Balance only 2s lipo charging - HeliFreak
Old 12-31-2016, 06:01 AM   #1 (permalink)
Default Balance only 2s lipo charging
PL8dual + bump and some parallel charging boards -
Cant charge 2S lipos trough parallel board because voltage is not detected.
So how can it be done - beside THIS ?
Oxy3, Goblin 380, 380kse, 500s, 700, 770 and T-rex 700 night & Dx9
My youtube weekly
badgravity is online now        Reply With Quote Quick reply to this message
Old 12-31-2016, 07:03 AM   #2 (permalink)
You need to use the small 1s/2s unbalanced preset on the charger.
Ace Dude is offline        Reply With Quote Quick reply to this message
Old 12-31-2016, 07:39 AM   #3 (permalink)
This seems to work other way around - by un ticking checkbox I Get
#34 wrong cell count or with tick #20 Bad cell count OR #19 no pack on bump
manual settings - Lipo - 2S Accu or normal charge
My youtube weekly
Old 12-31-2016, 07:50 AM   #4 (permalink)
This is covered on page 69 in the manual here:
http://www.revolectrix.com/support_docs/item_1431.pdf
Old 12-31-2016, 08:18 AM   #5 (permalink)
Thats my point: from manual page 69
"LiPo 1s/2s Small Non Balanced
Special LiPo preset designed for charging small Park Flier type batteries that are not equipped with balance connectors. "
where as - in my example all I have is balance connector.
My youtube weekly
Old 12-31-2016, 08:38 AM   #6 (permalink)
Okay, wasn't sure how you had it connected.
There are a few options:
1) You're going to need to use a balance board adapter as shown in your first post.
2) Makeup your own lead between the pack and main leads on the charger and charge as unbalanced.
3) Build a lead from the mains on the charger to your existing balance board which would essentially have you make your own version of option 1 above. This is a bit more challenging so be careful wiring it up if you go this route.
The Micro ParaBoard you linked to looks like the best option.
Old 12-31-2016, 10:07 AM   #7 (permalink)
I have a Trex150 too, so i went with similar #3 above - created a jumper with a female Deans connector on one end and XH on the other end (center wire is left unconnected). So I just plug this into my MPA and then plug the batteries into the XH connectors of the MPA to charge. Just make sure you dont leave the jumper plugged in and connect something other than 2S to the MPA.
RevoKelly is offline        Reply With Quote Quick reply to this message
Old 12-31-2016, 11:54 AM   #8 (permalink)
I was a bit hesitant to recommend option #3 for the reasons you identified. If you're not careful, unintended results can occur resulting in more $$$ damage than purchasing the specially made balance board for this application. I don't use those packs, but if I did, I'd get the balance board to mitigate the chances of me making mistake and creating a random smoke generating (RSG) circuit.
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
