Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Old 05-29-2017, 02:46 PM   #1 (permalink)
Default Edge 50 Lite enough?
I just ordered a P380 and need an ESC with full telemetry support. I already have an Edge 50 Lite in an X3 that I could move over. Anyone try this ESC?
Gscott is offline        Reply With Quote Quick reply to this message
Old 05-29-2017, 03:43 PM   #2 (permalink)
I use hw 50a esc on my P 380, it works with on issue. Guess edge 50a also can great fit in.
CyrusLi is offline        Reply With Quote Quick reply to this message
Old 05-29-2017, 03:46 PM   #3 (permalink)
The downside is the very well known weak BEC in the edge series. I would go with HW, personally. Much stronger BEC.
-Ben
Old 05-29-2017, 04:00 PM   #4 (permalink)
The HW doesn't support full telemetry.
Old 05-29-2017, 04:21 PM   #5 (permalink)
The Edge BEC on such a small heli should be just fine. You can always see what your BEC voltage is doing with telemetry and buy a small Gryphon BEC if you're having issues.
I'd never trust it on anything bigger, but I ran an Edge 50 on a 325 machine with MKS DS95 servos for years with no issues.
Specter v2, Tron Dnamic, Nimbus 550, P380, Edge-TX
JWeber is offline        Reply With Quote Quick reply to this message
Old 05-29-2017, 10:17 PM   #6 (permalink)
I've been using the Edge Lite 50 for quite some time now without issue. Moderate 3D at 3000 head speed and the highest logged current peaks have been less than 37 amps. It stays plenty cool. I did, however, decide to abandon the integrated BEC in lieu of an external one. This decision was only by recommendation, and not due to any negative experience or suspicious logging.
uh1medic is offline        Reply With Quote Quick reply to this message
Old 05-29-2017, 11:15 PM   #7 (permalink)
i've been using one for several months now along with built in BEC at 8V with mk93/93i servos - seems to be OK. I'm using a spektrum rx voltage protector cap.
live link telemetry seems to work pretty good as well with brain2 in this application if you're interested in that - no wild readings or throttle glitches.
HAPPY FLYING!
http://www.baysidercclub.com | AMA#912659 | RCHN #830
Jeti DS14 | Brain2
Synergy N7 | Protos Max V2 | Protos 380
canbarelyhover is offline        Reply With Quote Quick reply to this message
Old 06-18-2017, 12:54 PM   #8 (permalink)
You can build it up and bench test the BEC to see if it will hold on your setup.
Each setup, even identical ones can have different results.
I also ran a lite 50 for years on a 450 with DS95s and had no issue, but when I tried the same ESC on another machine with KST servos it would brown out.
The only way to be sure is to try iy
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 06-18-2017, 01:12 PM   #9 (permalink)
I'm still putting together my P380, but I'm going to do that on mine as well. Always better to have a dedicated BEC. You can get a higher rating and it's better not to share boards with that electrically noisy ESC. They put the BEC on the ESC as a convenience thing, but I don't think it's the best solution. Funny you can hardly find ESCs without a BEC on board, I guess they assume that's what everyone wants.
Krager is offline        Reply With Quote Quick reply to this message
Old 07-01-2017, 12:16 PM   #10 (permalink)
5a bec on the 50 isn't it? That should be fine.
I'm using a 60a YGE that has a 3a continuous, 5a burst BEC and haven't had any issues. Using 306gHV and a MKS ds95i
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 07-02-2017, 03:24 PM   #11 (permalink)
It should be fine on paper but sometimes the bec just isn't enough for some reason.
Like Canbarelyhover I run my castle 50a with a capacitor I got with my Hobbywing 130a esc. It buffers current spikes, so as long as your average draw isn't over 3a you should be golden.
My particular esc had brown outs before but this fixed it. Don't know why more people don't use caps. In my experience it made an inadequate bec perfectly usable.
Yfbb is offline        Reply With Quote Quick reply to this message
