Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Old 07-04-2017, 11:27 AM   #21 (permalink)
In addition, I did check the pitch curves for all for FM and I have it set as global pitch curve so they are all the same standard curve in the jeti.
I was wrong on the trim settings though they are active but none were "off" meaning all were in their centered positions.
Compass Chronos & 6HV,6HVu,Mcpx BL,CFX180
DS-16!!,Phoenix 5
Team Flybar & "Less" now
LubeMan1 is offline        Reply With Quote Quick reply to this message
Old 07-04-2017, 11:55 AM   #22 (permalink)
So in the last video you had disconnected the motor and you were out of TH obviously.
And there was no swash tilt.
So it only happens when the motor actually spins.
Vibrations?
Did you try the analysis?
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 07-04-2017, 11:56 AM   #23 (permalink)
Vibrations?
As I stated in the video, vibs are very low across the board like 9 or 10 max in the analysis screen.
DS-16!!,Phoenix 5
Old 07-04-2017, 11:58 AM   #24 (permalink)
Yeah, and it would not fit the symptom of the swash tilting only when you apply pitch...
Darn.
Tricky.
Old 07-04-2017, 11:59 AM   #25 (permalink)
yes it only does it when the motor is spooled up.
DS-16!!,Phoenix 5
Old 07-04-2017, 03:12 PM   #26 (permalink)
Where is the ESC signal connected? Spirit or receiver? Have you tried to set it up with ESC connected into the other device? Which ESC & receiver and are you running telemetry? Any other telemetry devices?
If ESC is plugged in to the Spirit now and works correctly in the rx, that will tell you something worthwhile. Or the other way around.
If you're running telemetry, disconnect it and do the same test as the first video.
If it works fine with no motor, you have to isolate it to find it, so try everything you can think of that will eliminate one device, input, or factor at a time.
Dan
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is offline        Reply With Quote Quick reply to this message
Old 07-04-2017, 04:17 PM   #27 (permalink)
Where is the ESC signal connected?- Spirit
Which ESC and are you running telemetry?- Yes spirit to CC esc telem cable. CC 120HV
Any other telemetry devices?-No
DS-16!!,Phoenix 5
Old 07-05-2017, 02:56 AM   #28 (permalink)
You could try to return to the previous setup where it was working well.
This is to disable CC telemetry (although it should have no effect on this).
The worst scenario could be, that during modification of the unit that you have shipped to us for resistor change, something happened to the sensor connection (which is very unprobable, but due to required forces, it is in theory possible). In that case we will send you a new unit of course.
Can you check if the rudder is drifting somehow when motor is running?
So if you do not know what else you could try is to swap the unit for other spirit, load there very same settings and compare.
Also you may try to enable Advanced/Expert settings/Extended signal processing option.
Spirit System - www.spirit-system.com
ZeXx86 is offline        Reply With Quote Quick reply to this message
Old 07-05-2017, 08:55 AM   #29 (permalink)
I do have another Spirit Pro on the way, when it comes in I'll load the same setting and see what happens.
DS-16!!,Phoenix 5
Old 07-05-2017, 11:48 AM   #30 (permalink)
can't wait to see what's going wrong here. Ill be watching as this gets fix. Spirit guy over here 4 so far...
Blade 300CFX, 450. Align: 450pro(3S), 500(6S), 600E(12s), 600N, 800E(12S). X-cell: Ion700(12S)
HELI_FUN is offline        Reply With Quote Quick reply to this message
Old 07-05-2017, 12:25 PM   #31 (permalink)
Ok, well not fixed yet but did rule out the FBL controller.
The Spirit Pro arrived today so I updated it to the latest firmware then loaded the settings into it from the older unit, same result...crazy swash action with motor running.
Still investigating...
DS-16!!,Phoenix 5
Old 07-05-2017, 01:19 PM   #32 (permalink)
Did you try swapping two servos?
Will help decide between a single crazy servo and something else.
(I think I suggested already but kind of lost trackl
Old 07-05-2017, 01:27 PM   #33 (permalink)
Make a video of moving every control even throttle ( so unplug a motor wire / remove pinion) and show the controller and Diag. screen of spirit in video.
shouldn't take very long but gives a idea as to whats going on in spirits head. moves controls with and with throttle engaged. even with idles ups
its so odd and we all want to help you not destroy your bird over a incorrect setting
Old 07-05-2017, 01:57 PM   #34 (permalink)
Default Solved!!
http://www.spartanrc.com/store/product.php?productid=72
Ok, I had one of these install between the aileron & pitch servos and the Spirit so I could have two power connections too the FBL.
Apparently either the Spirit or the servos did not like that & once I connected everything directly to Spirit all worked as it should while running-> No more crazy tilt
I don't really understand why it didn't like it but it didn't. I thought it would just pass the signal through as if it was directly connected.
DS-16!!,Phoenix 5
Old 07-05-2017, 02:20 PM   #35 (permalink)
You had one on each servo on both servos on the one Micro Bus ?
Trex 550 V2 FBL, Logo 550 SX V2, Logo 550SE V2, Oxy 4 Spirit Pro,Oxy 3 Spirit
blade newbe is offline        Reply With Quote Quick reply to this message
Old 07-05-2017, 02:21 PM   #36 (permalink)
If you needed an extra power input why not just use a simple Y harness ?
Old 07-05-2017, 02:22 PM   #37 (permalink)
Can you explain how it was plugged?
Old 07-05-2017, 02:27 PM   #38 (permalink)
WTF the power buss was mixing the signal from ali. and ele.? or throttle and pitch?
Thats odd, but I have never used one of those. is it just like a BEC?
Old 07-05-2017, 02:31 PM   #39 (permalink)
Wherever I read, they never mention you can plug servos there... they always mention Spartan Data Pod, S.Bus Receiver, Back Up batteries...
Why not a simple Y?
Old 07-05-2017, 02:46 PM   #40 (permalink)
I had something similiar in my nitro, I was noticing the uneven movement of servos for pitch. That is when I realized I had way too much trim on my controller but I see you went over that now...
Soxos Strike 7.1/Synergy 696/Goblin 570 KSE/Logo 600 SE/Trex 600
Alberta Millwright is offline        Reply With Quote Quick reply to this message
