Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters
Scale Helicopters Discussions About Scale Helis, compatibility and and projects
Old 10-13-2015, 02:45 AM   #1 (permalink)
Default Thermoforming plastic to make landing lights
Here's a technique that I use as an alternative to vacuum forming.
This is to make the landing lights for a Funkey 600 size AS350. Here's a view of the type I am making:
I make a male form, usually with wood, and cast a female from the male, using plaster of Paris, mixed with about 20% cement powder. The cement makes a harder material and it sets much faster than the plaster by itself.
Here is a male mould, partly finished:
The male mould is greased, and a cardboard wall is hot-glued around it, into which the creamy-texture plaster-cement mix is poured. Here are the two parts after separation. The grey is primer used to fill and smooth the wooden part.
I have a sheet of 0.5mm PETG but you can cut the same plastic from soda bottles. If you heat a small sheet all over it will just shrivel up. So, you EITHER need to have a sheet a few inches larger in every direction from your casting, and protect most of the area from heating (e.g. with a cardboard or wooden sheet with a hole cut big enough to heat the working area) OR securely fasten the edges of your plastic sheet to a stiff frame e.g. of ply wood.
So, I place the female mould on the floor, place the PETG sheet over it, place a heat shield over the PETG, exposing an area I want to heat, heat the exposed area with a heat gun (paint stripper type, on low) until it softens, then press the male mould into it.
Here is the raw casting:
And here cut out with the lamp lens hole cut:
And here are both landing lights, buffed with bathroom abrasive cleaner, shaped and drilled, ready for priming.
The lamp lens, and reflector are made in a similar way but no female mould is needed. I just rounded the end of a dowel and pressed it into the heated plastic, supported on plywood with a round hole.
As I assemble the parts I'll post more details. I'm using tiny M1 (1mm daim. shaft) machine screws to fasten these to the fuselage.
Nelson
Name:	landing lights1.jpg
ID:	613770   Click image for larger version
Name:	No 1 unfinished male mould.jpg
ID:	613771   Click image for larger version
Name:	No 1 raw cast.jpg
ID:	613773   Click image for larger version
Name:	No 1 hole cut.jpg
ID:	613774   Click image for larger version
Name:	No 1 male and female moulds.jpg
Nelson JR DSX9 II; Stretched Atom 500 in Bell 222 body , Stretched TRex550 in 600 size AS350 - . Trex 450 S and 550E for sport . practice.SK720 all round..
Old 10-13-2015, 04:07 PM   #2 (permalink)
Super awesome!!!
Thanks for sharing that process. I learned something!
Steve
ssmith512 is offline        Reply With Quote Quick reply to this message
Old 10-13-2015, 06:18 PM   #3 (permalink)
HF Scale Support
Well done, Nelson. I need to figure out how to use that technique to make up a lens for my Little Bird build. I used duct seal (what I had on hand) to make a casting mold for a second antenna base on my TOW Defender and when ready to take the epoxy, it looked just like the female portion of your mold. Very cool and simple method and a great tip using a bit of Portland in the plaster of Paris. Take care.
Don
Old 10-14-2015, 02:27 AM   #4 (permalink)
Don
Thanks Don.
The idea to add Portland cement came from an engineer when I was a graduate student at Univ. of Toronto - near your home turf. I've been using that male+female casting system on a semi industrial level recently - casting over 1000 small coffee cup sized units for bumblebees to lay eggs in.
If you just want a convex lens you just need a dowel or broom-stick the the end shaped accordingly, and press it into the softened plastic. One trick that may be interesting, is to press the plastic into woven cloth on a cushioned pad. The weave leaves a matte hatched pattern that look like a lamp lens pattern but it also took away the clarity.
Another tip for this technique:
If there is no gap between the two moulds the plastic may not fit between them. Sometimes I use a layer of flexible tape over the male mould before casting the female - then peel it off and thus create a gap. But if you grease the male first, by the time you've removed the grease later, and sanded the female to a smooth surface there is usually enough gap.
Here's some more images:
Male mould for the recessed light:
With the wall filled with plaster:
Name:	No 2 raw male mould.jpg
ID:	613904   Click image for larger version
Name:	plaster poured.jpg
ID:	613905   Click image for larger version
Name:	No 2 moulds.jpg
Old 10-14-2015, 07:45 AM   #5 (permalink)
That is super awesome! Very nice work. Question though... When you say "grease" are you actually referring to grease that I would pack a wheel bearing or similar with?
Roban AS350. Roban Bell 429. Ikon
Jeti DS-16
JurassicJet is offline        Reply With Quote Quick reply to this message
Old 10-14-2015, 01:24 PM   #6 (permalink)
It's just for easy separation of the 2 parts. I use "petroleum jelly" ("Vaseline" in some markets) but I've used bearing grease as well. You need to remove it after if you don't want it on the plastic - problem for painting of course.
Nelson
Old 03-28-2017, 08:42 PM   #7 (permalink)
Smile Thermoforming plastic to make landing lights
Nice work!thanks for sharing
gidz25 is offline        Reply With Quote Quick reply to this message
Old 11-01-2019, 10:51 AM   #8 (permalink)
Default Alternative Make
Amazing! Your Skills are Top Notch!
I am not skilled well, to try that way. As i need thouse lights, I designed in CAD and printed. It worked nice, i am satisfied.
ID:	823531 Click image for larger version
ID:	823533 Click image for larger version
ID:	823535 Click image for larger version
ID:	823537 Click image for larger version
ID:	823539 Click image for larger version
ID:	823541 Click image for larger version
ID:	823543 Click image for larger version
This is a 470 size fuselage, but as the lights are CAD designed for printing 3D, they can be scaled in any size.
The_Fox is offline        Reply With Quote Quick reply to this message
Old 11-02-2019, 12:08 AM   #9 (permalink)
They look good. Will you make the transparent "lens" for the front by pressing a dome shape in clear plastic?
