Spirit FBL system Spirit FBL System Discussion |
07-15-2017, 03:03 AM | #1 (permalink) |
RPM: Jive 100+LV, X-Nova, Diabolo 550
Hello,
I want to the display the head speed of the main rotor (RPM) on my JETI DS-16. My equipment: - Transmitter JETI DS-16 with Spirit integration - Diabolo 550 (pinion 20 teeth and gear ratio 1:9,88) - ESC Kontronik Jive 100+ LV - Motor X-Nova 4020-1000 (Minicopter Edition) - FBL Spirit Pro (firmware up to date) Can somebody tell me what I have to do to get an exact head speed? Thank you! Chris |
07-16-2017, 09:30 AM | #2 (permalink) |
You only have to set General - Throttle/Governor - Gear Ratio to 9.90 and Sensing Divider to 4.
If the readout will be too low, set Gear Ratio to 3.30. Then i hope it will be fine. If you do not use Spirit Governor, enable the Governor temporarily to set these parameters.
Spirit System - www.spirit-system.com |
07-16-2017, 11:33 AM | #3 (permalink) | |
Thank you very much for your excellent support Tomas.
I have got another two Spirit Pro units, they will operate with Kosmik and Pyro. Is it always the same proceeding? --> Setting Gear ratio and Sensing Divider is "Poles of motor : 2"? And if it does not work then set Gear ratio to "Gear ratio : 3"? EDIT: Okay, finally I found the Sensing divider in the manual: Quote:
