KDS Agile 5.5 KDS Agile 5.5 Discussion |
10-27-2015, 12:17 PM | #41 (permalink) |
my today set up
Scorpion 4025 1100kV jive 100 lv mks 7200 bx 5000 / 45c gensace , too rapidly used ..., 6S so Idecide to try my stock 600 mx and 80 hv on topfuel 10s first tests nextly , I will tell you |
11-02-2015, 02:35 AM | #42 (permalink) |
I originally set mine up with a Vbar, BLS351s and a BLS251 running on 6S with a YEP120lv and a scorp 4025-1100. I found this set-up to be fairly rough on packs because it's a heavy little heli so I upgraded to a yep120hv and a scorp 4035-560 on 12S with 2700mah packs. With this set up the heli was a beast and menace to society. I recently stretched it with a logo 600 boom and some 7.2 parts so it now runs 620/105s and it's awesome. I'm getting 3.30mins of 3D with these small packs so when they eventually die I'll probably go for some 3700s.
Lots of X-Cells and little sense. |
11-02-2015, 05:04 PM | #43 (permalink) |
Interesting setup. Happen to have the same motor laying around, may not sell it after all.
Paul Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD |
11-16-2015, 01:59 AM | #44 (permalink) |
My new Agile for 30s
My setup:
KDS stock motor 1100kV HW platinum 120 hv with WR BEC Align 615 & Futaba 251 with Turnigy 3dh 6S5000 / 40c revo I have a lengthy query though so please bear with me: I have installed WR BECs for all my 8 700-sized helicopters since 2008 without any issues. Every unit has been flawless. Over the weekend, I acquired the KDS Agile 5.5 so I decided on the Hercules Super BEC WRL-HBECCS7 to power the electronics at 6v each. However, as I was changing the dip switches on the BEC, I noticed that the voltage reading would behave erratically and jump from the preset 7.4v to 5v. I have tried it different lipos ranging from 3s-6s lipo all with the same adverse readings. In addition, whenever I touched the dip switches with the pincher, the voltage reading would jump and I also noticed that there was some kind of glitching sound emitting from the unit as if a component/s had been soldered incorrectly. I have tried pitch-pump the servos during setup and there were no brownout issues on the rx. Despite my suspicion that something is not right, I went ahead to use the WR BEC yesterday and 30s into the maiden flight of my new Agile 5.5, the esc cut off prematurely which resulted in a crash. It was disheartening to see all my efforts in building the heli and setup gone in an instance. And I also lost an expensive lipo in the process. I am NOT insinuating that WR BEC had caused the crash but is it possible that the esc cut-off was caused by the BEC glitch (if any)? Many thanks in advance for advice rendered. Peace be to all.
Heli-ADDICTION: Xxtreme700, X7F and all Logos & 600esp (初恋) Feeling of Hover at (28/12/2009) - PRICELESS! |
11-19-2015, 06:22 PM | #45 (permalink) |
Sure sounds like a BEC problem mainly because of the erratic behavior prier to your flight. Even the best will have a rare one that slips through bad. Once you get her in the air again your going to love the way she flies.
KDS Agile 5.5, Ikon, KST, KDE motor/Gaui X4ii, BK servos, Brain / Gaui X3, Ikon, KST, Scorpion 1580Kv Frsky Taranis plus PhoenixRC upgraded to wireless |
11-24-2015, 10:55 AM | #46 (permalink) | |
The 600 mx on 10s , very very very cool , not what i like ... but 510 kv is 510 kv , so I decided to stay with my 10s and to increase the kv , so I ordered a X nova 4025-670kv , just to see , with the doubt of the lying time Tests today , 3 flights... hacker topfuel 20 c 3000 mA 5s x2 : 4 minutes , but intensiv 2300 rotor speed , and power With 1800 rotor speed i think 5 minutes is possible 50 gr more with this energy , I really love it 6s or 12s....or anything between ciao |
11-25-2015, 01:52 AM | #47 (permalink) |
Hi Larryu, Thank you for the reply. It was the faulty WR BEC which i have changed out to a CC BEC. Flawless for 7 flights thus far and heaps more to follow. I really love this bird!
12-23-2015, 06:40 PM | #48 (permalink) |
Okay I thought it was time I posted my set up I don’t think I’ll be changing anytime soon I’m running 6S Turnigy 5000mAh Heavy Duty for about 6+ min flight time coming down with 3.78 volts, I started out with a KDS 1100KV but found a deal I couldn’t pass up on a KDE motor and yes it does have more power with about the same flight time.
KDE 1100KV Hobbywing Pro 80A Ikon KST 725HV cyclic KST 525HV tail CC BEC Pro RJX 550mm main blades and stock tail blades I have a set of Cyclones but haven’t tried them yet.
12-23-2015, 07:34 PM | #49 (permalink) |
You'll love the Cyclones.
Agile 5.5, Logo 550sx, X5, Goblin 500, Oxy 3, Trex 450proV2, 250DFC #309 |
01-05-2017, 09:54 AM | #50 (permalink) |
New 5.5 set up
Blades- Rotor tech 560mm/95mm tails Motor- Stock KDS 1100KV FBL- E-bar v2 (worth a try since it was free) Cyclic- KST 725 Tail- KST 525 ESC- Castle Talon 120 (fan/5v bec) Battery- Gens Ace 45c 5000mah 6s Connectors- rcproplus S6 2100-2300-2500 Head speeds
MSH Protos Max V2 Evoluzione 700 Goblin 500 carbon sport T-rex 470L V-bar Control |
02-13-2017, 01:31 PM | #51 (permalink) |
Here is my setup and still in the build.
- Kit Stock (550mm RJX blades) - Align ds615s on the swash - Align ds655 on the tail - Xnova 4025 1120kv - Hobbywing 100a V3 with fan and internal bec at 6.0v(cheap solution for now on) - MSH Brain - Optipower backup guard - Gens ace 5000mah 45c 6s - RX Futaba R3008SB - TX Futaba T10J |
04-24-2017, 03:44 PM | #52 (permalink) | |
- Normal: 2300 - Idle 1 : 2500 - Idle 2 : 2800 Collective 12deg Cycic 9deg It flys great ! Awesome machine ! Grtz Florian
Agile 5.5 6S Brain2BT Xnova HW100A v3 | Trex 450L 6S (380mm) Streched Brain HW50A v3 | Trex 150 | Esky HBK 2 with align dfc head, 3gx and Esc |
04-26-2017, 07:37 PM | #53 (permalink) |
My setup
Align 750MX on 12s ya its got power Bk Servos Ikon v1 Halo 610 or Rail Blades 626mm 3-95mm Halo tails RC-Tec ( Bob's ) custom made 3 blade tail unit 2 - 3400 HV LiPo's 1- 2200MA 2S X4RSB X12S I maybe down sizing this bird back to a 6s 550mm setup only to share batteries with its bigger brother....
KDS Agile 6.4 Proto-Type 750MX 12s with an Ikon / KDS Agile 7.2 / Tarot-Align 600CF-FBL Robird G31 12S / The First X3-385 FROM AUTO-CAD to DIRT NAP in 10 SECONDS ! |
05-27-2017, 04:46 PM | #54 (permalink) |
I have went back to the 640 mm Blades..... I must say its better ......very low disk load !
01-21-2018, 11:44 AM | #55 (permalink) | ||
Stretched to 600 - Logo 600SE tailboom - Agile 7.2 TT (cut down) - Agile 7.2 boom supports (cutdown) - CF control rod - 20T motor pinion - HW ESC 130A v4 - Align 600mm main blades - Zeal 96mm tail blades - Headspeeds 1800 2000 2300 (+/-20% headroom) - RX Futaba R7003SB - TX Futaba 14SG - MSH Brain Telemetry Fly's Like a Charm ! Amp Peaks at 170-180Amp with hard tictocs but dont do them that hard normaly (just for test). Normal 3d en full pitch pumps max 150Amp. Grtz Florian
05-12-2018, 09:57 PM | #56 (permalink) |
Working on the tuning now.
HW 120a v4 KDS 1100kv BK 7001hv on the cyclic BK 7005hv on the tail BD hc3x FBL unit Switch 553s and 95s KDS v2 gear hub and one way Normal - 2100 IU1 - 2250 IU2 - 2400
Spek iX12 | DX7G2 | NANO CPX | NANO S2 | MCPX BL2 | 120SR | Fusion 270 | AH64 Apache (450) | D380TBR | 450X | OXY 4 "360" | Goblin 420 | 500X | 550X | AGILE 5.5 | OXY 5 | AMA# 1157132 |
