LiIon, LiPo, NiCd & NiMh General General Battery Support |
02-21-2017, 06:40 PM | #1 (permalink) |
X2 Mean Well SE-450-24 w X2 1000 watt charges setup ?
So i just picked up X2 Mean Well SE-450-24 AC to DC Power Supply Single Output 24 Volt 18.8 Amp 451.2 Watt
What should i expect for output ? i'm guessing around 4c MAX on a 5000mah lipo? so what maybe just under 18 amps? for loss of efficiency and one more volt on battery side? I have 2 1000 watt chargers. but it looks like I will only be using them at a max of 500 watt with just one P/S per charger. I could put them in parallel but then you need to isolate something right? sorry, just trying to jump in head first and could use some help. Thanks
Blade 300CFX, 450. Align: 450pro(3S), 500(6S), 600E(12s), 600N, 800E(12S). X-cell: Ion700(12S) |
02-21-2017, 08:30 PM | #2 (permalink) |
I just use this (link.. the 24v48A model) for home charging and deep cycles for the field. http://www.feathermerchantrc.com
Maybe some info you might need is here http://www.tjinguytech.com/my-projects/HP47A
"It's not just a hobby... it's a lifestyle" - Pete ϟ MINNESOTA! Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 306b / Deep cycles |
02-22-2017, 11:16 AM | #3 (permalink) |
Thanks Slyster for the info
03-24-2017, 03:31 PM | #4 (permalink) |
So i looked into those link and that is for the server PS.
I am not using a server PS, I'm using the mean well PS my question is about hooking up (2) 24 volts PS in parallel not series then the parallel wires will feed 2 1000 watt charges. my guess is nothing special is required? maybe since they are not Server PS? if someone can just confirm?
03-24-2017, 03:32 PM | #5 (permalink) |
I have 2 of these
[ame="http://www.ebay.com/itm/122289390447?_trksid=p2057872.m2749.l2648&ssPageNa me=STRK%3AMEBIDX%3AIT"]Mean Well SE-450-24 AC to DC Power Supply Single Output 24 Volt 18.8 Amp 451.2 W | eBay[/ame]
