180CFX Blade 180CFX Helicopters Information and Help |
06-02-2017, 03:14 PM | #1 (permalink) |
Which hole on H3060 servo arm?
Hey guys, just wondering when you put in the Spektrum H3060 tail servo, which hole on the servo arm did you use?
On the stock servo arm, the second hole is used, which is about 7mm from the servo axle (for want of a better term). In the Lynx instructions for the tail push rod, however, the instructions say to use the first hole in the servo arm, which is about 5mm from the servo axle. Here's the thing, though. Shortening the distance between the link ball and the servo axle increases the effective torque of the tail servo, but sacrifices effective servo speed. Since the H3060 already has more torque than the stock DS76t servo, and nearly the same speed, wouldn't we be better off going with the second hole at 7mm instead of the first hole at 5mm?
navigator2011 Fusion 180 / OMP Hobby M2 & M1 / TBS Tango 2 / Radiomaster TX16S. Navi's Channel / Navi's RCGroups Blog |
06-03-2017, 12:38 AM | #2 (permalink) |
I used my stock tail servo arm/position on the 3060. Same spline etc.
06-03-2017, 01:05 AM | #3 (permalink) |
Do you get any tail weathervane behavior, even when flying backwards?
06-03-2017, 06:25 PM | #4 (permalink) |
To be honest I haven't had a chance to test thoroughly yet, I put my 3060 on a few months ago and have only had few test flights.....too much wind. I will report back when I have had a chance to test.
On the second hole and at 100% travel the pitch slider is about 1mm from each extreme end of travel. Pretty much perfect placement. |
