Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 02-14-2017, 09:04 AM   #1 (permalink)
Default wobble during spool up
does anyone have a wobble at around 75% of the spool up , it seems like there is a very pronounced wobble at a certain headspeeed which disappears once i'm up to my headspeed. is it something that I need to look into or just a quirk?
Anthony
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 09:57 AM   #2 (permalink)
probably off balance blades. Does it do it on slow down too?
bgymr is offline        Reply With Quote Quick reply to this message
Old 02-14-2017, 02:00 PM   #3 (permalink)
no just near the target headspeed , new switch blades too
Anthony
Old 02-14-2017, 11:39 PM   #4 (permalink)
What head and dampeners do you run?
And are your dampeners lubed up?
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 02-15-2017, 05:09 AM   #5 (permalink)
good question I will have to check
Anthony
Old 02-15-2017, 05:20 AM   #6 (permalink)
Your blades are probably a little too tight in the grips. Shake on spoolup=too tight, shake on spooldown=blades too loose. Spool down shakes are worse since they can cause a tip over.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 02-15-2017, 06:34 AM   #7 (permalink)
I put on the formula head about 15 - 20 flights ago so whatever the stock ones are and they should still be in good shape , io don't feel any movement when I try to rock them , baldes too tight is a possibility as I do run them fairly tight but they don't take too much force to move them in the grips , I thought maybe the main bearings might be a little old , they feel fine and rotate smoothly but they are old
Anthony
Anthony
Old 02-15-2017, 03:52 PM   #8 (permalink)
Check and lube the dampeners just to be sure.
What HS do you run?
JR XG14 PL8 v2
Old 02-15-2017, 05:37 PM   #9 (permalink)
2500 rpm
Anthony
Old 02-15-2017, 11:35 PM   #10 (permalink)
That's more then enough....
Still my money is on the lube of the dampeners...
JR XG14 PL8 v2
Old 02-16-2017, 05:08 AM   #11 (permalink)
lube'd them last night will let you know how it goes , also slackened the blades a little , still tight but not as tight as I had them
Anthony
Old 02-16-2017, 08:03 AM   #12 (permalink)
i love my x5 formula but it has been, by far, the hardest heli to tune.
I have noticed that dampers play a big role in rotor head oscillations.
seems everyone runs the kbdd lime green ones.
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 02-16-2017, 07:45 PM   #13 (permalink)
well I tried it this morning and the wobbles have gone, more than likely it was the dampeners as they were hard to get out and the feathering shaft was also difficult to move after lubing it was a lot easier, thanks for the help
Anthony
Anthony
Old 02-16-2017, 11:07 PM   #14 (permalink)
JR XG14 PL8 v2
