Go Back   HeliFreak > R/C Electronics Support > EZNOV
EZNOV EZNOV Support Forum
Old 10-25-2015, 11:45 PM   #1 (permalink)
Default ***RESCUE MODE fixed ***** look inside
After alot of experimenting with grumpyoldman we have come up with the solution to this problem
1. Yes it is vibration not the neuron
2. Seems to be mostly when mounted on the back of the tailcase especially torque tube belt seems less effected
3.after trying alot of different tapes eg my usual 3m or 3m gel red 1 or 2 layers make no difference
4.we have found some of this tape
5. Going back to nitro days with 1 layer of this and a aluminum plate and 1 more layer seems to work nicely
And yes i hot glue as ive had them come out before anyone asks
This has worked on 2 trex 500 pros and it has fixed both of them
Videos to come
Thomas you owe us
"So What is 3D Flying"
Definition: 3D as applied to current rc helicopter flying is any maneuver that to be performed requires the constant harmonized input of three or more controls simultaneously while the maneuver is taking place.
satchy is offline        Reply With Quote Quick reply to this message
Old 10-25-2015, 11:46 PM   #2 (permalink)
Post saved for videos
Video one
Watch "Neuron rescue problem" on YouTube
https://youtu.be/floGui4GAQo
Video two
Watch "Neuron on the bench" on YouTube
https://youtu.be/iD-JD6UyoNo
Video three
Watch "Neuron fixed" on YouTube
https://youtu.be/QawTmBk4wio
NEW VIDEO explaining why the servos don't go up all together
Watch "Neuron rescue servos wonky is normal if not level" on YouTube
https://youtu.be/mxUEvpj-da0
If anyone wants the tape and plate sent to them ready to go pm me but you're looking at $40 otherwise not worth my time thanks
Old 10-26-2015, 06:47 AM   #3 (permalink)
Why does it still go wonky on the bench with no motor running? Why did a known good unit work on diffirent helicopters, but a known defective unit does not work on the same helicopters? All these questions are still not answered and a metal plate and tape will not fix any of these questions we have..
VControl
Old hand at Planks
Peter
Old 10-26-2015, 07:10 AM   #4 (permalink)
^^^^^^ end user if not get another unit if it still happens you don't know how to use the gyro maybe try another gyro brand or try planks as i see that's why you purchased it in the first place.....
Old 10-26-2015, 07:13 AM   #5 (permalink)
Also if it goes (wonky) on the bench check your servos on a servo tester what servos are you running ?
Old 10-26-2015, 07:40 AM   #6 (permalink)
Get some video up, we may be able to help, if indeed it is a defective unit or units then send them back !!
Steve
Trex 500 Pro Neuron
Trex 500 Pro Vbar
Futaba
grumpyoldman is offline        Reply With Quote Quick reply to this message
Old 10-26-2015, 11:02 PM   #7 (permalink)
Take exception into blaming me and stating that I do not know how to use a gyro!! Been in this hobby since childhood and helicopters since 2007.....
VControl
Old hand at Planks
Peter
Old 10-27-2015, 02:42 AM   #8 (permalink)
Omg you should change your name to whinger it would make more sense !! I wasn't having a go at you im trying to help you ...
It just annoys me how people quickly dis the product and not actually set them up correctly
Like i said if you believe it's faulty get a 2nd and try that if they both do the same thing it must be something in your setup or hardware related mate
And like Steve said maybe a video or two so we can see what's happening
Old 10-27-2015, 09:53 AM   #9 (permalink)
Sweet ... one of the other brands have the same vib issue whe.n in SL they use a Milton Mod wich is Zeal thick gyro tape and a strap or zip tie ...
Sounds like you have a GOM mod !
kayakboy69 is offline        Reply With Quote Quick reply to this message
Old 10-27-2015, 11:17 PM   #10 (permalink)
This decision says about the imperfection of the alignment algorithm
If you cannot write the log of the vibrations, we may have the opportunity to show a level of vibrations via the existing LEDs?
AndreyI is offline        Reply With Quote Quick reply to this message
Old 10-27-2015, 11:35 PM   #11 (permalink)
Andreyl, isnt there another location possible to install the neuron or isn't it on the tailcase with a 450l? My gaui is probably far from vibration free but self level works perfect with the unit on the bottom plate.
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 10-28-2015, 10:28 PM   #12 (permalink)
Tried THREE units, two does not rescue upright and ONE DOES..... Swopped between helis etc etc, go read all my posts in the rescue problem thread. No need to video anything as it was all explained over and over in the other thread.
Name calling not the HF motto.......
VControl
Old hand at Planks
Peter
Old 10-29-2015, 01:23 AM   #13 (permalink)
One works fine? The others not? Send them back. Where is the problem? Why whining so long?
Sounds strange, but possible...
Tele repair does not work in real.
LarsBraun is offline        Reply With Quote Quick reply to this message
Old 10-29-2015, 05:25 AM   #14 (permalink)
I'm glad I'm not the only one
I didn't name call you i was trying to help you sitting there saying videos are no good really doesn't help ....
I did read all your posts and i agree with Lars
Old 10-29-2015, 09:58 AM   #15 (permalink)
At 450L neuron it is convenient to put only on the tail. This is due to the located connectors.
If someone have done anything different, please show photo.
Old 10-29-2015, 02:01 PM   #16 (permalink)
Here is a link to how I installed a Spirit FBL on bottom plate on a Trex 450L. You can do the same thing with the Neuron, which has the same connector positioning as the Spirit.
https://www.helifreak.com/showpost.p...69&postcount=3
Not that this puts the FBL controller directly under the main shaft, which is probably the best location to avoid vibration problems.
FrankFuss is offline        Reply With Quote Quick reply to this message
Old 10-29-2015, 03:06 PM   #17 (permalink)
Thank you!
I will try to put the same.
Old 10-29-2015, 06:00 PM   #18 (permalink)
Thank you!
Replace the button head cap screws with standard cap screws. The button head cap screws take a smaller driver and can be hard to get out.
Old 10-31-2015, 10:28 AM   #19 (permalink)
Hi, I just setup my goblin 380. Tried the rescue function on the bench. The swash plate goes to forward position, when activated. Does this make sense. Thank you for your support.
Goblin 380 Neuron Test Rescue Function (0 min 28 sec)
TimmBerlin is offline        Reply With Quote Quick reply to this message
Old 11-01-2015, 05:51 AM   #20 (permalink)
Timm if you lift the goblin at front alittle do they all go up together ???
If so that's how it's supposed to work
