OXY HELI OXY HELI Factory Support Forum |
05-19-2017, 11:22 AM | #1 (permalink) |
Did you Ground your OXY?
Just wondering if any of you guys ground your OXY. I've been flying mine without grounding the tailboom but just read something in the VBAR NEO forum about static.
Protos 380 NEO x2 Oxy 2 Goblin Fireball |
05-19-2017, 11:26 AM | #2 (permalink) |
I haven't seen anyone report that they grounded their boom. Doesn't mean that there isn't someone somewhere, but I don't believe it's common.
Compass Atom 5.5; Oxy 2/3/4 XK K110 K120 |
05-19-2017, 11:32 AM | #3 (permalink) |
If the heli has belt, then there is static too. Never had a single issue after hundreds of flights
|Michalis| ...let the flying be second nature! |
05-19-2017, 12:05 PM | #4 (permalink) |
I lost a Goblin 770 a few years back to static. Ron Thomas at Mikado helped with the diagnosis of it. All of my Goblins are grounded. Some will argue it's presents but is very real. If one researches "van de graaff generator" you will see a resemblance to our belt driven heli booms. Grounding is a cheap fix.......just say'in.
S#!t Creek Survivor, up and back....No Paddle
Fireball 280/ G380/ G500/ G630/ G770/ MD500E 600 Ecureuil AS350 700/ Bell 222 800 Jeti DS-14/ Brain/ iKon- AMA 611227 |
05-19-2017, 12:21 PM | #5 (permalink) |
I grounded all my big helis 500 size and up, but not the small ones. So far I've been lucky after many flights.
05-19-2017, 01:09 PM | #6 (permalink) |
Oxys don't seem to have that issue, or if anyone has have not seen any postings here.
I have been fighting an issue with my G420 just shutting down mid flight or even on the bench, despite 100% change of electronics. Remove the belt and it seems to stop, although have extensively tested that theory. Just got it well grounded last night for a test today. Sent from my SM-N910T3 using Tapatalk |
05-19-2017, 03:12 PM | #7 (permalink) |
Never read of anyone grounding theirs. I don't think I read of anyone grounding other smaller helis, like 470L and bellow. At this sizes its possible there is not enough surface area on the belt and tail boom to create high voltages. It also seems to me on the Oxy the belt and the tail should have same potential as the tail pulley is metal and connects to the rest of the tail assembly. So the voltage across the two should be same. Not sure however.
Nano CPS, Lynx 160CFX, Oxy 3TE, Align 470LM, DX6, Heli-X, 206b+[Dead in 4 month], FMA GT500. Flying since Feb 6th, 2016. |
05-19-2017, 03:35 PM | #8 (permalink) |
No, they don't need to be grounded it's by design
https://www.helifreak.com/showthread.php?t=731375 ________________________________ sactownhobby.com |
05-19-2017, 05:58 PM | #9 (permalink) |
+1
Didn't ground, no static issues. Matter of fact I haven't grounded a heli yet but only flown 470mm 500class or smaller and all we're designed not to need grounding. Nowadays it seems like everyone uses plastic blended with a conductive material to prevent static or uses CF and aluminum.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm ~Problem Child~ |
05-22-2017, 06:27 AM | #10 (permalink) |
Mine is grounded... but not for static, for not having time to fly...
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV) Lynx Team Pilot / Oxy Field Rep |
06-13-2017, 07:45 PM | #11 (permalink) |
didnt ground mine. 700 flights and no problems
06-15-2017, 04:47 AM | #12 (permalink) |
No grounding, no issues in many hundreds of flights. But then again it's not that dry in the UK so YMMV if perhaps you live in a desert.
Goblin 380 KSE, OXY 3, 180 CFX, 130 X, nQX, mCX2 DX8, BeastX, Heli-X, neXt |
06-15-2017, 11:31 PM | #13 (permalink) |
The boom clamping system is plastic so there's no need for grounding. If it were metal the. Yes
Sent from my iPhone using Tapatalk |
06-16-2017, 07:28 PM | #14 (permalink) |
I had some static problems when I first built my Oxy3. Thought I had done something wrong in the build when it fell out of the sky 30 seconds into the maiden flight. After carefull inspection and testing on the bench I could see a spark jumping from the fbl to the frame, so I ran a small ground wire from the tail box to main frame and solved that problem.
It didn't however fix the problem of the fbl being a piece of junk. I was using a ZYX at the time which I could never tuned right so I binned it and installed an Ikon and havent had any issues since. It's possible though that it was a problem with the ZYX more so than an actual static issue. FWIW
Oxy 3 |Oxy 2 |180CFX stock | 450X stock | and a few Planks
