mCP X BL Blade Micro mCP X Brushless |
04-12-2017, 12:44 PM | #1 (permalink) |
Front flips require aileron input
I can flip my ncpx bl just fine, I'd blame my thumbs normally but this problem only happens with my mcpx bl.
When I do I tail in front flip I have to add substantial left aileron to keep the flip under control. When I do an aileron roll I have to add substantial elevator to keep the help from plowing into the ground. Hopefully this is clear, I have a black dx6 and I have my travel set to 125% for ail and elv. I don't believe I have any mixes set I don't think there would be any reason for me to but ill double check when I get home. The helicopter flies forward, banks, and hovers perfectly. Does anyone have any ideas? |
04-13-2017, 01:10 AM | #2 (permalink) |
I honestly have no idea. I have never had that problem with mine. My only thought could be is if a servo is binding up against a wire or the canopy maybe? I have my DR set to 120% because 125% is getting close to the servo limits.
Rakon 200 SRX with AFRO Tail ESC, 230s Night, Nano CPX BL, MCPX BL, Sport Cub S, and Nano QX. DX6, DX6i and Phoenix Flight Sim
04-13-2017, 07:10 AM | #3 (permalink) |
I forgot to mention that my tail boom is significantly loose, sometimes I've seen the tail rotor off but I've straightened it and it stays in place for a while.
Last night I glued the tail boom into place, it's not going anywhere. I'll come back with the results. |
04-13-2017, 11:27 AM | #4 (permalink) |
Yup. Most glue the boom in I did and haven't looked back.
Sent from my SM-G925W8 using Tapatalk |
04-13-2017, 09:08 PM | #5 (permalink) |
Quick test revealed more of the same, when doing a front flip the heli travels to the right. Watched the servos while giving full elevator and everything seems smooth, no servo jitters or unevenness.
I'm not blowing my tail out am I? It's on an extended boom even. |
