CB100 Walkera CB100 Helicopter Support |
01-04-2012, 11:54 AM | #1 (permalink) |
Is the 2801 Pro worth buying for the CB 100?
I am wondering if I should spend the extra money to get a 2801 Pro or should I just use the stock one?
My current heli's and equip are: Carbon Edition Belt CP V2 - On its' way Belt CP V2 green box (kit) - " " Spektrum DX8 Walkera V200DQ02 - Currently flying and figure I could use the 2801 Pro with it. Going to order - CB 100 from Wowhobbies with all the upgrades (2.9g tail, ect.) I figure I might as well go big and get the kit for $419 with the 2801 Pro, extra blades, batteries, and an aluminum case. Thanks for any suggestions and ideas. I'm trying to buy the best electronics so they can be used later on other more advanced heli's/planes. Hence the reason I bought the Spektrum DX8 for $325 (used once, but everything is still in the original box with everything still in plastic. |
01-05-2012, 05:34 PM | #2 (permalink) |
yes if plan on buying more advanced heli's from walkera that are 2801pro compatible.
you should look into it........... |
01-05-2012, 08:08 PM | #3 (permalink) |
I think a decent Tx, like the WK-2801 Pro, gives you the ability to set and fine tune various settings for your helis, plus the smooth and consistent feel of the sticks helps your flying.
I use the WK-2801 Pro for my V400D02 and my Genius CP. Been very happy with it. For all my E-flite / Blade / Horizon Hobby stuff, I use a DX7. Also a great Tx. Both are so much better than the plastic-y feeling stock Tx's in my opinion, but keep in mind, the WK is only ever going to fly with Walkera helis.
01-07-2012, 05:09 PM | #4 (permalink) | |
01-10-2013, 03:44 AM | #5 (permalink) |
Pick up a Devo 8s or a Devo 10. Then install this custom firmware http://www.deviationtx.com It lets you control WK2401, WK2601, WK2801, Devo 6/7/8/10/12, DSM2, DSMx (in the works), and Nine Eagles J6 Pro without ANY modification to the TX. Its badass. I have a CB100 with a Devo 8s. The firmware even turns my Devo 8s, to a 12 channel radio, that supports 255 models. VERY VERY COOL.
01-10-2013, 10:20 PM | #6 (permalink) | |
Re: Is the 2801 Pro worth buying for the CB 100?
Sent from Mars. Using Mars Rover.
When you are lying on the floor there is no place to go but up! Trex 480 Pro DFC, RoBird, Devo 10 Deviation 3.0, Trex 450 Pro DFC, AR7200BX, Devo 10 Deviation 3.0 |
