Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 04-02-2017, 03:25 PM   #1 (permalink)
Default Tail Not holding.. probably mechanic..
My Triabolo with tri-tail was flying great at 1500hs, whatever I throw, I had it at 10.5* pitch and 10* ele, With a 18T. Have the red tail pulley and 110mm tail blades.
Whanted more agresiv to do some maneuvers, so I change it to 13* pitch, and 20T, so I can run at 1770hs.
Tail is not holdin on pitch ups the nose turns left and it turns like 90* then return the were it was, and when doing fast stop the tail blow and does not hold...
I try playing with the gyro sensitivity but no help..
Should I move the ball link on the tail servo in (close to servo) or out?
The only mod I did was change pinion / pitch and HS.
Also change from HW160 to Scorpion Tribunus... could it be the internal GOV
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 04-03-2017, 09:09 AM   #2 (permalink)
what size tail blades, tail gyro and servo?
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 04-03-2017, 09:36 AM   #3 (permalink)
NHP 110mm Tail blade with the tri-tail and red pulley
FBL is Spirit Pro,
Tail Servo: Savox SB-2283MG
Dimension: 40.3x20.2x38.7mm
Weight: 69g
Rated Voltage: 6.0 - 7.4V
Operating Speed:
@6.0V: 0.06 sec°/60
@7.4V: 0.048 sec°/60
Torque:
@6.0V: 69.4 oz-in (5.0 kg-cm)
@7.4V: 138.9 oz-in (10.0 kg-cm)
Gear: Metal
Bearing: 2BB
The strange thing is tat when it was on the 18T pulley at 10.5*'and 1500HS, it holds just fine when I incrise thenpitch and HS to 1770, it blow the tail, also since in change the ESC maybe the internal GOV is not responding fast enough to demand and is not acceleration to regain HS
Jeti DS-14 Edition
Old 04-03-2017, 10:14 AM   #4 (permalink)
A little strange since you usually gain tail hold when you raise the headspeed so you don't need to increase tail gain.
Since you added hs and pitch it might be a little too much for the tail to handle with your current settings. Did you try raising tail gain a couple/few points?
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 04-03-2017, 11:32 AM   #5 (permalink)
IŽll have to check the letter the log on the HS, since the only thing that comes in mind is that when I go full pitch the HS drop significant and the tail loose authority since it turns the nose to the left, and when it regain the HS it also regain authority... in the matter of setup in the FBL I try pretty much everything that alowsmy to...
Because if i go full throttle smoothly it will hold just fine. is more on the agresiva side that the tail loose authority..
Jeti DS-14 Edition
Old 04-03-2017, 12:56 PM   #6 (permalink)
I have tried 13 deg collective on mine at 1800. It holds just fine. It must be your Gyro settings.
Having said that, 13 degrees is really not needed with the NHPs. The recommended 10.5 is ballistic at that head speed. Check out vids of Miles beating the *%#! Out of it with just 10.5 and 1800. 👍
aziz76 is offline        Reply With Quote Quick reply to this message
Old 04-03-2017, 01:43 PM   #7 (permalink)
ok, I wanted to try Nick Maxwell setup...
13, 10
RPM 950 in hover/1250 slow RPM 3D/1780 3D
Jeti DS-14 Edition
Old 04-03-2017, 06:44 PM   #8 (permalink)
Hou mentioned its loosing head speed on those pitch pumps. If so then thats the explanation. Loss of head speed makes the tail kick out.
Make sure the motor and esc can handle the collective pitch as aggressive pitch pumps.
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 04-04-2017, 06:09 AM   #9 (permalink)
yeah also what motor are you using with it?
Richard Zappe
Old 04-04-2017, 07:52 AM   #10 (permalink)
FBL System: Spirit pro
Motor: Xnova XTS 4435-460
Pinion: 20T
Target Headspeed(s): 1100-1800HS
ESC: Scorpion Tribunus 200a
Governor: Internal Gov
BEC: internal 7.4v
Cyclic Servos: Savox SB-2282SG
Main Blades: 3 x NHP 680mm
Tail Blades: 3 x NHP 110mm?
Lipos: Pulse 2 x Revolextrix 5200 6S 40C
Anything else: Tri-Tail | Red Speed up Tail Pulley
Jeti DS-14 Edition
Old 04-04-2017, 10:44 AM   #11 (permalink)
Try to increase the ESC gov gain.
You could also try the spirit gov.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 04-04-2017, 12:28 PM   #12 (permalink)
Pinion: 20T
BEC: internal 7.4v
On my 700/Neo/Tribunus
I had to just about double my collective pre comp to eliminate the same effect.
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 04-13-2017, 11:56 AM   #13 (permalink)
Yep i had to double my pre comp for tail but also after comp is added i turned on heli and re did tail linkage so it was 90 this is with precomp. Other wise it would be all wacky. So basically tail is set up mechanically and pre comp can perform without being stopped at either ends of throw...tail holds perfect now
out flying..
$Gambino$ is offline        Reply With Quote Quick reply to this message
Old 06-06-2017, 01:58 AM   #14 (permalink)
try lower your headgain
untill yesterday i have same isseu on Vbar Neo, we lowert the headgain more the usueal and now my tail is rock solid in strong wind fast flying backward .. hope it helps.. all credits go to Patriek from heligear.nl
Minicopter Diabolo black edition
Logo 550 2017, Gaui X3Gold, Oxy 210FE
Vcontrol Touch, NeXt, PL8x2
RuudM is offline        Reply With Quote Quick reply to this message
Old 06-06-2017, 10:36 AM   #15 (permalink)
Still - loss of head speed = tail speed down. Make sure the governor settings on ESC compensate for the extra push. Three bladed main head requires a bit more power increase to compensate quick for head speed loss. So you need to compensate in the governor settings. Possibly even switch from ESC governor to the FBL system.
