Aerodynamics, Physics and Engineering Aerodynamics, Physics and Engineering Discussions |
01-16-2013, 09:28 PM | #61 (permalink) |
Gyroscopic precession relates to the pulling of the rotor system with the controls. It is not related to dissymmetry of lift in the capacity you are describing.
Please read the section in your link on compensation to understand what I am referring to about articulation. In RC aircraft the contributing factors are the blade dampers, the rigidity of the blades, blade span moment, and the blade bolt tightness. I would imagine if you reached VNE with a FBL model the FBL controller would make things worse not better. You would be simply inputting forward cyclic and the controller would be giving the compensation to correct the result would be an immediate roll. I do agree with the pitching upwards the faster you are going just not in the capacity you are trying to piece it together. |
01-16-2013, 09:51 PM | #62 (permalink) |
"pulling on the rotor system with controls" creates dissymmetry of lift. Thats what controls the heli.
If you actually look at your helis you'll find: Up elevator (nose up control input) increases the blade pitch on the advancing side of the rotor - creating more lift on the advancing side. This causes the nose of the heli to lift. Nose up in FFF happens because the advancing side is generating more lift as well. Not "effects about the roll axis" (unless maybe you are in a real heli in which case I would have no idea) I agree that its possible for a heli experiencing RBS to roll in the direction of the stalling blades, but thats no what I'm trying to discuss. Every person Ive spoken to about his (except you) has told me to make my heli nose heavy for FFF to avoid pitch-up problems. So I make my heli nose heavy. It really works, you should try it. I'm no heli mechanic, but it works for me. |
01-16-2013, 10:25 PM | #63 (permalink) |
I am quite familiar with how a rotor system works. The term dissymmetry of lift is referring to a specific phenomenon. I have never heard it used to explain the actual left, right, nose up, nose down response of cyclic input is all.
I never stated to not shift the heli cg forward to stop the nose from coming up. This works. What it would do is cause the heli to flip faster (as in without as long of an indication of the nose coming up). This is because the RBS is related to the rotor dynamics and not the CG. All I was pointing out on the gyroscopic precession is this is not related to airspeed or lift. It has to do with what direction the aircraft will move in relation to where the swash is tilted and the connection to the rotor blades. |
01-16-2013, 10:37 PM | #64 (permalink) | |
Let me expand on what I originally said. Dissymmetry of lift = nose-up in FFF Nose-up = error signal generated my FBL controller FBL controller compensates for error-signal by adding forward cyclic. Therefore FBL unit has compensated for dissymmetry of lift. BUT - its better to have a CG forward so the FBL unit does have to compensate as much. Dont ask me why, it just flies better like that. Was I really completely wrong on this? |
01-16-2013, 10:43 PM | #66 (permalink) |
Ok, correct, they have a simple form of that, but this does not explain how I was completely wrong
EDIT: even rigid head helis without articulation still get compensated by an FBL unit |
01-16-2013, 10:47 PM | #67 (permalink) | |
01-16-2013, 11:25 PM | #71 (permalink) |
Since this thread moved to dissymmetry of lift, can one of you super genius people that was posting in the beginning of the thread explain why we don't see the effects of translational lift in our model helicopters? I have never gotten the shimmy coming back to a hover. Is this related to the wicked fast head speeds?
01-16-2013, 11:29 PM | #72 (permalink) | |
ever fly in the wind? even just hovering in the wind you can see it
DX8 mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades AMA#948801 |
01-16-2013, 11:34 PM | #74 (permalink) | |
and when i had my mCP X you could feel it in the wind its also why fixed pitch helis fly like crap in the wind
01-16-2013, 11:49 PM | #76 (permalink) | |
You dont always get the little wobble in my experience, could be FBL can compensate for it, or the helis are so small and light it is nor really apparent?
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
01-17-2013, 11:55 PM | #77 (permalink) |
Guys
The last few pages has a lot of convoluted/incorrect info. Fore and aft CG vs pitch stability is the same with helis as with fixed wing. If you have CG ahead of the center of lift in forward flight, when the rotor experiences a transient period of positive lift (i.e. slight change of headwind, etc), that causes the chassis to pitch down. Since the chassis is fairly rigidly attached to the rotor, this action tends to pitch the rotor to a reduced angle, reducing lift. This holds for the reverse (i.e. negative lift countered by chassis pitch up). Dissymmetry of lift is not generally considered to be offset by blade articulation (i.e. flap to equality). Flap to equality is a transient condition normally seen during changes in velocity, but helis dont cruise with high rotor cant angles relative to the chassis. The pilot compensates for it with cyclic. Phase lag is not 90deg in our machines. That is the ongoing myth of rotors as gyroscopes, used for ages as a simple way to teach students why rigging angles are what they are. No one seems to question why the rigging angle is not 90deg in reality, or why it changes with blade Lock number or with hinge offset. The rotor flies to position, and swamps underlying gyro forces. Dissymmetry of lift is not limited to left/right rotor hemispheres (i.e. advancing vs retreating blades). Another variant is fore/aft, which is a function of asymmetric inflow in horizontal flight. In conventional flight, the air pulled in axially through the top front of the rotor has not accelerated as much as the air that is pulled in at the top rear of the rotor. As a result, the AOA at the rear is reduced. While the advancing blade/retreating blade effect impacts pitch in FF, the inflow asymmetry impacts roll in FF (hence its common name, inflow roll). Pilots learn to deal with this without thinking- which is probably a reason it is non-intuitive. On the shimmy question, that is normally attributed to blade vortex interaction. We are less likely to see this, because our blade vortex energy is very low due to our low rotor disc loading (which is generally about 10% of full scale). Sorry to not break this out by thread, etc, but time is a bit short. Regards,
"The problem with quotes found on the internet is you have no way of confirming their authenticity." - Abraham Lincoln |
01-18-2013, 08:39 AM | #78 (permalink) | |
If the effects of the blades bending, leading/lagging, and flapping are limited to periods of transient velocity relative to the entire aircraft you would only ever see a per rev vibration during transient periods (if the track was in at any one given airspeed). This is not what happens because the blades can fly out of position at different airspeeds. |
