Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > Esmart
Esmart E-Sky Esmart
Old 11-22-2008, 01:17 AM   #1 (permalink)
Default would anybody buy g10 frames?
just curious if there would be a market for cnc cut g10 side frames for esky carbon version belt cp/honey bee/e smart helicopters. Would you guys buy them?
Mainly built out of g10 but custom materials are possible. Maybe Lexan with led in it for night flying.
Stock Esky cut or Direct To Swash cut (belt cp only for now, until i get my hands on anything else.
The DTS sides would be identical to each other so IF they broke you would only need an upper or lower, not an upper RIGHT or lower LEFT. This would give left OR right elevator servo mounting options as well.
Custom designs can be used for the weight savings cuts (the slots at the rear and by the battery)
To convert your plastic belt cp to dts g10 upgrade version, all you would need is the frames and either the plastic or aluminum bearing/crossmember set
Will also be able to cut just about any flat part. Tail fins, battery trays, Trex frame sides.
MSR-X, Nano CPX, Belt CP Metal Edition w/g10 DTS align compatible frame, Trex 450 pro v2 w/metal upgrades, TREX 550e v2 w/ kde upgrades.
CUSTOM CNC MACHINING... Inquire within.
onehot69stepside is offline        Reply With Quote Quick reply to this message
Old 11-22-2008, 03:24 AM   #2 (permalink)
I think the biggest factor is "would it be cheaper $ then the E_Sky Carbon Fiber frames/panels?"
nuttcaze is offline        Reply With Quote Quick reply to this message
Old 11-22-2008, 01:17 PM   #3 (permalink)
well if you are paying the same price for the esky sides, why woudnt you want the stronger, g10. On an esmart, it would even be beneficial to replace the aluminum frames because it would take more force to break the g10 than it would be to bend the aluminum. Its like carbon, doesnt bend and is stronger until you get to the breaking point.
Old 11-22-2008, 02:35 PM   #4 (permalink)
so they would be the same price? because if thats the case I'd be interested in some (in a few weeks though, bills arghh)
Old 11-22-2008, 02:45 PM   #5 (permalink)
well if i want to do this, (and it looks as if i am) the first frame would be at least a couple weeks out anyways. Id better get busy in cad.
Old 11-22-2008, 02:51 PM   #6 (permalink)
I would be up for a set as well. For those of us still on 72 mHz this would have the added bonus of being non-conductive as well.
Dave
Design Engnr is offline        Reply With Quote Quick reply to this message
Old 11-22-2008, 03:00 PM   #7 (permalink)
yeah keep me posted, I might need a few sets I still have to rebuild my ES that I buried into the ground the other week
Old 11-23-2008, 10:38 PM   #8 (permalink)
Actually, I am looking for a set of silver G10 frame for the e- smart. Some mods I can suggest are the ff:
1. Use a 2mm G10 sheet (silver)
2. Refer to the pics below for some mods on the frame. Some weak spots I noticed.
If you can actually incorporate this mods to the aftermarket sideplates you are going to make, I'll buy several sets.
Another thing, if you know anybody or if you can do an aftermarket delrin main gear, that would be nice and I will definitely buy a few.
Name:	main frame.JPG
ID:	70280   Click image for larger version
Name:	bottom frame.JPG
_____________________
Scott's Hobbies
DVS inc.
damyxz is offline        Reply With Quote Quick reply to this message
Old 11-24-2008, 01:23 PM   #9 (permalink)
i also forgot to mention, g10 does come in a variety of colors.
And yes, I can incorporate strength changes, I can do whatever you want, although if i come out with a dts frame for the esmart, the design will be completely different
Old 11-24-2008, 04:41 PM   #10 (permalink)
AND as soon as I get the frames in production, I think delrin gears for the e smart is a very good possibility guys.
Old 11-24-2008, 05:52 PM   #11 (permalink)
you find a way to make/get stronger gears and pretty much every ES600 flyer will be overloading your inbox with pm's requesting some, they'll all be below my PM
Old 11-24-2008, 11:34 PM   #12 (permalink)
i would have to get a turnable and a 4 axis cnc controller to machine gears. You guys gotta wait on gears until I get some frames out.
Old 11-24-2008, 11:39 PM   #13 (permalink)
The E-smart frame's basic design is as good as it gets. Just strength changes in the cutout of the stock frame will do. Another iteration of the bottom frame plate that I can think about is attached(I draw it using ms paint). Anyway the top frame's basic design is OK(I do not like direct to swash-It's a hype with what you get on performance. It is harder on the servos since you will be using longer arms and the force from the head is directly transmitted to the servo gears. This will wear the zero point on the servo pot and the servos will lose it's center quickly)
Scott's Hobbies
DVS inc.
Old 11-24-2008, 11:40 PM   #14 (permalink)
forgot the pic
Scott's Hobbies
DVS inc.
Old 11-24-2008, 11:41 PM   #15 (permalink)
here's the pic
Scott's Hobbies
DVS inc.
Old 11-25-2008, 12:36 AM   #16 (permalink)
oh oh, my request is to have an opening that would give better access to the bolt on the bottom of the main shaft, trying to change gear now makes me want to throw my heli (which I've done) its the one thing I absolutely hate about this heli, why its so hard is beyond me , and I've changed alot of main gears. Make that access and I promise I will get sets for all 3 of my ES600's
Old 11-27-2008, 12:49 AM   #17 (permalink)
ill see about that opening when i take a gander at mine tonight, nutt.
I'm having some trouble getting all my ducks in a row to get the mill here. The CNC system is on its way So This IS a for sure thing. Its just a matter of time guys.
Old 11-27-2008, 09:29 AM   #18 (permalink)
No worries! I will still be looking for a set frames when the mill arives.
Dave
Old 11-27-2008, 09:44 AM   #19 (permalink)
Before -
After -
Old 11-27-2008, 05:00 PM   #20 (permalink)
Are you considering making prototype's in "any" material ? (plasics, ally, wood?)
Anything that flies
Ber60 is offline        Reply With Quote Quick reply to this message
