Go Back   HeliFreak > R/C Electronics Support > EZNOV
EZNOV EZNOV Support Forum
Old 05-21-2017, 12:33 AM   #1 (permalink)
Default YGE Gov Store and Neuron
I just picked up Neuron Eznov for my 470L. How do I setup YGE Gov Store with Eznov? Currenty I'm getting 6 beeps on my ESC.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
norstaroption is offline        Reply With Quote Quick reply to this message
Old 05-23-2017, 08:22 AM   #2 (permalink)
I forget what the different beep sequences mean.
I used A YEP ESC with an earlier model. I used the ESC's gov without any problems.
I kept the Neuron's gov disabled, set throttle range (with 0-100 linear throttle curve) using the program card, and then prompted the ESC to go into gov store, using the card. Then you connect a battery charged to 4v/cell (?), and run your throttle up to 100. As you plug in, you'll hear a single beep/sec while it is waiting to store an rpm. After speeding up to full throttle, you'll hear the motor "kick" once it settles in (the LED on the ESC may do something too). Then disconnect the battery, reset your throttle curve, and it should be set.
I may have had to power the Neuron separately, before powering on the ESC on the initial setup. I found resources on YT, here, and elsewhere to help guide me in this process. As I recall, it was a bit of trial and error- so I'd advise attempting this setup when you have some time, and are in a good mood.
(PM me if you have trouble and I'll try to help more.)
Not sure if that helps you, but I did get mine to work well.
-b
Flying > Crashing
(well, I'm working on it...)
KDS Chase 360, Gaui X3L 3 blade head & tail, KDS Agile 7.2, Spektrum DX8g2. Citizen 740.
heli-b is offline        Reply With Quote Quick reply to this message
Old 05-23-2017, 10:41 AM   #3 (permalink)
Thank you, I was able to get it working after many tries and sometimes the will motor cut out before reaching 100% headspeed. I believe that's a known issue with this FBL system. Also I had the FBL in the Soft Start with Gov instead of Direct Control.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 05-23-2017, 11:15 AM   #4 (permalink)
Hello,
Could you send us the complete configuration you are using and the exact symptoms (motor cut out) by e-mail at contact@eznov.com
We are actively investigating the issue.
Thomas.
Otatiaro is offline        Reply With Quote Quick reply to this message
