Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Like Tree8Likes
Old 05-03-2017, 01:57 AM   #61 (permalink)
Awesome news!
Maeg is offline        Reply With Quote Quick reply to this message
Old 05-03-2017, 05:55 AM   #62 (permalink)
Thanks Gert - thats great news
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 05-03-2017, 06:33 AM   #63 (permalink)
Great indeed. Thanks Gerd!
I'm pretty excited about it. Sounds like I'll be able to have one in the air before this season is over :-)
corrosionate is offline        Reply With Quote Quick reply to this message
Old 05-03-2017, 07:31 AM   #64 (permalink)
Originally Posted by Gerd View Post
We are in time. Estimated shipping of first kits was planned from beginning for June. Preorders are in our shop and Chuck is taking preorders as well.
We have removed pics because the optic and some inner details have changed since the first prototype. During the next days the homepage will be updated.
Excellent
A\ziz - Citizen 672
Minicopter Diabolo 700 Black, SAB Kraken 700, Kraken 580, Minicopter Diabolo 600, Minicopter Diabolo 550, Henseleit TDR Mark II, Henseleit TDR
Jeti DS24 / VControl Touch
aziz76 is offline        Reply With Quote Quick reply to this message
Old 05-12-2017, 12:06 PM   #65 (permalink)
600 questions,
Is the frame ,head and gears all the Diabolo ?
Can we use this 600 boom assembly on a 700 Diabolo ?
Can we use the 550 belt and parts on a cut down 600 boom ?
Thx Tom
Diabolo S # 1 & 77
Diabolo 700 Sportmen - Diabolo 700
Tribolo 800 - Diabolo 550
7hvman is offline        Reply With Quote Quick reply to this message
Old 05-15-2017, 06:48 AM   #66 (permalink)
Default New Diabolo 600!!
Not that I know any of these answers for certain, but in looking at the photos posted, I think the following to be true:
The head looks to be the 550 head, as I don't see any shims where the blades mount. The 700 head uses shims even for 700mm blades, so would really need them for 600's.
The tail box definitely looks a bit different than the others. My guess is that it'd use the same diameter boom as the 700, only cut down. The wider boom at shorter length should allow for the lack of boom supports.
Not a clue on the frame, but I suspect a 700 frame using all plastic gears could possibly be light enough to be feasible for use for a 600. It's certainly small enough. but There was mention of a manually adjusted belt tensioner and quick change belt system, so there are likely at least a few changes to the frame, if it's not a completely new frame. The longer frame could possibly make a 550 belt length feasible too, but of course Gerd will have to answer that.
Edit: looking back, the frame does look quite a bit different. It looks narrower, because the tail servo sticks out farther. Also, the cyclic servos mount differently, more like how the 550 servos mount, but I believe they're full size servos. So it may use the 700 drivetrain gears, but the frame appears to be totally different.
Again, these are just my speculations based on what I see in the photos which Gerd said may not be applicable any more, and comments on what MiGHt be possible, based on those speculations. Until we see kits or Gerd answers, that's all we can do
Old 05-15-2017, 07:25 AM   #67 (permalink)
Originally Posted by 7hvman View Post
600 questions,
Thx Tom
You can contact Gerd direct
|Michalis|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 05-15-2017, 11:42 AM   #68 (permalink)
I am sure we will get the information very soon once its finalized. If all goes as planned we may see the heli in a month from now.
Old 05-15-2017, 02:27 PM   #69 (permalink)
600 questions,
Particulary. The frame is 56.5mm wide (550=52mm) to accept a 45 size motor (but not necessary).
The head is a mixture from 550 and 700 with new blade grips.
The second stage gear wheel is from the 700, but with other pinion and the first stage is a new gear wheel with the usual motor pinion.
600 questions,
Thx Tom
Both a 30mm in diameter if you mean that.
600 questions,
Yes, of course you can use the belt.
minicopter-Support
Gerd is offline        Reply With Quote Quick reply to this message
Old 05-17-2017, 12:53 AM   #70 (permalink)
Gerd, if there are new gears what is new total teeth count?
So I can work out which motor and pinion to buy.
chris-green is offline        Reply With Quote Quick reply to this message
Old 05-24-2017, 12:21 PM   #71 (permalink)
Sure, reduction = 197.8 / Pinion teeth
minicopter-Support
Old 05-27-2017, 09:48 AM   #72 (permalink)
Nice. I think a Pyro 650-65 Competition will go into mine, with an 18t pinion. Light weight power
A\ziz - Citizen 672
Old 05-28-2017, 07:45 AM   #73 (permalink)
Miles beating the $&%# out of the 600:
Diabolo 600 (3 min 50 sec)
Diabolo 600 2 (3 min 41 sec)
Old 06-01-2017, 08:55 PM   #74 (permalink)
The minicoptr site has been updated :-). Lots of close up pics :-)
I'm a bit puzzled by the clamp thing on the back of the frame on the boom. Maybe something to do with the adjustable tension Gerd mentioned?
Looks sweet :-)
http://minicopter.de/en/diabolo600
Old 06-01-2017, 11:54 PM   #75 (permalink)
CHC Benefactor
Thanks for that. Looks nice. Maybe time to rationalise my fleet
Old 06-02-2017, 03:06 AM   #76 (permalink)
A winner for sure... I can't wait
Old 06-02-2017, 03:24 AM   #77 (permalink)
looks very good to me. Makes the wait time even harder
Old 06-02-2017, 04:13 AM   #78 (permalink)
It sure looks nice. I like that the frame comes in two pieces an upper and a lower part.
Do you guys think that 6s setup will strain the pack?
|Michalis|
Old 06-02-2017, 04:41 AM   #79 (permalink)
What will be the final design of the canopy?
Rasim Ozturk
[Prôtos Max V2][Prôtos 380 Evo][OXY3 GL][Vbar Neo][Vbar Control]
rasheem is offline        Reply With Quote Quick reply to this message
Old 06-02-2017, 04:59 AM   #80 (permalink)
The two design options are on that link. So your choice.
