Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > MSH Protos 700/800
MSH Protos 700/800 MSH Protos 700/800 Helicopter Support Forum
Like Tree118Likes
Old 09-11-2016, 09:16 PM   #61 (permalink)
You'd be smart just to use the pitch links...I went through this 6 months ago..
You don't need the servo links anyway, it throws geometry off.
MSH Protos
Xpert-Xnova-Jeti
KSKen is offline        Reply With Quote Quick reply to this message
Old 09-11-2016, 10:11 PM   #62 (permalink)
Servo to swash links are fine. I just need the swash to grips links. Couldn't get tracking just right with stock links and seeing how stock links will be $10 plus the ride I was thinking of upgrading to turnbuckles.
2slow2g is offline        Reply With Quote Quick reply to this message
Old 09-12-2016, 02:43 AM   #63 (permalink)
I use Heli option turnbuckles, they seem to work well with the stock links. If you search in this section there is a thread or two about turnbuckles for the pitch links.
//Dennis.
Sent from my SM-G930F using Tapatalk
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 09-12-2016, 07:05 AM   #64 (permalink)
Installed the satellites on my Max. Now MSH just has to ship the last parts for my Max that I need...
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is online now        Reply With Quote Quick reply to this message
Old 09-12-2016, 10:11 AM   #65 (permalink)
shipping resumes today! I have a couple of brain2 units shipping today to swap 2 of my Max to Jeti intergration
HELIDIRECT - HOBBYWING - XNOVA - XPERT - PULSE - ROTOR TECH
Colin Broughton is offline        Reply With Quote Quick reply to this message
Old 09-12-2016, 06:46 PM   #66 (permalink)
Originally Posted by Stkshkr View Post
Decided to swap the Spirit Pro out to try the Brain and replaced my old Torq's with a new set of BK 8002's. Got it all bench tested today and ready for the field tomorrow. Come on sunrise!
Update: Perfect day to fly. 82 and sunny with a light breeze. Took the Max out to the flight line and pulled the pin flag out of the Gryphon BEC. Got about 5 seconds into the boot and then everything went dead. Still not sure what happened...triple checked everything and have had it wired the same way from day one. The good news is now I have a reason to dump my old YGE and get a HW160
Protos EVO 800
Gaui X3
Stkshkr is offline        Reply With Quote Quick reply to this message
Old 09-13-2016, 09:52 AM   #67 (permalink)
Update: Perfect day to fly. 82 and sunny with a light breeze. Took the Max out to the flight line and pulled the pin flag out of the Gryphon BEC. Got about 5 seconds into the boot and then everything went dead. Still not sure what happened...triple checked everything and have had it wired the same way from day one. The good news is now I have a reason to dump my old YGE and get a HW130
Maybe a bad servo?
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 09-13-2016, 11:23 AM   #68 (permalink)
Are you thinking back EMF that would fry the BEC?
The cyclics are brand new and had been working flawlessly in the setup and bench testing . I used my flight packs during setup too so there was no change there either. Naturally, I'm out of town for the week so troubleshooting is put on hold for a bit...
Protos EVO 800
Gaui X3
Old 09-14-2016, 08:02 PM   #69 (permalink)
Installed a Brain2 and set up Jeti Intergration on my main 700 Max, now to swap the others
Old 09-14-2016, 11:21 PM   #70 (permalink)
Got partway through rebuilding mine, and managed to snap both swash driver links and bend the bottom bearing block trying to get the bearing out.
More parts ordered...
On the plus side, the carbon boom looks amazing. Related, how is belt tension supposed to be set with it? The hole for the tail box is slotted so I could pull it back, but I'm not sure that's a good idea. I'm using the middle hole on the belt tensioner and the spring isn't putting any tension on the belt. It needs to be a bit tighter to get the screw lined up with the hole.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 09-15-2016, 01:40 AM   #71 (permalink)
I looked at my heli today and said: "mwaaa ha haaaaa - lets fly!"
Goblin 570, Protos Max V2's, TDF in the queue - Brain 2 goodness on each, with Jeti DS-14 telling it all what to do...
And remember - If it ain't broke, you need to tinker with it.
johncclayton is offline        Reply With Quote Quick reply to this message
Old 09-15-2016, 07:03 AM   #72 (permalink)
Got all my parts in. Put it back together
Old 09-15-2016, 07:50 AM   #73 (permalink)
Default What did you do with your Protos Max today?
You tension it the same way you do it with the aluminum boom. Loosen the side clamping screws and the two screws in the "spine" to free up the boom block to move.
HeliFreak Support
Graupner MZ-32
Old 09-15-2016, 08:17 AM   #74 (permalink)
Old 09-15-2016, 08:18 AM   #75 (permalink)
Oh, duh. I got it in my head somehow you pulled the boom back in the clamp, not slide the whole plate. I blame not enough sleep.
Thanks!
Old 09-17-2016, 08:10 AM   #76 (permalink)
Set up my new Xpert R2s with a brain2 for my Evoluzione 700 Tri build
Old 09-17-2016, 02:48 PM   #77 (permalink)
Got my 700 back flying again. I was going to sell it but changed my mind. Primarily because it's easy to work on, that's hard to find it seems. Anyway, got a hw130 and a scorpion 4525 520 for it.
Came in at a little over 12 lbs with 4500 pulse batteries.
daboxe is offline        Reply With Quote Quick reply to this message
Old 09-18-2016, 12:04 AM   #78 (permalink)
Kenny had a really bad day at Rotors over Denver..
Had several "freaks" here today and the only thing we can figure is "it went dead".. Don't know why but some said they never heard a heli hit this hard...anyway, wifi here is too slow for pics but it was my green 770 Evo.
I'll upload pics when I have a stronger connection.
MSH Protos
Xpert-Xnova-Jeti
Old 09-18-2016, 12:14 AM   #79 (permalink)
One if those crashes huh , my first max v2 experienced one of those. That crash takes the protos crashes well statement and threw it out in the trash. Man there was very little left. Basically the centre Hub and main grips, and the tail box and a few pieces back there like the side members that hold the tail shaft bearings. Everything else and I mean everything else was smashed or bent severely. Mine was a 13 lb bird and it did a nice long fall into hard earth. Badaboommmmmmmm , dust cloud and the grusome crunching sounds. Now recently my logo 690 what a pile of crap
that is. I messed up some low pyro flips and it's hit the deck at very low speed. It's demolished man. Just stupid. I smashed many goblins way harder than that and they crashed better. And I crashed many times other birds like the way the logo crashed and often times it was under an hour and under 100 dollars back in the air.
jsbach#1 is offline        Reply With Quote Quick reply to this message
Old 09-18-2016, 08:07 AM   #80 (permalink)
Oh no Kenny
