Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree3Likes
Old 07-26-2016, 11:17 AM   #21 (permalink)
Plenty of NX7 3-blade videos out there as well
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is online now        Reply With Quote Quick reply to this message
Old 02-06-2017, 02:22 AM   #22 (permalink)
I have a small question about this new tail rotor head.
It will work also with the old Control Arm:
http://www.aligntrexstore.com/Metal-...6A_p_1649.html
Or I have to upgrade to the new:
http://www.aligntrexstore.com/700Met...7A_p_4591.html
misterRED is offline        Reply With Quote Quick reply to this message
Old 02-06-2017, 11:21 PM   #23 (permalink)
it requires the multi-link tail control arm.
By replacing your morning coffee with green tea, you can lose up to 87% of what little joy you still have left in your life.
... You can increase it by replacing said coffee with beer.
Old 02-24-2017, 02:03 AM   #24 (permalink)
Default Max blade length
Thank you for the answer!
I have an other question about the main blade.
I'm working on a new scale-project with the Align 3 Blabe Main and Tail head.
The Align standard 3 Blade are 690mm
It will work also with 720mm or I will have Problems with the tail blade?
I saw a Nitro with 710mm, but the Nitro has a 15mm longer Tail boom...
Old 02-24-2017, 02:09 PM   #25 (permalink)
The Align 690 3-pack is the best for 3D performance.
But, most other blades will be heavier and more stable
The head itself is advertised for 700 / 800 - so I assume you could fit much longer blades that 690 / 700 and not worry about the head having a mechanical failure.
I used to use 710mm blades on my T700N v2 with 105mm tail blades without problems.
I don't think the 3-blade blade grips are any wider then 2-blade blade grips - so I would try it.
Old 03-01-2017, 01:43 PM   #26 (permalink)
It's me due to is my first experiencie with the 3 blade .....or is difficult to place the 3 blades in the blade holder?..
It's an easy job or needs some trick?
Thanks in advance
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 03-06-2017, 08:28 PM   #27 (permalink)
Thanks in advance
I am not sure what the "blade holder" is
You mean the EPS foam holder that mounts on the tailboom and holds the blades when they are folded back?
It is designed for a good fit with the 690mm blades
Or the main blade grips?
Those are also designed for the 690mm blades, but any blade that is designed for the Trex 700 should fit fine.
Old 10-11-2017, 01:15 PM   #28 (permalink)
Hi
Which gear tail ratio are you using with the 3 tail blade rotor ?
thanks in advance.
Old 10-13-2017, 11:48 PM   #29 (permalink)
It has been awhile since i had to calculate it. But it is the new slant tooth black main gear and pinion.
I want to say 8.1:1 (??).
Old 10-15-2017, 06:35 PM   #30 (permalink)
tail ratio: 21T , 22T , 23T?
Old 12-12-2017, 02:22 AM   #31 (permalink)
Hi m8. How is the 3 blade flying compared to stock ? Easier to bog engine ? . Also do you have any videos ?
Helicrow is offline        Reply With Quote Quick reply to this message
Old 02-21-2018, 12:35 AM   #32 (permalink)
Default Rotax
Sounds a bit like a Rotax powered LSA. Not all the time but I hear it. We have a few at our airport and they are called "ramp lice". It has the same sound on occasion.
dirtcurt is offline        Reply With Quote Quick reply to this message
Old 04-06-2018, 07:50 AM   #33 (permalink)
@ticedoff8
How is going with the Zeal 690s?
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 03-14-2021, 12:56 PM   #34 (permalink)
Please could you help me do you no the part number as I am thinking of having 3blades on tail though you could use the one witch is no the helicopter kindest regards Richard
Richard 22 is offline        Reply With Quote Quick reply to this message
Old 03-14-2021, 07:47 PM   #35 (permalink)
Start here:
Shop Align - 3-blade setup for Trex 700
You want the Align H70T008XXW 700E Three Tail Blade Set
