Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics > 2.4G JR Radios
2.4G JR Radios JR 2.4 Gigahertz Radios and Technology
Old 08-24-2015, 01:54 AM   #1 (permalink)
Exclamation JR Telemetry
I'm planning to get the JR telemetry modules Temperature Sensor TLS1-TMP, Volatage Sensor TLS1-VOL and Motor RPM sensor TLS3-ROT. I have aN XG8 TX with RG7318X RX.
My question here is how do i connect all three sensors to the RX. Do i have to get the DMSS Telemetry Adapter TLS1-ADP and connect it to the Xbus port of the RX or is there any other alternate means to connect the same.
Please throw some light on the setup and configuration of the Telemetry Sensors .
rockinaero is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 09:39 AM   #2 (permalink)
Have you looked into the Unisens-e?
I'm interested in hearing the updated telemetry options for the XG8.
Calgary RC Heli Club Alberta, Canada
Oxy - Align - Spirit - Vbar - Frsky
RCHN 4 Life - #610
Jasons9 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 09:48 AM   #3 (permalink)
You will plug the adapter into the Sensor port next to the xbus port.
The JR telemetry is great. On my Forza 700 I use:
Altitude alarm
Mah consumption alarm
Amp draw
Main pack voltage alarm
Rotor RPM
It's very nice not using a flight timer.
I also run a CC bec pro in conjunction with a optipower ultra guard. If the the bec drops out and the ultra gard is in use. I have a alarm set on rx voltage. The ultra guard runs around .5 volts less than the bec. Which it auto detects the voltage on startup. I don't look at the screen while fying, but it is nice to have a alarm for failures.
Team JR Americas
Synergy Helicopters
Rail Blades
Scorpion Motors
justinspicer is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 01:31 PM   #4 (permalink)
Get the hub for more than one sensor, they are just connected in parralel.
More info
http://www.jrpropo.com/english/propo/XBus/index.html
Hub
http://www.horizonhobby.com/product/...-dmss-jrp03439
VControl
Old hand at Planks
Peter
Old 08-27-2015, 04:30 AM   #5 (permalink)
Thanks Vinger and Justin spicer.
I would get the adapter TLS1-ADP adapter lyk u said.
cheers
Old 09-14-2015, 10:51 AM   #6 (permalink)
Altitude alarm
Amp draw
Rotor RPM
JR has Mah consumption telemetry now?? Please do tell more.
Synergy 766, Goblin 700C, Synergy E7 SE, Logo 700, Align 700x, Logo 550sx, Goblin 500, Oxy3 TE, BK Servos, Spartan VX1e, TX - JR XG14 Xbus
rb30cory is offline        Reply With Quote Quick reply to this message
Old 09-14-2015, 04:17 PM   #7 (permalink)
http://www.jramericas.com/211289/JRP03438/?pcat=333
That one has a lower volt and amp limit.
On my 700 I use the Unisense E sensor.
It is one sensor that gives RPM, Vario, Amps, Mah draw, Main pack voltage, barometric altitude.
http://www.sm-modellbau.de/shop/prod...2cb45f8aed990a
You will also need the USB cable to program the Unisense.
Team JR Americas
Synergy Helicopters
Rail Blades
Scorpion Motors
Old 09-15-2015, 10:49 AM   #8 (permalink)
Did you order the Unisens E from there? Do you have any sample logs or screen shots of the radio you could show us?
Thanks for the info!
Steve
senzafine is offline        Reply With Quote Quick reply to this message
Old 09-18-2015, 10:59 AM   #9 (permalink)
The Jlog works well too, easy to get in the U.S. through HeliDirect to name one.
I had it working really well with Jives, not so well with Castle but I think some others have gotten that ironed out.
exfokkerflyer is offline        Reply With Quote Quick reply to this message
Old 09-18-2015, 12:09 PM   #10 (permalink)
Default JR Telemetry
Could you show the wiring of the Jlog or Unisens E?
Trying to grasp the concept and a picture would help a lot...
Gh
goodhunting is offline        Reply With Quote Quick reply to this message
Old 09-25-2015, 02:22 PM   #11 (permalink)
The wiring of the Jlog depends on what ESC you are using. Best to go to the site and figure it out from there. Kontroniks are very simple but something like a castle requires an adapter be made. Unisens-e is inline between the ESC and the batteries.
Jlog site. http://j-log.eu/jlog2-en/
Old 09-20-2016, 03:49 PM   #12 (permalink)
what radio are you using?
drjondice is offline        Reply With Quote Quick reply to this message
Old 09-20-2016, 03:49 PM   #13 (permalink)
Old 09-21-2016, 09:50 AM   #14 (permalink)
I am using a Castle 160 on my Jlog and it works well. I didn't have any issues setting mine up? The radio in the photo is an XG14 which is what I am using as well.
Old 10-26-2016, 02:13 AM   #15 (permalink)
Hello gents,
I am using Unilog2 telemetry, with a current sensor. It works well and gives main battery voltage, current amps, consummed mAh, altitude. It works awesomely on my XG8.... apart from a detail: after autorotation, the displayed data is like "frozen" until I start the engine again...
It's annoying because the remaining battery capacity goes back to the configured default value (5000 in my case) until I spool up the engine again.
I would like to this value BEFORE restarting the engine...
I firstly thought it was a start/stop problem from the Unilog2 module, but after having analysed the records, it appears that the module remains on and is transmitting the values even when the autorotation is activated (throttle value at around 10%).
Then I release the throttle from autorotation (10%) to off (0%). The display is still frozen. When I spool up the engine again (50%), the displayed data makes like a jump to current values.
So it seems that the radio that freezes the display upon activation of autorotation... which is annoying.
Any of you has a solution about that?
myster.mask is offline        Reply With Quote Quick reply to this message
