 05:18 PM   #13 (permalink)
RevoKelly - any update on this effort?
MDawson is offline        Reply With Quote Quick reply to this message
Old 08-10-2016, 10:29 PM   #14 (permalink)
I don't have anything I can publicly discuss yet, but we're working on it.
In the interim, I've found a workaround setup that works quite nicely if you're running on 12v or 24v power supply and you don't normally use the Battery supply setup in your PowerLab ...
SETUP
1. Find a suitable resistive load which, when powered by your switching power supply voltage, results in a wattage load that meets your discharge requirements, but does not exceed the amps capability of your power supply ... for example, connecting a 1 ohm resistive load to a 24v power supply will result in 24A and 576W. (V = I x R)
2. Setup the PowerLab Battery supply settings as follows:
Battery Low Voltage Out = { slightly less than your power supply voltage }
Battery Max Amps Out = { max amps rating of your power supply }
Enable Regenerative Discharge: enabled
Regen Amps IN to Pb = { slightly less than resistive load current }
Regen Volt IN to Pb = { slightly higher than your power supply voltage }
So for my setup, I have a 24.6v power supply capable of 75A, and a resistive load (modified hair dryer) which is 0.75 ohm. When attached to that 24.6v supply, the resistive load will draw 32.8A and 807W. So my PowerLab setup values are:
Battery Low Voltage Out = 11.9V/23.8v (slightly under 12.3/24.6v)
Battery Max Amps Out = 40A (limit of DPL)
Regen Amps IN to Pb = 32A (slightly under 32.8A of resistive load)
Regen Volt IN to Pb = 12.5/25V (slightly above 24.6v power supply)
This setup gives me about 800W of discharge for my Dual PowerLab - so takiing a 12S (pair of 6S) 5000 packs from full to storage can be done at 30A which only takes about 5 mins.
OPERATION
When you need to do a high-wattage discharge (something higher than the internal discharge limits of the Powerlab), simply :
1. Switch the PowerLab supply setting to Battery (to enable regen discharge)
2. Connect your external discharge load to your power supply
3. Start your discharge
4. When your discharge completes (and all chargers are idle), disconnect your resistive load
CAUTION: Never connect/disconnect the resistive load (or any other significant power load) while *ANY* PowerLab charger is active !!! The PowerLab manual will tell you the same thing, but just reiterating the same precaution when it comes to the external discharge load.
HOW IT WORKS
As the regen discharge current ramps up, the load on your switching power supply will go down ... the PowerLab basically takes over supplying most of the power to the external discharge resistor while the power supply continues to provide (at least) a small amount of power, therefore it is able to continue to regulate the output voltage.
The nice thing here is that it doesn't tie-up one of your charger ports - for example, both sides of your Dual PowerLab can be used to discharge a 12S pack.
Old 03-31-2017, 02:38 PM   #15 (permalink)
Kelly,
Any update on the FMA discharge solution?
T-Rex 550 ikon, T-Rex 700E v2 brain2
Goblin 500 brain, goblin blk nitro braid2,Goblin 770 ikon
RCHN 761
jflowers84 is offline        Reply With Quote Quick reply to this message
Old 03-01-2018, 02:58 PM   #16 (permalink)
Add me to the list.
Of course, what RevoKelly suggested is a nice idea, but a solution that requires less fiddling with the PSU settings would be great, if at all possible.
The fact that you risk damaging the PSU if you forget to disable reg discharge, is one reason.
vvv850 is offline        Reply With Quote Quick reply to this message
Old 03-02-2018, 12:18 AM   #17 (permalink)
Lightbulb
I don't want to be the guy that only asks for functionality and never contributes with ideas.
So, this is one of those "what ifs" discussion/idea.
Imagine you have a PL8T and a PL6 wired as such:
What if you can program the PL6 to act as a controlled resistor, basically a charger that varies output current to the resistor to keep the voltage of the PSU as steady as posssible, while the PL8T discharges into it.
I would imagine it could be working like this:
- you program the PL6 to act as a regenerative source
- input the maximum watts the resistor takes
- set the PL8T to discharge the attached lipo/batt
- once started, the PL6 will vary the output power to the resistor to keep the voltage on the input close to the start voltage
- the PL8T should know what the resistor limit is so that it does not increase the discharge power over the allowed limit to avoid increasing the voltage that goes to the PSU beyond an acceptable voltage
It's close to what RevoKelly suggested but it's more controllable and would not use unnecessary power while the discharge cycle ramps up.
I hope it makes sense. I also want to mention that I'm not an EE, and everything I know on the subject was self taught.
Cheers
Old 03-02-2018, 05:43 AM   #18 (permalink)
I'd guess that after this much time from when Revo said they were 'looking at it' and considering it's still unavailable that it must not be supported with current hardware?
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is online now        Reply With Quote Quick reply to this message
Old 03-02-2018, 08:01 AM   #19 (permalink)
Post 14 details an interim setup that RevoKelly states works "quite nicely" so I'm not sure how one could conclude "it must not be supported with current hardware"
Additionally, they just released the new PowerLab Touch Series so I'm sure Revolectrix has been quite busy with that project.
Old 03-02-2018, 08:08 AM   #20 (permalink)
Over a year ago...
Human Verification
