700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-19-2017, 05:39 AM | #1 (permalink) |
700n OS105 Flight Times
Just curious to see what sort of flight times people are getting.
I'm running 1950 HS and getting about 8 mins flying, 2 mins faffing about and landing with about 12mm left in the bottom of the tank. Once I get my on board glow and dont have to mess around getting the canopy on I think I could get 9 mins flying.
700N MJ DTS VX1N, Logo 690SX - VX1e, 780L Top - VBar Neo, 700L Top - VX1n, Logo 550SX - VX1n, Goblin 570 (6s) - VX1n, Trex 550E Pro DFC - VX1n, Trex 450L Dominator (6s) - VX1n, Trex 450 Plus DFC - VX1n, JETI, DX9, Pheonix R/C, AccuRC, neXt |
04-19-2017, 09:23 AM | #2 (permalink) |
I run a 6 min timer with a bladder, I land with enough fuel left that I could probably run 7 min. 2000hs with the 8.0 ratio gears.
Edit: 30%, added the thinner shim, stickbanging.
Team Only Fine Helis Last edited by smwht; 04-19-2017 at 12:26 PM.. |
04-19-2017, 10:55 AM | #3 (permalink) |
Stick banging about 6m with 30% pretty rich to keep it cool. With extra shim.
04-19-2017, 11:16 AM | #4 (permalink) |
6-7 minute of stick banging at 2000 rpm (8:1 ratio).
I tried to fly my 700 electric this past weekend and landing at 3:45 was unsettling.
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550x spirit pro / Goblin Black Nitro 700 |
04-19-2017, 02:38 PM | #5 (permalink) |
What do the different shims do?
04-19-2017, 03:18 PM | #6 (permalink) |
Stick banging about 5m with CoolPower 30% . 2050rpm
2 x 0.2mm shims in the head
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo |
04-19-2017, 03:23 PM | #7 (permalink) |
Reduces compression. The motor with stock shims is designed for 15%-20% nitro, with 30% you need to reduce compression to avoid detonation.
Team Only Fine Helis |
04-19-2017, 08:01 PM | #8 (permalink) |
Yah per the OS105 manual you want to run 2x 0.2mm shims for 30% (it's just the fuel I already had 3 cases of). Good news is with this setup it doesn't run too hot at all. Just need to run the middle needle pretty rich. And just tune the high needle. I'm a learning tuner, but I'm VERY happy with the OS105. I had nothing but bad luck with my YS91SRX. To the point where I couldn't even learn to tune before burning out a motor. Now finally I have 5 gallons through an engine and I'm enjoying what nitro has to offer.
I mounted VTX 697 on the nitro. Actually pretty shocked with what happened. Normally there is an envelope of maneuvers I can do with a 3.5HP nitro vs a 12HP electric. A compromise. But what surprised me is the amount of cyclic I can use with VTX without bogging the engine. Pretty much opened my entire envelope with the nitro. Was really surprised by it. So my love of nitro hit a new level since I can just fly it and load cyclic a _lot_ more without killing the engine. |
04-20-2017, 06:36 AM | #9 (permalink) | |
