Like Tree4Likes
Old 12-22-2007, 06:24 AM   #201 (permalink)
But the big advantage is, I can buy 401s for under $100 used.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 08:34 AM   #202 (permalink)
Originally Posted by Finless View Post
Jeremy.... after flying the 760 I can tell you for sure it BLOWS away the 401. I don't know that I will be good enough a pilot to be able to tell the difference between that and a Zero-G.
Bob
Zero-G Gyro LOL , It should rock on a Solig G Raptor conv. JK.
epc2.
epc2 is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 09:57 AM   #203 (permalink)
Team Taco VP
Ooops.... got me... I meant Solid-G gyro.....
OK OK... It was late last night
Bob
Old 12-22-2007, 10:05 AM   #204 (permalink)
Team Taco VP
A BUNCH more videos just posted.
Head, main gear, etc install
Geometry explained!
Head setup. THis also shows how i set 0 pitch without a pitch guage!
Bob
Old 12-22-2007, 10:52 AM   #205 (permalink)
Smile
So Bob ,
What gyro will YOU actually be using on this heli ???
Antony.
ADK
TREX 450 SE, HS65MG, 9650, GY401, Align 3K CF main Blade.
DRAGONUS II PRO, FUT S3153 DIGITAL SERVOS, GY401, Align 450XL .
TREX 600CF, 9255'S, GY401 9254, Fut 138 DP RX.
TREX 500CF, 4x9257 on 6 volt, GY401, 6S 2500's EVOLITE'S, 13T, 2700HS.
Antony Konnarides is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 10:59 AM   #206 (permalink)
Team Taco VP
Curtis Solid-G and 9257 tail servo.
Bob
Old 12-22-2007, 11:02 AM   #207 (permalink)
Hey Bob, i've got a Li-Po sitting here, it is from maxamps, http://www.maxamps.com/proddetail.ph...48-Pack&cat=14, I know 4s but i just want to use it for the first couple flights until i get enough $$$ for a flight power 6s pack, will it fit under the canopy and will it balance well?
Thanks ALOT!
spencer737 is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 11:09 AM   #208 (permalink)
Team Taco VP
It's a little long but yes I think it will fit.
Bob
Old 12-22-2007, 11:23 AM   #209 (permalink)
Good Morning Bob,
I use a 4s 1800 & 4s 2170 packs on my Mini-Titan. Would it be posibble to make this a 8s bird with the supplied ESC and Motor or do I need to buy my own?
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 11:32 AM   #210 (permalink)
Team Taco VP
Nope.... ESC and motor wont support 8S.
Bob
Old 12-22-2007, 12:56 PM   #211 (permalink)
Geometry explained!
Bob
Thanks again Bob!!!
Mikrokopter building photos and heli x-ray images: www.x-ray-heli.com
/ Blade mCX
/ Blade CX extreme / Hurricane 200 / Mini Titan E325 /
T-Rex 500 / Logo 500 3D / Trojan T-28 / Super Mini Cub / MPX Blizzard
Mikrokopter Cayman 500 /
Mr. Slumber is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 01:16 PM   #212 (permalink)
Team Taco VP
Step 11 is up.... Tail drive and boom install!
Bob
Old 12-22-2007, 02:31 PM   #213 (permalink)
The Capi
As you command Bob,
I did a little bit of math to show the effect of using any horn length that results in a different angle than 90degrees. I didn't however figure out the best angle as it gets really complicated really fast.
As you can see even if you let the Lo term go to zero the swash relation to the servo angle is FAR from linear.
Old 12-22-2007, 04:07 PM   #214 (permalink)
Team Taco VP
Well beyond me dude.... I use to love geometry in High School as it was one of my favorite subjects but after 30 years of rarely using it at this level it's all LOST in my gray matter somewhere....
Splain it in layman terms
Bob
Old 12-22-2007, 06:17 PM   #215 (permalink)
Team Taco VP
Two more up!
Step 12 and 13.....
Getting closer
Bob
Old 12-22-2007, 08:30 PM   #216 (permalink)
Stupid question time: on the thrust bearings, what's the purpose of the inner race being loose? Is it to accommodate wobble without binding against the shaft?
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 11:00 PM   #217 (permalink)
I am stuck between going with the Hitec's 5245mg's or the JR 3400g..I really want to go metal gear but dont want to suffer on performance..What to do??
Tron 7.0 Tron 5.5 Tron Nitron Tron 5.8
VTouch/Neo
Locktite is offline        Reply With Quote Quick reply to this message
Old 12-22-2007, 11:52 PM   #218 (permalink)
Looks like i am pretty much set on 5245mg's
VTouch/Neo
Old 12-23-2007, 12:40 AM   #219 (permalink)
what about the futaba 9257?!
Old 12-23-2007, 01:01 AM   #220 (permalink)
I would rather suffer just a tad in performance so I don't have to change servo gears all the time if i crash..
VTouch/Neo
