Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Aftermarket Upgrades
700 Aftermarket Upgrades Align T-REX 700 Aftermarket Upgrades by HF Vendors and Supporters
Old 08-29-2008, 10:50 PM   #61
Mike Fortin
The canopies come with dimples clearly marking where they should be drilled out, not a big issue.
Mike Fortin is offline        Reply With Quote
Old 08-30-2008, 06:24 PM   #62
cbdane
Agreed. Put away the drill bits though. In my opinion, nothing like the right tool.
http://www.readyheli.com/HZ050_Align...er_p/hz050.htm
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 04-16-2009, 07:45 PM   #63
helidirect
If you want them pre-drilled, let me know. I can request.
helidirect is offline        Reply With Quote
Old 04-16-2009, 08:40 PM   #64
John Cook
Location: Winnebago IL Where the politicians are MORE corrupt-Thanks alot Blago/Burris/Daley etc...
yeah I ordered the reamer for HD and got it today with a new canopy and it made reaming the holes a 10 second job.
KBDD
MKS Servos
Scorpion Power Systems/Batteries
Spartan RC
John Cook is offline        Reply With Quote
Old 05-11-2009, 03:14 AM   #65
masu
I surfed the stores and ended up looking at the V2 canopies. One store page said that the rubber canopy braces (or stands) have to be removed when using V2 canopies? Is this correct and does it affect using the original shaped canopy (if switching between the two)?
T-Rex 700NP, YS91SR/Kasama Header/SB19, GY611, ReactorX, BLS451, RevMax/9254
JR X9303
masu is offline        Reply With Quote
Old 05-24-2009, 01:38 AM   #66
helidirect
yes need to remove it. The shape does not change.
Old 05-24-2009, 04:18 AM   #67
nwolsink
You can cut them down a bit as well, then they still keep their function
SPEkTRUM DX8
TREX600NSP VStabi V5.3 / 55HZ
TREX700N DFC/3Gx/ 105 HZ-R
nwolsink is offline        Reply With Quote
Old 05-31-2009, 02:33 PM   #68
harrier808
Default New:Radical Designs from Canomod
i saw this at rc heli resource.
http://www.**************.com/newrad...-from-canomod/
ID:	99549   Click image for larger version
ID:	99550   Click image for larger version
ID:	99551   Click image for larger version
ID:	99552   Click image for larger version
Blade MCX, Blade MSR, Protos 500, 600ESP, 700E
harrier808 is offline        Reply With Quote
Old 11-28-2011, 10:35 PM   #69
harveyd
i wish the 700 nitro canopies would fit the 700e. i like that point-er look. like the velocity cano's and the 550e cano.
harveyd is offline        Reply With Quote
