Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > R5
Old 03-29-2016, 06:33 PM   #21 (permalink)
Robert,
Another great video. Thanks for posting!! I'll be replacing my motor after this weekends funfly with the new scorpion as well.
Is there a reason why you increased hover head speed? Is there a issue with esc temperature when lowered to 1800 or so? I find the r5 to lift off and land really smooth at 1800ish and was planning to leave it there.
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 03-29-2016, 08:29 PM   #22 (permalink)
It just feels better to me with this motor.
RGorham is offline        Reply With Quote Quick reply to this message
Old 03-29-2016, 09:22 PM   #23 (permalink)
It sure looks faster Robert. I can wait to maiden mine.
Thanks for the video.
Kaylee Smith, RCHN #231
Spartan, Synergy E7, Legend FBL, Goblin 700, Whiplash E, Furion 6s,GAUI R5, Furion 450s, Xcell 60 , T-REX 600s, T-REX 450s, 300X, 130X, MCPXs. I'll fly what I want to fly. You do the same.
flyul1 is offline        Reply With Quote Quick reply to this message
Old 03-30-2016, 10:37 AM   #24 (permalink)
Robert,
Just wants to say, keep them videos coming. They are spectacular.
Logo 700 | Trex 700X | Logo 600 | Logo 690SX | Gaui R5 | V-Bar Control
V-Bar Control flight analyzer (Win/OSX/Linux) - Latest release v5.0.0 July 5 - 2017
Sleipnir timing system - How fast can you fly?
Only the ground is the limit!
LinusLarsson is offline        Reply With Quote Quick reply to this message
Old 03-30-2016, 12:20 PM   #25 (permalink)
The Airetic
Great video! Thanks for sharing!
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 04-05-2016, 08:58 AM   #26 (permalink)
Further information about this NEW powerhouse of a motor for those of you that are interested.
http://www.scorpionsystem.com/blog/?...#comment-18063
Old 06-21-2016, 06:55 PM   #27 (permalink)
Robert,
I am swapping out motors tonight. What have you settled at as far as head speed for a 3 speed setup with the Scorpion 630kv?
Old 06-24-2016, 10:07 AM   #28 (permalink)
I settled with 2000, 2450 & 3100 using the 22T pinion. You can go up on your top end head speed but battery usage leaves very short flight time.
Old 06-24-2016, 10:35 AM   #29 (permalink)
Thanks, Robert. Motor is in and a bench spool up with Kosmik showed 2000 with 22T at 50% TC, 3280 at 78% and 3400ish at 80%.
I'll dial in your settings and give it a go in the morning.
Old 06-24-2016, 12:55 PM   #30 (permalink)
I'll warn you....it goes really fast ! Lol
I would set your first flight at two minutes and check your batteries.
Old 06-25-2016, 02:34 PM   #31 (permalink)
That's what I'm talking about!!! Four flights performed today and what a difference this motor made. Very locked in and stable at the new head speed. One set of batteries with 45+ flights will have to take a bullet after today. On pass number 4, they set off my low voltage alarm, followed by mah consumed alarm.
Thanks again Robert for the tips!!
Old 06-25-2016, 02:45 PM   #32 (permalink)
The Airetic
Nice!!! How many flights did you get out of them? And what brand etc..packs are they?
Old 06-25-2016, 03:03 PM   #33 (permalink)
Pulse 6S, 3300 mah, 65C. I got 45 or so flights on them running 2800 HS. On the newer set (20 flights) I made 6 passes at 3150 HS before tripping my 70% mah consumed alarm. Note: I reduce HS to 2400 going up the ramp and switch back to 3150 1/3rd the way down the ramp to conserve battery.
Old 06-25-2016, 03:28 PM   #34 (permalink)
The Airetic
Holy crap! That's pretty quick. I was hoping to get more flights than that from them.
I guess it isnt that big of a deal though, I have 6 sets of them (3300mah packs) so, that should get though quite a good while!
Old 06-25-2016, 03:53 PM   #35 (permalink)
Justin P mentioned getting 30 flights out of his packs on a recent RCHN episode. I guess it depends on how hard you fly them, amount of collective pitch you run and your HS/kV choice. I'm at 14+ pitch right now and feel bumping it up to 15 will only kill batteries at a faster rate.
Old 06-25-2016, 05:31 PM   #36 (permalink)
This is what telemetry showed using my battery with 20 flights
Ambient: 87F/30.6C
motor temperature at end of flight: 197F/91.7C
Battery temp at end of flight: 110F/43.3C
flight time of motor: 2:57 min
6 passes made using 2674 mah for total flight (81% of capacity)
Power System GPS II speed readings: 235, 230, 228, 221, 232, 235 km/h
Motor PWM: 92-95%
Kosmik 200 fet max 188F/ 87C
3150 HS
7000 watts maximum
amps: 40 in normal mode , 80-160 in IU2
Old 08-17-2016, 12:07 PM   #37 (permalink)
Robert, do you have to cut short the shaft making it 41-42mm in length?
I'm in the middle of building my new R5. Still deciding whether to use my old motor, Scorpion 4525-520KV, with the shaft replaced, or get the new one, 4235-630KV.
sam.s.man is offline        Reply With Quote Quick reply to this message
Old 08-17-2016, 12:32 PM   #38 (permalink)
Yes I did
Old 09-19-2016, 11:47 PM   #39 (permalink)
Hey guys
With summer just around the corner for us, I'm thinking of doing some work on getting more speed out of my R5. My 6's hyperion packs are just about flogged and batteries will be on the list of requirements.
I'm thinking of getting this motor but was wondering also if there is a benefit to going 14's instead? I understand the reasons for going 14's but just wondering if it's worth it??
I'm running the 160amp kontronik esc so either is fine, its just the battery/motor decision.
Also has anyone heard anything about proper speed blades coming out any time soon??
Chrs Guys
Gaui NX7,X7, R5, NX5,
Vcontrol, Vbar
Hobbycity New Zealand
flyingkiwi is offline        Reply With Quote Quick reply to this message
Old 09-21-2016, 04:55 AM   #40 (permalink)
I did the math and a 520kv motor running 14S will give almost the same motor rpm as the Scorpion 630kv on 12S but everything will run cooler.
TheKingPhisher is offline        Reply With Quote Quick reply to this message
