600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
07-15-2017, 08:35 PM | #1 (permalink) |
3 blade head?????
Would this be a good idea for my DFC 600 with YS60SR. The the YS60SR makes really good power but would it be enough to push 3 blades?
07-15-2017, 08:40 PM | #2 (permalink) |
At your own risk. Use the lightest set of blades you can find. 3 Blade puts a significantly higher load on the system from the extra drag alone, let alone the extra blade weight.
Keith - FrSky | OMP | KST | KC3D Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More |
07-15-2017, 08:47 PM | #3 (permalink) |
what size blades would I get? also do i have to by the 3 in a set or can I balance them my self?
07-15-2017, 09:13 PM | #4 (permalink) |
Don’t use two sets of 2 blade blades (rip English). You need to use specifically made 3 blade sets... not just for balance reasons. Using blades designed for 2-blade heads on a 3-blade heli would result in lots and lots of bogging and very slow cyclic. I’d actually try some 550ish size blades which should result in a similar thrust as 2-blade 600 and similar load on the engine. I’d look at the SAB 570 Tri-Blade set. They’re actually 540s, which should as I said result in similar load on the engine.
https://www.amainhobbies.com/sab-540...40-3ds/p479296
07-15-2017, 09:20 PM | #5 (permalink) | |
07-15-2017, 09:22 PM | #6 (permalink) |
550
I always wanted to 550 3 blade with 3 blade tails and 550 boom.
Austin, TX HoudiniRCHeli Podcast |
07-15-2017, 09:30 PM | #7 (permalink) |
Cyclic will be very fast. You might need to increase collective pitch a little to gain pop back as tri-blade typically loses some collective pop and not to mention the blades are 60mm shorter.
07-15-2017, 09:56 PM | #8 (permalink) |
Is it worth it with the blades being 60mm shorter? Will I reap the full benefit of 3blade set up?
07-15-2017, 10:05 PM | #9 (permalink) |
With nitro, it's unlikely that you will anyway. Even a powerful engine such as the YS won't even come close to electric power... and think about it, you're adding a third blade. 50% more rotor mass, 50% more drag.
~550 3-blade would be your best bet unless you don't mind lots of bogging and possible stalling... I would really recommend against simply buying two sets of blades made for 2-blade heads. It will fly, obviously, but probably not very well.
07-15-2017, 10:21 PM | #10 (permalink) |
I'm looking for a more locked in feel or more stable. I'm not going to use other blades. With the 540 blades will I noticed that the heli is more locked in?
07-16-2017, 01:53 AM | #11 (permalink) |
Hi, perhaps do a search in the Goblin forums. There are a number of discussions about 2 vs 3, size of blades, setup considerations, feel etc.
07-17-2017, 12:27 PM | #13 (permalink) |
Yeah, it works.
I have the YS 60SR with the Hatori SAB-1 pipe w/ 30% nitro With 3 600mm blades, it is marginal. I converted to shorter blades using a Trex 550 tailboom assembly and bought a set of the SAB 540mm Blackline HPS3. The picture is the 600N (CHP 600N DL frames) with the 550E tailboom kit installed. The SAB 540 blades are the lightest I could find. Before these, I was matching blades by buying two standard packs and then weighing and balancing them. The pictures show Zeal 550mm blades. These weigh a ton and they killed what little performance I was getting. Even with the SAB blades, It still doesn't meet my expectations The biggest change from 2 blade to 3 blade is gyro gain - the cyclic needs to be tuned down by at least 50% from whatever you are currently running Also, the heli has a more locked in feel on cyclic. It stops cyclic as soon as you center the stick - there is no overshoot. And starts as soon as you move the stick. You run a lower headspeed too - but not by much. It works a whole lot better on a 700N with a YS 120SR-X
By replacing your morning coffee with green tea, you can lose up to 87% of what little joy you still have left in your life. ... You can increase it by replacing said coffee with beer. Last edited by ticedoff8; 07-17-2017 at 12:43 PM.. |
07-17-2017, 07:21 PM | #14 (permalink) | |
