Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Scale Projects <790
Scale Projects <790 Scale Projects <790 Discussion
Old 04-05-2017, 03:55 PM   #61 (permalink)
Nice job! Mine only needs pilots and Windows 👍🏻
MartinHansson is offline        Reply With Quote Quick reply to this message
Old 04-05-2017, 03:59 PM   #62 (permalink)
Wow. ..nice cockpit
SYMA S-107/BLADE (2)450 3D FBL/ALIGN(3)T-REX 500 (2)T-REX 550 T-REX 700L V2/DX8
SCALE
MD500(450) UH-60/AS350/BO105(500) A109(600)
Windmanquebec is offline        Reply With Quote Quick reply to this message
Old 04-06-2017, 12:38 AM   #63 (permalink)
Thx it turned out great
Old 04-06-2017, 07:10 AM   #64 (permalink)
Do you have a photo with your battery installed? Because me I had to cut some part of the cockpit center console for my battery to fit
SCALE
Old 04-06-2017, 11:48 AM   #65 (permalink)
I had to remove some of the cockpit to make a fit Its tight. I'm running 6s5200mah to get the CG right and i put in 350gram og led to make it fly good
Old 04-06-2017, 12:26 PM   #66 (permalink)
Can you give me a farther look?
What size battery you have?
I have a 4400 mah
SCALE
Old 04-06-2017, 12:49 PM   #67 (permalink)
I use 5200mah. I'm talking my mecanics out in the next days, i want to change to torque tube - be Aware of this cheap align chap! Luckely i happeney under spool up on the Ground.
Im Giving this a try looks more robust Its from rc aerodyne
Old 04-06-2017, 12:50 PM   #68 (permalink)
Il post more pics when mechanics is out
Old 04-06-2017, 12:51 PM   #69 (permalink)
Mine is an Heliartist
...much beafier
SCALE
Old 04-06-2017, 03:01 PM   #70 (permalink)
Hmm Can that be orderet seperately?? My fuselage is also heliartist but the mechanics is from an plader project. Dont recall getting that Bent torque included?
Old 04-06-2017, 03:36 PM   #71 (permalink)
This is the p/n HA500STG
SCALE
Old 04-06-2017, 04:51 PM   #72 (permalink)
Thx found it
Old 04-16-2017, 07:50 PM   #73 (permalink)
I finally decided not to go with the cnchelicopter 4 blade tall...the company says it will be ok at hi speed. I wont take the risk of flying that $1500 bird with a loose slider like that. Jeff at XM Hobbies accepted to refund me.
So I installed the oem align 2 blade tail system.
Yesterday I did my maiden flight. With the weight of the body, the scale blade don't get me safe lift at 1700 rpm. I decided to use normal 425mm blades. With them I get better lift without increasing the rotor speed.
Final weight: 3.528 kg without battery
4.208 kg with 4500 mAh nano tech battery
Flight time with 20% left in the battery: 00:10:30 hrs
Here is the video I made out:
[ame="http://www.dailymotion.com/video/x5ihvzk_uh-60-maiden-mission_tech"]UH-60 maiden mission - Video Dailymotion[/ame]
SCALE
Old 04-17-2017, 04:20 AM   #74 (permalink)
Hey I had the same issues with the Cnc tails I got the one you purchased and the Apache style for well my Apache. Both had terriable pitch sliders. I ended up mixing parts from my align slider and modding it to fit their housing and it works beatifully. (After removing all the glued bearing) when I contacted cnc about the issues he said "fly it it will we fine" like you I want willing to risk so I just rebuilt to my standards. https://www.helifreak.com/showthread.php?t=760527
Bm421 is offline        Reply With Quote Quick reply to this message
Old 04-17-2017, 07:31 PM   #75 (permalink)
Sorry couldn't figure out how to pm pics so here it is. As I said in the pm this can be easily done with a dremel, fine file, a drill and green 648 retaining compound or similar. Click image for larger version
ID:	703654 you will need a pitch slider assembly and a extra slider bushing (white) cut where the red lines are use the dremel to work those side to get them close to the rounded areas where you didn't cut. Then with the extra busing thread the cut piece onto it and put the extra bushing into the drill setting the direction of rotation so the when you apply pressure it threads on. Carefully take down the high spots and slowly work it till it a press fit. Then most importantly clean everything very well use the green 648 and allow full cure time. Don't rush this process without a lathe shut or with one. Lol Click image for larger version
ID:	703653 this is the end goal to make a press fit threaded insert to allow the use of the align bearing and bushing. Any more questions please feel free to ask!
Old 04-18-2017, 12:35 AM   #76 (permalink)
You lose me from here
on what part you thread in the extra bushing?
the align one ( the cut piece) already has a busing in.
You need to remove the brass bushing and the bearing holder with the ball on the cnc parts, how you do that? you drill the brass bushing from the opposit side of the bearing holder?
SCALE
Old 04-18-2017, 07:18 AM   #77 (permalink)
Use the extra bushing in the drill so one doesn't get messed up by the chuck.
Old 04-25-2017, 06:30 PM   #78 (permalink)
Finally here is my maiden flight
http://www.dailymotion.com/video/x5i...n-mission_tech
SCALE
Old 04-25-2017, 07:24 PM   #79 (permalink)
Awesome! Love the radio chatter. Were you able to make heads or tails of the cnc tail mod
Old 04-25-2017, 07:25 PM   #80 (permalink)
Thanks...no I made that flight with a 2 blade tail
SCALE
