Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info |
04-10-2017, 07:21 PM | #1 (permalink) |
Trex 500 5 blades set up.
Planning to convert my T500 to Tow Defender. i need help picking and finding the good parts.
1. 5 blade head: where and what brand? can i use a regular align main blade or i need to get a scale skinny blades? 2. Scorpion motor: which model and how much Kv? 3. ESC is the castle 60 is enought? 4. pinion gear; how many teeth?
Trex 500 AW1 cobra ,Trex 450 pro MH-6,Trex 450 SE Apache,Trex 450 Sport MD 500,120 SR Seahawk, MCPX, DX8.Dji phantom. |
04-12-2017, 03:22 PM | #2 (permalink) |
With a ScaleFlying fuse? Even if not, they have quite a few MD500 based kits and I would check with them for what they recommend on the head and blades. You might get a faster response here if you post in the scale forum.
On the ESC and gear train, it's all about knowing what HS you want to fly. Once you know the HS, you can figure out the options for motor/pinion combinations that will get you there. ESC should then be based on motor specs, although you can certainly cheat a bit for scale flying. I assume a 60 is in the ballpark.
Compass Atom 5.5; Oxy 2/3/4 XK K110 K120 |
04-12-2017, 08:40 PM | #3 (permalink) |
Thank you for the reply. nope i never get a reply in scale flying section.
04-13-2017, 06:06 AM | #4 (permalink) |
Ok... so I would definitely check the few scale vendors like ScaledFlying to see if they have recommendations on the head. If they do, they would probably also have a recommendation on the right HS for a 5-blade. Once you have that, everything else will fall into place.
